SMTP Relayer Authentication Setup
Pertzis
Post by Pertzis » 2020-07-23 21:18
Hello everyone,
I recently started to get into Email Server hosting with hMailServer, so please excuse me of my knowledge level. I first tried to send an email from my email server to a Gmail account I own. I then check my inbox and see that my email bounced back, with the error message: "530 SMTP authentication is required." My guess on how to fix this is to navigate to Settings > Protocols > SMTP > Delivery of e-mail and check the "Server requires authentication" box. Now, my two questions are as follows: (1) What exact details do I need to enter to enable SMTP Authentication, and also (2) Am I missing any other steps to make my email server compliant so I can send emails from my own server to my Gmail account?
Your help would be gladly appreciated.
Thank you!
johang
Re: SMTP Relayer Authentication Setup
Post by johang » 2020-07-24 00:12
Pertzis wrote:
2020-07-23 21:18
Hello everyone,
Thank you!
you have unfortunately missunderstood .. something is already asking for authentication .. youre guess is towards enabling it "again" not resolving that you dont authenticate
with more info regarding your problem you get better help ... what server is saying "530 SMTP authentication is required." yours ? the relay servers ? Gmails ?
do this..
https://www.hmailserver.com/forum/viewt ... 20&t=30914
post in this thread ..
and post what is in your SMTP log ( at least TCP/IP and SMT enabled )
ean post from error log if there is something in there ,..
Pertzis
Post by Pertzis » 2020-07-24 13:01
Thank you for your response.
I ran the VBS Script on my computer, as well as enabling logging for my SMTP. I have attached both logs.
The "530 SMTP authentication is required" error came from the Gmail server. My guess is that my SMTP Server isn't authenticating at all, if that's even possible.
I am also using a DDNS, which I know is a bad idea, but I am just using it for testing, and I don't plan to use this as my main option, although I don't know if this is causing any problems.
Here are my 2 logs which I have pasted in:
HMSDiagnostic_202007241345.txt
2020-07-24   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - aaxxxxxx.ddxx.net              Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                  !! POINTS TO LOCAL DOMAIN !! Disc. on invalid:  False  Delivered-To hdr: False
                     Port: 587                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Error:    E:\.Servers\hMailServer\Logs\ERROR_hmailserver_2020-07-24.log
    Event:    E:\.Servers\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  E:\.Servers\hMailServer\Logs\hmailserver_awstats.log
SYSTEM TESTS
Database type: MySQL
HMAILSERVER.INI
Program folder:  E:\.Servers\hMailServer\
Database folder:
Data folder:     E:\.Servers\hMailServer\Data
Log folder:      E:\.Servers\hMailServer\Logs
Temp folder:     E:\.Servers\hMailServer\Temp
Event folder:    E:\.Servers\hMailServer\Events
Type=              MYSQL
Username=          hMailServer
Port=              3306
Server=            localhost
Internal=          0
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
"SMTPD"	7696	202	"2020-07-24 13:48:10.627"	"127.0.0.1"	"SENT: 220 xxxxxxxx.ddns.net ESMTP"
"SMTPD"	12828	202	"2020-07-24 13:48:10.642"	"127.0.0.1"	"RECEIVED: EHLO localhost"
"SMTPD"	12828	202	"2020-07-24 13:48:10.642"	"127.0.0.1"	"SENT: 250-xxxxxxxx.ddns.net[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	16604	202	"2020-07-24 13:48:10.643"	"127.0.0.1"	"RECEIVED: AUTH LOGIN"
"SMTPD"	16604	202	"2020-07-24 13:48:10.643"	"127.0.0.1"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	7696	202	"2020-07-24 13:48:10.644"	"127.0.0.1"	"RECEIVED: cGV0ZXIuZ2lhbWFsYWtpc0BhYS1ncm91cC5kZG5zLm5ldA=="
"SMTPD"	7696	202	"2020-07-24 13:48:10.644"	"127.0.0.1"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	16604	202	"2020-07-24 13:48:10.644"	"127.0.0.1"	"RECEIVED: ***"
"SMTPD"	16604	202	"2020-07-24 13:48:10.645"	"127.0.0.1"	"SENT: 235 authenticated."
"SMTPD"	7696	202	"2020-07-24 13:48:10.646"	"127.0.0.1"	"RECEIVED: MAIL FROM:<xxxxx.xxxxxxxxxx@xxxxxxxx.ddns.net>"
"SMTPD"	7696	202	"2020-07-24 13:48:10.646"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	16604	202	"2020-07-24 13:48:10.646"	"127.0.0.1"	"RECEIVED: RCPT TO:<xxxxxxxxxxx@gmail.com>"
"SMTPD"	16604	202	"2020-07-24 13:48:10.647"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	7696	202	"2020-07-24 13:48:10.648"	"127.0.0.1"	"RECEIVED: DATA"
"SMTPD"	7696	202	"2020-07-24 13:48:10.648"	"127.0.0.1"	"SENT: 354 OK, send."
"SMTPD"	9516	202	"2020-07-24 13:48:10.658"	"127.0.0.1"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	7696	202	"2020-07-24 13:48:10.659"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	7696	202	"2020-07-24 13:48:10.659"	"127.0.0.1"	"SENT: 221 goodbye"
"SMTPD"	7696	221	"2020-07-24 13:48:10.726"	"94.64.87.168"	"SENT: 220 xxxxxxxx.ddns.net ESMTP"
"SMTPC"	16604	222	"2020-07-24 13:48:10.730"	"94.64.87.168"	"RECEIVED: 220 xxxxxxxx.ddns.net ESMTP"
"SMTPC"	16604	222	"2020-07-24 13:48:10.730"	"94.64.87.168"	"SENT: HELO xxxxxxxx.ddns.net"
"SMTPD"	7696	221	"2020-07-24 13:48:10.732"	"94.64.87.168"	"RECEIVED: HELO xxxxxxxx.ddns.net"
"SMTPD"	7696	221	"2020-07-24 13:48:10.732"	"94.64.87.168"	"SENT: 250 Hello."
"SMTPC"	7696	222	"2020-07-24 13:48:10.739"	"94.64.87.168"	"RECEIVED: 250 Hello."
"SMTPC"	7696	222	"2020-07-24 13:48:10.739"	"94.64.87.168"	"SENT: MAIL FROM:<xxxxx.xxxxxxxxxx@xxxxxxxx.ddns.net>"
"SMTPD"	16604	221	"2020-07-24 13:48:10.741"	"94.64.87.168"	"RECEIVED: MAIL FROM:<xxxxx.xxxxxxxxxx@xxxxxxxx.ddns.net>"
"SMTPD"	16604	221	"2020-07-24 13:48:10.741"	"94.64.87.168"	"SENT: 250 OK"
"SMTPC"	12828	222	"2020-07-24 13:48:10.745"	"94.64.87.168"	"RECEIVED: 250 OK"
"SMTPC"	12828	222	"2020-07-24 13:48:10.745"	"94.64.87.168"	"SENT: RCPT TO:<xxxxxxxxxxx@gmail.com>"
"SMTPD"	7696	221	"2020-07-24 13:48:10.747"	"94.64.87.168"	"RECEIVED: RCPT TO:<xxxxxxxxxxx@gmail.com>"
"SMTPD"	7696	221	"2020-07-24 13:48:10.747"	"94.64.87.168"	"SENT: 530 SMTP authentication is required."
"SMTPC"	7696	222	"2020-07-24 13:48:10.752"	"94.64.87.168"	"RECEIVED: 530 SMTP authentication is required."
"SMTPC"	7696	222	"2020-07-24 13:48:10.752"	"94.64.87.168"	"SENT: QUIT"
"SMTPD"	12828	221	"2020-07-24 13:48:10.755"	"94.64.87.168"	"RECEIVED: QUIT"
"SMTPD"	12828	221	"2020-07-24 13:48:10.755"	"94.64.87.168"	"SENT: 221 goodbye"
"SMTPC"	16604	222	"2020-07-24 13:48:10.758"	"94.64.87.168"	"RECEIVED: 221 goodbye"
johang
Post by johang » 2020-07-24 13:35
Pertzis wrote:
2020-07-24 13:01
first your local client on 127.0.0.1, authenticates into your mailserver 127.0.0.1 and "sends mail" into your mailserver
then you mailserver adresses itself on outside IP 94.64.87.168 trying to send email supposingly to google but connected to itself ?
( and to do that your mailserver asks (itself) for authentication to deliver to external part )
oh my oh my...
have you somewhere added an "record" ( in hosts file, own dns or similar ) that your own mailserver uses to "reach gmail" have you in your firewall som kind of quirk setup to send mail "back into itself" port 25 -> always send traffic to: "internal net, ip of mailserver"
suggestion: check external firewall so the settings are correct... if that is not the problem look into NAME resolution
Pertzis
Post by Pertzis » 2020-07-24 14:40
I think I found the problem. My SMTP Relayer settings are wrong.
At first, for the SMTP Relayer, I tried to log in using an account from my email server. I thought these were the correct details to write in there. However that didn't work, as it sent emails back to myself.
I then tried to switch my SMTP Relayer settings. I made my settings correspond to my 2nd gmail account, and surprisingly, the email sent without problems. However, I received the email on my personal account with the sender's name being the one account I used to login to the SMTP Relayer.
My question now is with what details do I need to "login" to the SMTP Relayer so my email server account can be shown when I send emails????
johang
Post by johang » 2020-07-24 18:13
i would suggest reading this.. all the way to the end .. to understand ..
https://www.digitalocean.com/community/ ... mtp-server
Post by jimimaseye » 2020-07-24 19:14
Search your diagnostic report for that string - you will see the problem.
Pertzis
Post by Pertzis » 2020-07-24 21:07
johang wrote:
2020-07-24 18:13
Thank you for your help.
I read the article you sent, it helped me alot. However I have another problem. I have set my SMTP Relay with the Gmail SMTP server and it works, but when I try to "Add another email address I own" on Gmail, it can't connect to my SMTP server. I have added exceptions in my firewall, as well as port forwarding. Am I missing something?
johang
Post by johang » 2020-07-26 00:04
Pertzis wrote:
2020-07-24 21:07
johang wrote:
2020-07-24 18:13
I have not used Gmail services like that so i might not be the right person to respond to that question ( i have no clue where or what you are reffering to in their system )
but i guess...
for Gmail to "pose" as you .. there has to be services working.. ( Gmail wont let you just make up a mail-domain or use someone elses .. )
so you bought a domain, you have configured DNS and pointed mx to your mail server so Gmail knows IP wise how to connect to your SMTP server ?
and your ISP lets traffic in on port 25 to your server ? ( im just guessing Gmail would come in on port 25, or do they IMAP connect or something, has to say in their interface .. ?? ) and you have checked that your local server is reachable from the internet on all services needed ? ( check via https://mxtoolbox.com/ )
Post by mattg » 2020-07-26 12:51
To clarify, you are trying to SMTP forward to gMail using multiple gMail accounts, is that correct?
If so
Pertzis wrote:
2020-07-24 21:07
...but when I try to "Add another email address I own" on Gmail, it can't connect to my SMTP server.
Use routes + global rules
