Server issues (crash)
dvsatech
Post by dvsatech » 2020-07-03 06:05
I am having a problem where my new build hmailserver crashes with an error. I have version 5.6.7-B2425 (32 bit) with MSSQL CE installed on a new wndows 10 64-bit PC 2 CPU, 2 Core and 8G ram and 250G SSD disk with all patches to date loaded. My logs has 10 minidunps and 5 ERROR_ files.
Perfromance->threading is (defaults)
Max Command Threads: 15
Delivery Threads: 10
Max Number Async Threads: 15
Worker Priority: Normal
No more threads can be created in the system. (Exception from HRESULT: 0x800700A4)
ExceptionType: COMException
HelpLine:
Message: No more threads can be created in the system. (Exception from HRESULT: 0x800700A4)
Source: Interop.hMailServer
StackTrace: at hMailServer.IInterfaceApplication.get_Status()
at hMailServer.Administrator.ucStatus.ShowStatistics()
at hMailServer.Administrator.ucStatus.timerServerStats_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
TargetSite: hMailServer.Status get_Status()
Suggestions? I have processed about 35,000 emails in the last 4 days.
Re: Server issues (crash)
Post by jimimaseye » 2020-07-03 09:13
What is the date and time of the dumps, I'm guessing they are all at the same time? If they are and they were some days ago and the dumps have not happened since then I would suggest don't worry about it as you will never know the answer. Just be happy that your system is continuing to run ok. Maybe if you view the error files it might give you a clue as to what the problem is.
Post by mattg » 2020-07-10 07:57
dvsatech wrote:
2020-07-03 06:05
There will only ever be the LAST 10 minidumps, older ones are deleted
There should be an error file EACH day
Where do you see the error that you report?
ALSO, what is the contents of the daily error logs?
dvsatech
Post by dvsatech » 2020-07-12 23:04
Sorry, been a few days since I have been here...
All the following files are in: C:\Program Files (x86)\hMailServer\Logs
All the minidumps listed are all 7/12/2020 now, doesn't show any other dumps but all the dump files are today (I assume because there are 10 of them the old ones are gone). I sent a mailing today to about 10,000 subscribers.
How do I look at a dump file?
There is an hmailserver_<date> file per day
There are also 6 ERROR_hmailserver_<date> in the directory as well (dates 6/25, 6/29, 6/30, 7/1, 7/2, 7/12 probably coincides with dates I sent mailings out)
johang
Post by johang » 2020-07-12 23:19
dvsatech wrote:
2020-07-12 23:04
did you answer the questions ? particularly regarding the content of the error files ?
dvsatech
Post by dvsatech » 2020-07-12 23:25
"ERROR" 4828 "2020-07-12 14:48:58.389" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:48:58.452" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3376 "2020-07-12 14:48:58.467" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3360 "2020-07-12 14:48:58.998" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4884 "2020-07-12 14:48:58.998" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 2392 "2020-07-12 14:48:58.998" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3340 "2020-07-12 14:48:58.998" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4824 "2020-07-12 14:48:59.014" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4808 "2020-07-12 14:48:59.014" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3380 "2020-07-12 14:48:59.061" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4828 "2020-07-12 14:49:00.280" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144858_{EB916FFC-78E3-499D-90FD-8A5916B80F07}.dmp"
"ERROR" 4828 "2020-07-12 14:49:00.295" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:49:00.576" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144900_{E981E9B4-9B6E-4165-A2BB-4C7CBA4B85CE}.dmp"
"ERROR" 4812 "2020-07-12 14:49:00.592" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4808 "2020-07-12 14:49:00.842" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144900_{72F4C8F7-CB59-40D6-97DE-AAE133197E5E}.dmp"
"ERROR" 4808 "2020-07-12 14:49:00.905" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:49:01.123" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144900_{1B5B521A-96C4-48B2-ABFB-02DE7A93E5EB}.dmp"
"ERROR" 4812 "2020-07-12 14:49:01.123" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4828 "2020-07-12 14:49:01.389" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144901_{314F4F82-2D57-4462-8CF8-C290C68721E5}.dmp"
"ERROR" 4828 "2020-07-12 14:49:01.404" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:49:01.670" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144901_{7D6C5C68-8317-45C0-B7BE-21C3007BC60A}.dmp"
"ERROR" 4812 "2020-07-12 14:49:01.717" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4808 "2020-07-12 14:49:01.936" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144901_{8E27BAE4-710B-49EC-84A6-9DBEC437E91E}.dmp"
"ERROR" 4808 "2020-07-12 14:49:01.951" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:49:03.045" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144901_{112F1002-A45E-42B3-98DE-29F526A0F58C}.dmp"
"ERROR" 4812 "2020-07-12 14:49:03.061" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4808 "2020-07-12 14:49:03.264" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-07-12 144903_{120D348A-675E-4CEE-A830-BBA0CF82E13A}.dmp"
"ERROR" 4808 "2020-07-12 14:49:03.279" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4812 "2020-07-12 14:49:03.295" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4812 "2020-07-12 14:49:03.295" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4812 "2020-07-12 14:49:03.311" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 4828 "2020-07-12 14:49:03.311" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4828 "2020-07-12 14:49:03.311" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 3376 "2020-07-12 14:49:03.311" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 3376 "2020-07-12 14:49:03.311" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4828 "2020-07-12 14:49:03.311" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3340 "2020-07-12 14:49:03.326" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 3340 "2020-07-12 14:49:03.326" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 3376 "2020-07-12 14:49:03.326" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask'"
"ERROR" 3360 "2020-07-12 14:49:03.326" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 3360 "2020-07-12 14:49:03.326" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 3380 "2020-07-12 14:49:03.326" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 3380 "2020-07-12 14:49:03.326" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 2392 "2020-07-12 14:49:03.342" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 2392 "2020-07-12 14:49:03.342" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4824 "2020-07-12 14:49:03.342" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4824 "2020-07-12 14:49:03.342" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4884 "2020-07-12 14:49:03.357" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4884 "2020-07-12 14:49:03.357" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4808 "2020-07-12 14:49:03.357" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4808 "2020-07-12 14:49:03.357" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4812 "2020-07-12 14:49:03.357" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4812 "2020-07-12 14:49:03.357" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 4828 "2020-07-12 14:49:03.373" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 4828 "2020-07-12 14:49:03.373" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
"ERROR" 3376 "2020-07-12 14:49:03.373" "Severity: 3 (Medium), Code: HM5401, Source: ProcessLauncher::Launch, Description: There was an error launching external process hMailServer.minidump.exe. Process start failed. Windows error code: 19"
"ERROR" 3376 "2020-07-12 14:49:03.373" "Severity: 1 (Critical), Code: HM5521, Source: StackLogger::Log, Description: An error has been detected. hMailServer was unable to launch minidump generator."
Post by mattg » 2020-07-13 07:27
Please run this and post the results
viewtopic.php?f=20&t=30914
jim.bus
Post by jim.bus » 2020-07-13 07:35
In your SMTP Header Forum Thread you state you are a commercial environment. If so, then you may not use MSSQL CE in a Commercial Environment. See this link for the latest hMailServer B2425 Documentation:
https://www.hmailserver.com/documentati ... ase_engine
This link states you may only use MSSQL CE for personal installations not commercial installations.
Post by jimimaseye » 2020-07-13 07:49
jim.bus wrote:
2020-07-13 07:35
This is no longer true. MS eula, on which this claim was based, has recently been discussed and reviewed and concluded it was no longer correct to make such a claim. It "is freely redistributable under a redistribution license agreement" without restriction on environment. (https://www.microsoft.com/en-gb/downloa ... px?id=5783)
johang
Post by johang » 2020-07-13 10:32
dvsatech wrote:
2020-07-12 23:04
All the following files are in: C:\Program Files (x86)\hMailServer\Logs , All the minidumps listed are all 7/12/2020 now, doesn't show any other dumps but all the dump files are today (I assume because there are 10 of them the old ones are gone). I sent a mailing today to about 10,000 subscribers. How do I look at a dump file? There is an hmailserver_<date> file per day. There are also 6 ERROR_hmailserver_<date> in the directory as well (dates 6/25, 6/29, 6/30, 7/1, 7/2, 7/12 probably coincides with dates I sent mailings out)
i just stole an answer from Dravion provided in another thread regarding: reading open dump file ; minidump .dmp :
Minidumps can be read by WinDBG, the official Microsoft Windows Debugger. Its an Experttool for Programmers only. Its free avaiable as part of the Windows Driver Kit or the Windows SDK or as Debugging Tools for Windows Standalone Package.
your posted loglines from error log is a bit sparse, it is hard to tell what caused the crash to happen.. those loglines more state that "something" went wrong and because of that it writes a dump file .. there really is not a a simple .. ohh theres the cause in those lines from error log provided .. ( BUT i will still ADD in here ... you arent doing AV scans internally in your server ... are you ? ... you have disabled the AV scans for every directory that hmailserver uses and wants to use ?? (number 2, Antivirus intervention in https://www.hmailserver.com/forum/viewtopic.php?t=31519 applies at all times )
To be able to perhaps see why or what made it crash you want to pick up loglines from hmailserver log as well as from the error log and cross reference those 2 information sources in respect to time stamping ..
+ your diagnostics, .... and where the error report comes from that you post as 1st post, ( Mattg asked about earlier )
( and icing on the cake ... look at corresponding events in time with microsoft event and microsoft error logs ... )
