Gmail relay and connect to hmailserver not working?
markm75
Post by markm75 » 2020-07-26 21:43
I have the hmail server on a windows 10 machine as the main install.
I wasnt sure what to put for domain, so i just called the domain "localhost"
Under settings smtp protocols i have the relay info for smtp.gmail.com and the generated password here.
Doing an email test within the server application seems to connect ok to smtp.gmail.com on 587
Under advanced tcp ip smtp ports, the local ip address is there with port 25 and no password required.
If i go to another machine windows 10 in my network and use for instance acronis notification settings and try to specify my windows 10 hmail server name and port 25 with no security, it never connects.
I've tried by the hmail server ip address as well, no luck there.
Under the domain name info area i have not added any accounts etc, i didnt think this was needed to just allow port 25 to be open and working from this machine address. edit: tried adding an account and then referencing this from the test smtp send machine within acronis, no luck
Under settings advanced, bind to local ip address i have it blank but i tried specifying the windows 10 hmail server ip address with no luck.
Any ideas what im missing here?
Thanks in advance
johang
Re: Gmail relay and connect to hmailserver not working?
Post by johang » 2020-07-26 22:16
markm75 wrote:
2020-07-26 21:43
Thanks in advance
i am not sure i understand .. ( you should not change [settings][advanced][TCP/IP address] ; you should use 0.0.0.0 !!! ) there is no setting for "no password required" there ... what do you mean ?
if you test locally on your win10 PC with hmailserver installed, can you telnet to port 25 locally ?
and
have you opened your local firewall on your win10 computer to accept traffic on port 25 for other computers to use ?
and if what i have written sofar is not getting you anywhere..
go here https://www.hmailserver.com/forum/viewt ... 20&t=30914 run it and post result here
markm75
Post by markm75 » 2020-07-26 23:07
johang wrote:
2020-07-26 22:16
markm75 wrote:
2020-07-26 21:43
Thanks in advance
and
putting 0.0.0.0 helped slightly.
Now i get error 503 from the other win 10 workstation.
Must have sender and recipient first
On the remote workstation if i try to telnet ie: telnet machinename 25 it connects i think, then snaps back to the command prompt quickly, if i do telnet in the same manner from the actual win 10 hmail server, it says 220 machinename ESMTP and a blank cursor.
I also tried removing the domains to get this far.
Here is the diagnostic output:
2020-07-26   Hmailserver: 5.6.7-B2425
DOMAINS
     (No Domains Entered)
IP RANGES
IP: 127.0.0.7 - 127.0.0.7     Priority: 15     Name: localhost
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 60   Plain Text:        False  Bind: 192.168.0.7
Max Msg Size: 20480  Relay:-                   Incorrect endings:  True  Use STARTTLS:     False
                     Port: 587                                           Loop limit:           5
                     Con. Sec.: StartTLS Required
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-07-26.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-07-26.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
johang
Post by johang » 2020-07-26 23:21
i would recommend you creating a user with a password, and use an email client.
503 Issue a reset if you want to start over
When an email client delivers an email message to an email server, it starts of by telling the server the senders address. After it has done this, a transaction is started which is not finished before the entire message has been delivered to the email server. If the client wishes to abort the transaction and send another message, it should issue the RSET command. If a client, in the middle of a transaction, tries to send a new email without first aborting the current transaction, hMailServer issues this error message. This indicates a bug in the SMTP client.
if you dont want any smtp authenication be sure to uncheck "Require SMTP authenication" in your IPranges that would apply to your particular config-
but acually i recommend that you set up a user and authenicate and see to it that it works..
Post by jimimaseye » 2020-07-26 23:24
Bind: 192.168.0.7
Unless you have 2 nics, get rid f of that.
Also worth no domain setup, every delivery attempt will be external to external - which you have set to require authentication.
Post by mattg » 2020-07-26 23:38
AND
What is the contents of this log file??
markm75
Post by markm75 » 2020-07-27 00:11
2020-07-26 23:38
AND
"ERROR" 6688 "2020-07-26 15:10:55.395" "Severity: 3 (Medium), Code: HM5007, Source: SMTPDeliverer::DeliverMessage(), Description: Message 1 could not be delivered. No remaining recipients.
markm75
Post by markm75 » 2020-07-27 00:15
Adding a domain and specifying that fake domain admin@domainetc.com with password seems to have worked (referencing my hmail machine name for the server).
It would have been nice to not need authentication, but at least this is working now.
Thanks for the assistance all
Post by mattg » 2020-07-27 02:27
To get it to work without an account and domain...
2020-07-26 23:24
Make sure you ONLY enable external to external for for LAN ip range, not the internet IP range or you will be sending spam from around the world very quickly, and then get blacklisted
