Exception with Interop.hMailServer COM API on .net core 3.1
naren
Post by naren » 2020-08-07 07:50
I am getting below exception when using Interop.hMailServer on .net core 3.1
First i got below error when my platform is "Any CPU" or x64,
BadImageFormatException: Could not load file or assembly 'Interop.hMailServer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. An attempt was made to load a program with an incorrect format.
Then i changed platform target to x86, and now i am getting below error.
COMException: Retrieving the COM class factory for component with CLSID {D6567EF8-0A6C-48E7-9288-A2463123C2F3} failed due to the following error: 80040154 Class not registered (0x80040154 (REGDB_E_CLASSNOTREG)).
I am using x64 based windows 10 machine and hMailServer 5.6.8 - Build 2431
Does anyone know how to fix this issue ?
Re: Exception with Interop.hMailServer COM API on .net core 3.1
Post by mattg » 2020-08-07 09:36
What dot net versions do you have installed?
Add windows features, add Dot Net 3.5 (if not already done) and see if that fixes the issue
naren
Post by naren » 2020-08-09 06:32
I added Dot Net 3.5, but still not working. Let me do more troubleshooting
