Minor problem with the smtp server name
Bob.Dig
Post by Bob.Dig » 2020-07-01 16:51
Thanks to hmailserver, I run my own, personal mailserver at home (behind a pfSense).
I only get a residential IP-address. So I got myself a cheap VPS, installed OpenVPN on it and route my mails from home with pfSense out to the internet over that vps...
I configured rDNS for that IP-address and put that name in the "local host name" field in the hmail smtp settings, so far so good.
But if I get email, than that name will not match, because it is the ip of the VPS, not my home.
So what can I do about it? I don't want to run the mailserver at any other place then my home. So I guess I have to install a relay on my VPS... Is there another solution? Or maybe just leave it as it is? Seem to work.
johang
Re: Minor problem with the smtp server name
Post by johang » 2020-07-01 18:21
Bob.Dig wrote:
2020-07-01 16:51
what do you mean ? what name is it that you want matching when recieving ?? ( it is more important it matches when you send...... " Delivery of email" )
does it work ?
what is your actual question ?
Bob.Dig
Post by Bob.Dig » 2020-07-02 10:29
johang wrote:
2020-07-01 18:21
does it work ?
It is all in my post, which you quoted fully...
Virinum
Post by Virinum » 2020-07-02 13:24
Bob.Dig wrote:
2020-07-01 16:51
Can you explain that in more detail? I don't understand your problem.
Generally the rDNS is mostly important for sending mail.
Bob.Dig
Post by Bob.Dig » 2020-07-02 13:34
Virinum wrote:
2020-07-02 13:24
That is true so it is not as important, but still not looking perfect.
E.g. if I do the smtp-test on mxtoolbox.com:
SMTP Banner Check Reverse DNS does not match SMTP Banner
That is why I am asking.
Virinum
Post by Virinum » 2020-07-02 13:45
Is your incoming and outgoing mail traffic routet over your VPS? Or only the outgoing?
Maybe you could send me your domain via pm?
Post by SorenR » 2020-07-02 14:11
My server is no longer FCrDNS as I changed provider last year. I now use 4G router (fixed IP). 8)
I have not registered any issues with rDNS not matching HELO greeting since the change last year. I do however have active SPF and DMARC records. Also over time I have had to "register" with DNSBL's to validate my IP addresses as they have all been residential allthough fixed. IIRC I've had 3 different IP addresses over the past 14 years.
Bob.Dig
Post by Bob.Dig » 2020-07-02 21:09
Virinum wrote:
2020-07-02 13:45
Only that, email is "policy routed" by pfSense out to the vpn at my VPS.
Virinum
Post by Virinum » 2020-07-02 22:29
Then just ignore the rDNS for incoming mail. Take a look at the receiving mailserver of google: https://mxtoolbox.com/SuperTool.aspx?ac ... tworktools
It doesn’t match, too. No sending mailserver will check if the rDNS is correct. Just a receiving mailserver will do that.
Bob.Dig
Post by Bob.Dig » 2020-07-03 14:18
Virinum wrote:
2020-07-02 22:29
Thanks, wasn't sure about that.
Post by mattg » 2020-07-10 08:07
Virinum wrote:
2020-07-02 22:29
Although some sending servers WILL check the SSL certifciate name matches the rNDS
The OP doesn't state if they have a certificate or not
ALSO, as stated by some above, very few receiving servers will demand that the rDNS matches the local host name. Normally just a valid rDNS is OK
If this really is a concern, why don't you use the VPS for both incoming and outgoing mail
Much more important in my view to have a valid certificate, issued from a real Authority (not self signed) and have DMARK and SPF set up correctly on your domain. I use LetsEncrypt - they are free
And off topic slightly, but was the VPS actually cheaper than getting business grade internet at home?
Here in Australia, Business grade Internet with static IP is perhaps $10 per month more expensive than home grade internet (same speed), where as a VPS is at least $60 per month
Bob.Dig
Post by Bob.Dig » 2020-07-10 09:08
2020-07-10 08:07
Hello mattg,
my idea is to have as few data as possible outside my own hmailserver installation at home. So even the vps counts against that. LE, DMARK and SPF and even DANE, I managed to set that up. :D
Although DANE is not automated here.
And with vps, I meant a virtual server, not a dedicated one. So its cost my less then 3 bugs (€) a month, which is still expensive for what it is doing, but so far, I am ok with it.
Virinum
Post by Virinum » 2020-07-10 09:42
2020-07-10 08:07
Ok, that's new to me. I always tought only the hostname in the mx record is checked against the certificate.
Bob.Dig wrote:
2020-07-10 09:08
Just keep the private key and you don't have to set a new DANE record every time the certificates gets renewed. Most LE clients provide an option for keeping the private key.
Bob.Dig
Post by Bob.Dig » 2020-07-10 10:28
Virinum wrote:
2020-07-10 09:42
2020-07-10 08:07
I am just a novice user, but to have a matching cert is not a problem I think, mine is even a wildcard.
Bob.Dig wrote:
2020-07-10 09:08
Virinum wrote:
2020-07-10 09:42
Actually on my side is nothing automated. I use pfSense for the certificate and than manually copy the cert over.
I'm ok doing this four times a year, because I'm the only one using this server anyway.
I'm not sure if I got DANE correct, but I think, if the intermediate certificate is not changing, than I don't have to update the DANE record, will look closely, when this will happen next time.
A lot of I's in that. :shock:
Post by mattg » 2020-07-11 06:48
Virinum wrote:
2020-07-10 09:42
2020-07-10 08:07
If you SMTP relay from hMailserver to another server that requires a secure connection and you have in SSL settings 'verify remote server SSL /TLS certificates' set (which is the default), then your hmailserver as the SENDING mailserver will confirm that the name on the certificate matches the name self identified by the remote server, and also the chain of trusted issuers. We noticed this issue with gmail >> https://www.hmailserver.com/forum/viewt ... 21&t=32158
Some servers will check who issued a certificate (matches a CAA record on DNS) for a particular server, and also DNSSEC confirms DNS records are correct
This is an example of a tool that can test the rdns and compare to certificate name
https://github.com/drwetter/testssl.sh/issues/1116
