Can´t connect from clients to hmailserver when using SSL
RDA
Post by RDA » 2020-07-12 19:19
Hello there,
I'm trying to secure my mail server with SSL which I transfered directly from my Apache webserver running in a diffrent machine. Since I configured the SSL settings in hMailServer, no clients can connect. When I checked diagnostics no error shows up. I ran the HMS Settings Diagnostics script and couldn't figure out where the issue is. Please help.
Thanks in advanced.
2020-07-12   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - abxx.lk                        Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain1.com
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - inxxxxx.uk                     Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain2.com
        Greylisting:     False
   "Domain3.com" - itxxxx.co.uk                   Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain3.com
        Greylisting:     False
IP RANGES
     External To External - False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
                              Minutes Before Reset:           60  (1.00 hours, 0.04 days)
                              Minutes to Autoban:            300  (5.00 hours, 0.21 days)
There is a total of 10 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                                               Max number commands: 100  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Add X-HmailServer-Subject:  True    Verify DKIM:       False
              Subject Text: "[SPAM]"
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              [@t]Domain1[dot]lk
              0.0.0.0            to    255.255.255.255              [@t]Domain2[dot]co[dot]uk
              0.0.0.0            to    255.255.255.255              [@t]Domain3[dot]uk
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   Domain1.com
       Certificate: \\172.16.10.50\SambaShare\Domain1.com\fullchain1.pem
       Private key: \\172.16.10.50\SambaShare\Domain1.com\privkey1.pem
   Domain2.com
       Certificate: \\172.16.10.50\SambaShare\Domain2.com\fullchain2.pem
       Private key: \\172.16.10.50\SambaShare\Domain2.com\privkey2.pem
   Domain3.com
       Certificate: \\172.16.10.50\SambaShare\Domain3.com\fullchain6.pem
       Private key: \\172.16.10.50\SambaShare\Domain3.com\privkey6.pem
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :  False
             TLS 1.1 :  False
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
               0.0.0.0         / 110   / POP3   -   StartTLS Required   Cert: Domain1.com
               0.0.0.0         / 143   / IMAP   -   StartTLS Required   Cert: Domain1.com
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: Domain1.com
               0.0.0.0         / 587   / SMTP   -   StartTLS Required   Cert: Domain1.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: Domain1.com
  Paths:-
    Current:  F:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-07-12.log
    Error:    F:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-07-12.log - !! ERRORS PRESENT !!
    Event:    F:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  F:\Program Files (x86)\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory E:\HmailBU is writable.
HMAILSERVER.INI
Program folder:  F:\Program Files (x86)\hMailServer\
Database folder:
Data folder:     F:\Program Files (x86)\hMailServer\Data
Log folder:      F:\Program Files (x86)\hMailServer\Logs
Temp folder:     F:\Program Files (x86)\hMailServer\Temp
Event folder:    F:\Program Files (x86)\hMailServer\Events
Type=              MYSQL
Username=          root
Port=              3306
Server=            localhost
Internal=          0
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
johang
Re: Can´t connect from clients to hmailserver when using SSL
Post by johang » 2020-07-12 19:38
RDA wrote:
2020-07-12 19:19
Hello there,
Thanks in advanced.
DOMAINS
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   Domain1.com
   Domain2.com
   Domain3.com
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :  False
             TLS 1.1 :  False
SslCipherList  :
  Paths:-
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Database folder:
Type=              MYSQL
Username=          root
Port=              3306
Server=            localhost
Internal=          0
start with removing the SSL for port 110 and 143 ( remove start TLS required ) so your clients work as normal ..
THEN you test with your own client your setup on port 465, 587 and 993
IF you can get that to work on those ports you can add STARTTLS ( Optional ) on port 110 and 143 because you have no clue if the clients support "required" on port 110 and 143 ... and absolutetly not "on the fly" ( with that i mean earlier configuration of clients to use port 110 and 143 without encryption .. and then all of a sudden you just enforce it ... clients will take a dive ... )
and
SSL/TLS
SSL 3.0 : False
TLS 1.0 : False --> change to true
TLS 1.1 : False --> change to true
TLS 1.2 : True
i havent dared to go 1.2 only .. yet .. a bunch of iphone-users i have does not support it correctly ..
RDA
Post by RDA » 2020-07-12 21:25
Did all that changes and still can't connect.
johang
Post by johang » 2020-07-12 21:38
RDA wrote:
2020-07-12 21:25
did you reboot ?
what does your hmailserver log say ? ( you should have checked the boxes for: Application, SMTP, POP3, IMAP, TCP/IP, an perhaps debug depending on your level of knowledge )
what does your error log say
( have you tested to unistall that SSL certificate so you are back to the beginning ? )
and post diagnostics again..
RDA
Post by RDA » 2020-07-12 22:20
"ERROR" 5928 "2020-07-12 09:57:20.497" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 25, Error: use_certificate_file: asio.ssl error"
"ERROR" 1868 "2020-07-12 09:57:41.201" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 25, Error: use_certificate_file: asio.ssl error"
"ERROR" 1868 "2020-07-12 09:57:41.232" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 143, Error: use_certificate_file: asio.ssl error"
"ERROR" 4760 "2020-07-12 09:58:15.341" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 25, Error: use_certificate_file: asio.ssl error"
"ERROR" 4760 "2020-07-12 09:58:15.404" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 143, Error: use_certificate_file: asio.ssl error"
"ERROR" 4760 "2020-07-12 09:58:15.419" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 465, Error: use_certificate_file: asio.ssl error"
"ERROR" 3468 "2020-07-12 09:58:53.669" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 25, Error: use_certificate_file: asio.ssl error"
"ERROR" 3468 "2020-07-12 09:58:53.716" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 143, Error: use_certificate_file: asio.ssl error"
"ERROR" 3468 "2020-07-12 09:58:53.763" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 465, Error: use_certificate_file: asio.ssl error"
"ERROR" 3468 "2020-07-12 09:58:53.779" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 587, Error: use_certificate_file: asio.ssl error"
"ERROR" 4440 "2020-07-12 09:59:55.419" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 25, Error: use_certificate_file: asio.ssl error"
"ERROR" 4440 "2020-07-12 09:59:55.466" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 110, Error: use_certificate_file: asio.ssl error"
"ERROR" 4440 "2020-07-12 09:59:55.482" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: \\172.16.10.50\SambaShare\cert1.pem, Address: 0.0.0.0, Port: 143, Error: use_certificate_file: asio.ssl error"
I removed the SSL certificates and tested, working like a charm. Not sure what's wrong with the SSL certificates as I shared the same SSL certificates that my Apache is using to host.
Post by jimimaseye » 2020-07-12 22:25
1, check the certificates are in the right format
2, map the network instead of using UNC path
3, ensure permissions are set in the files and path to allow the hmailserver service to read them
RDA
Post by RDA » 2020-07-13 14:14
Thanks for the support. I removed the certificates and convert them using https://www.sslshopper.com/ssl-converter.html all works without any issues.
So the issue is with the certificate format even though they are already in *.pem format in Ubuntu Apache server. When I convert them they came in *.der format which had no issues whatsoever.
Any idea how I can get this to *.der or *.crt format...?
Post by mattg » 2020-07-14 01:22
RDA wrote:
2020-07-13 14:14
I use Ubuntu >> Lets Encrypt auto generated certificates in PEM format
(I used to use Apache, but UPGRADED to Nginx earlier this year - no issues with either)
I use UNC path to my Ubuntu server
You need to make sure that the certificate UNC path is accessible to the USER that runs the hmailserver SERVICE
I had to change my hMailserver SERVICE 'run as' to a regular account that had the required SAMBA permissions, from the default 'local system'
You could alternatively just copy the certificate files to your hMailserver machine each time that they change. Lets Encrypt change after 30 days so this can be a painful task when using lets encrypt
RDA
Post by RDA » 2020-07-14 01:48
Thank you very much for the support
jim.bus
Post by jim.bus » 2020-07-14 10:29
2020-07-14 01:22
I'm not sure how the Error Messages relate to this but RDA should also make sure the certificate files hMailServer are reading are not Password Protected.
And mattg, I can't resist razzing you a little about this. This is the second time I know of when you seem to have forgotten that Let's Encrypt Certificates actually expire after 90 days not 30 days. Though you are correct it can be a painful task even at 90 days. I fortunately have my Let's Encrypt Certificates automatically renewed by my NAS Server and I just export from it and import into hMailServer. It's still a bit cumbersome to import it into hMailServer but it isn't too bad a chore.
Post by mattg » 2020-07-14 10:59
jim.bus wrote:
2020-07-14 10:29
2020-07-14 01:22
Oh I know that they expire after 90 days, but they are actually replaced before expiry date.
https://certbot.eff.org/docs/using.html ... d-renewals
certbot renew - This command attempts to renew any previously-obtained certificates that expire in less than 30 days
Looking at the historical certificates on my system, and thinking this through, that actually means that certificates are replaced after 60 days by default using certbot (Linux + Cron).
Life of the certificate is not the same as the time between replacements.
It matters little to me, except that I need to restart my hMailserver somewhere in the 30 days between when a subsequent certificate is issued, and the current certificate expires.
This is normally handled with Windows updates.
See where I get the 30 days from? :D
jim.bus
Post by jim.bus » 2020-07-14 11:55
2020-07-14 10:59
jim.bus wrote:
2020-07-14 10:29
2020-07-14 01:22
Yes, my Let's Encrypt Certificates also renew after 60 days as well but my statement was that they expire in 90 days and your statement was they change in 30 days. But I am a nitpicker and like to have fun with nitpicking. Hope you don't mind my picking on you a little.
Post by mattg » 2020-07-14 14:09
All good :mrgreen: :mrgreen:
Bob.Dig
Post by Bob.Dig » 2020-07-14 14:19
If I remember correct, hmailserver has a naming issue. Mine look like this and that works fine.
xyz.com.fullchain
xyz.com.key
jim.bus
Post by jim.bus » 2020-07-14 20:32
I've had problems with my Let's Encrypt certificate when trying to use the chain.pem file. hMailServer gets errors with it. Seemingly this appears to be in the chain.pem file. The validity date is already expired if memory serves me corretly.
So, I've been using the cert.pem and privkey.pem files in hMailServer which has seemingly works with no issues.
