Auto ban issues
alexwhite68
Auto ban issues
Post by alexwhite68 » 2020-08-02 12:51
I am having a lot of issues with auto ban, what is going on is my own computers are being banned repeatedly.
Both accounts are on the same server and devices (happening on both iPhones and mac's), what seems to be happening is the authentication fails it retries then works, so it looks (correct me if I am wrong it is failing on one method and retrying on a different type of authentication which then works.
So I recognise 86.131.243.233 that is the public ip address of the broadband that the mac is connected to, the 192.168.1.69 is the dhcp address of the mac.
I have retyped the user name and password of the accounts and they do work e.g. mail does send but eventually the ip range gets banned almost certainly due to the authentication failed messages.
I need the auto ban on as I am having issues with people trying to relay through my server.
"SMTPD" 2608 2981 "2020-08-02 12:38:50.795" "86.131.243.233" "SENT: 220 mail.t**** ESMTP"
"SMTPD" 22872 2981 "2020-08-02 12:38:50.852" "86.131.243.233" "RECEIVED: EHLO [192.168.1.69]"
"SMTPD" 22872 2981 "2020-08-02 12:38:50.856" "86.131.243.233" "SENT: 250-mail.t****[nl]250-SIZE 102400000[nl]250-STARTTLS[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 22872 2981 "2020-08-02 12:38:50.903" "86.131.243.233" "RECEIVED: STARTTLS"
"SMTPD" 22872 2981 "2020-08-02 12:38:50.907" "86.131.243.233" "SENT: 220 Ready to start TLS"
"SMTPD" 22872 2981 "2020-08-02 12:38:51.215" "86.131.243.233" "RECEIVED: EHLO [192.168.1.69]"
"SMTPD" 22872 2981 "2020-08-02 12:38:51.219" "86.131.243.233" "SENT: 250-mail.t****[nl]250-SIZE 102400000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 2608 2981 "2020-08-02 12:38:51.268" "86.131.243.233" "RECEIVED: AUTH PLAIN YWRtaW5AMmRvLWdpYi5naQBhZG1pbkAyZG8tZ2liLmdpAEJhbGw4cmRzR3IzZW42Nw=="
"SMTPD" 2608 2981 "2020-08-02 12:38:51.288" "86.131.243.233" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 12448 2981 "2020-08-02 12:38:51.334" "86.131.243.233" "RECEIVED: AUTH PLAIN AGFkbWluQDJkby1naWIuZ2kAQmFsbDhyZHNHcjNlbjY3"
"SMTPD" 12448 2981 "2020-08-02 12:38:51.342" "86.131.243.233" "SENT: 235 authenticated."
"SMTPD" 22872 2981 "2020-08-02 12:38:51.390" "86.131.243.233" "RECEIVED: MAIL FROM:<a********>"
"SMTPD" 22872 2981 "2020-08-02 12:38:51.399" "86.131.243.233" "SENT: 250 OK"
"SMTPD" 22872 2981 "2020-08-02 12:38:51.447" "86.131.243.233" "RECEIVED: RCPT TO:<***@ta***>"
"SMTPD" 22872 2981 "2020-08-02 12:38:51.452" "86.131.243.233" "SENT: 250 OK"
"SMTPD" 2608 2981 "2020-08-02 12:38:51.513" "86.131.243.233" "RECEIVED: DATA"
"SMTPD" 2608 2981 "2020-08-02 12:38:51.519" "86.131.243.233" "SENT: 354 OK, send."
"SMTPD" 10956 2981 "2020-08-02 12:38:51.598" "86.131.243.233" "SENT: 250 Queued (0.064 seconds)"
2020-08-02   Hmailserver: 5.6.8-B2494
DOMAINS
   "Domain1.com" - 2dxxxxx.gi                     Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: admin@Domain1.com
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - alxxxxxxxx.uk                  Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: email@Domain2.com
                   Max message size:        0                      Plus addressing:  True
                   Max size of accounts:    0                      Character:
        Greylisting:     False
   "Domain3.com" - taxxxxxx.co.uk                 Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: alex.white@Domain3.com
        Greylisting:      True
IP RANGES
     External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain3.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
                              Minutes Before Reset:           20  (0.33 hours, 0.01 days)
There is a total of 21 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  3 Mins: 60   Plain Text:         True  Bind:
                     Host: EXTERNAL.TLD        Empty sender:      False  Batch recipients:   100
Max Msg Size:102400  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Spam:    False    Check HELO host:    True - 2
  Add X-HmailServer-Reason:  False    Check MX records:   True - 2
DNSBL ENTRIES:
SURBL ENTRIES:
   No 'enabled' entries
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: False
Greylist WHITELIST ENTRIES:
   No entries
Greylist DOMAINS enabled:
           Domain3.com
WHITELISTING
              86.131.243.233     to    86.131.243.233
  Block Attachments: False
SSL CERTIFICATES
   certs
       Certificate: D:\Certificates\SAN\mail.Domain3.com-chain.pem
       Private key: D:\Certificates\SAN\mail.Domain3.com-key.pem
SSL/TLS
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True
             TLS 1.3 :   True                Verify Remote SSL/TLS Certs:   True
SslCipherList  :
               192.168.1.2     / 25    / SMTP   -   StartTLS Optional   Cert: certs
               192.168.1.2     / 110   / POP3   -   StartTLS Optional   Cert: certs
               192.168.1.2     / 143   / IMAP   -   StartTLS Optional   Cert: certs
               192.168.1.2     / 465   / SMTP   -   SSL/TLS             Cert: certs
               192.168.1.2     / 587   / SMTP   -   StartTLS Optional   Cert: certs
               192.168.1.2     / 993   / IMAP   -   SSL/TLS             Cert: certs
               192.168.1.2     / 995   / POP3   -   SSL/TLS             Cert: certs
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-08-02.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-08-02.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL
Backup directory D:\SQLBackup is writable.
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=          sa
Port=              0
Server=            mail
Internal=          0
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
thank you.
johang
Re: Auto ban issues
Post by johang » 2020-08-02 19:33
i think your problem is that you do not "Require SMTP authentication"
you should change in your Internet IP range to Require SMTP authentication for
Local to local e-mail addresses
Local to external e-mail addresses
External to External e-mail addresses
and you can add an ip range for the IP of your mac and give it special priviligies if you want ( like setting priority 25 on it so even though it gets listed as banned it will ignore it ) ..
johang
Re: Auto ban issues
Post by johang » 2020-08-02 20:45
and it is always intereasting whats inside
jim.bus
Re: Auto ban issues
Post by jim.bus » 2020-08-03 01:52
You should also try upgrading to B2501.
Personally I only use the latest stable build 5.6.7-B2425 and have not upgraded to 5.6.8. However, from posts I have read 5.6.8-B2501 is in Beta now and apparently has little problems. You are using presumably a less reliable Build, 5.6.8-B2494 when B2501 is the current released Beta on the Download tab of hMailServer.com.
I, also, don't understand why you are listening on only a specific IP Address 182.168.2.1 in your TCP/IP Ports settings. I would have thought hMailServer wouldn't even have registered a connection from your MAC with these TCP/IP Ports settings. Your TCP/IP Ports should show IP Address 0.0.0.0 which will allow hMailServer to listen on all ports.
You should also for TCP/IP Ports to require Encryption on Ports, 465, 587, 993, and 995. Ports 110 and 995 if you are going to use Encryption, probably SSL/TLS would be better as some Clients like Outlook don't support StartTLS for these Ports. My experience so far is that StarTLS might be better for the other Ports you would want to Encrypt.
You also have specified a Default Domain which is not thought to be wise as it allows a hacker to try to guess your email ID without having to worry about also guessing the Domain. You should just not specify any Default Domain. You don't need it is my experience.
Re: Auto ban issues
Post by mattg » 2020-08-03 05:04
johang wrote:
2020-08-02 20:45
The way that this diagnostics works, that file doesn't exist, unless it says 'contains errors' after the file name
jim.bus wrote:
2020-08-03 01:52
Yes, these should be 0.0.0.0 in most cases
Re: Auto ban issues
Post by jimimaseye » 2020-08-03 09:30
alexwhite68 wrote:
2020-08-02 12:51
You don't help with your settings. You have 'local to local' and 'local to external' deliveries not requiring authentication. And also a default domain set.
Thats an invite for spambots.
jim.bus
Re: Auto ban issues
Post by jim.bus » 2020-08-03 10:42
You might want to specify in your IP Ranges 'Require SSL/TLS for authentication'. This is the Default setting and will require Logins to use SSL/TLS for authentication. It looked like your Diagnostics Report was indicating you don't have this option specified.
alexwhite68
Re: Auto ban issues
Post by alexwhite68 » 2020-08-04 15:40
Thanks for all the replies I will reply in one message rather than lots of little messages.
johang
after posting I made a couple those changes you suggested I also switched off external to external, that looks like trouble leaving that on.
jim.bus
The specific ip of 192.168.1.2 was a hangover from old config where I had several ip addresses because I had different stuff listening to different things on those ports, that config was changed a while back so not needed anymore so now changed 0.0.0.0
removed the default domain
got it all working again, hotmail banned me for a while but it's back on now, interesting they only put me back on once my reverse dns for my static ip matched FQDN for my mail server.
Thanks again :D
Re: Auto ban issues
Post by jimimaseye » 2020-08-04 16:56
alexwhite68 wrote:
2020-08-04 15:40
did you sort the 'local to local' and 'local to external' deliveries not requiring authentication as well?
jim.bus
Re: Auto ban issues
Post by jim.bus » 2020-08-04 21:24
alexwhite68 wrote:
2020-08-04 15:40
Thanks again :D
That's what reverse DNS is used for. Not matching is a sign of an unauthorized access.
Re: Auto ban issues
Post by SorenR » 2020-08-04 22:13
jim.bus wrote:
2020-08-04 21:24
alexwhite68 wrote:
2020-08-04 15:40
Thanks again :D
It's a sign of a potential problem, RFC does NOT say REJECT if not FcrDNS.
Anyways, I'm thinking of changing my DNS MX records as my server lost FcrDNS when I switched ISP... This way I can regain FcrDNS
hMailServer: Protocol SMTP Local host name: 123.123.123.123.broadband.isp.tld (NO Welcome message!)
DNS: mydomain.tld
mydomain.tld   A      123.123.123.123
mydomain.tld   MX  10 123.123.123.123.broadband.isp.tld  <== PTR exists and is a match.
Problem is that some admins like @Palinka have rules to reject HELO/EHLO greetings containing IP addresses. It IS a valid greeting re. RFC but can be identified as a generic SPAM source
Re: Auto ban issues
Post by palinka » 2020-08-05 01:32
2020-08-04 22:13
I'd never firewall ban you, my man!
But yeah, greetings containing IPs are generally bots using rdns hostname for the greeting.
I had a few false positives, like stoopid facebook. But by few, I mean VERY FEW. Therefore, the miniscule number of false positives tells me that its working and also that using an ISP supplied rdns hostname is probably not a good idea.
