Display number of emails pending in each account?
- New user
I just installed hMailServer and got it working. Is there any way to display the number of emails available for reading in each account? I was previously using CMailServer, which displayed a GUI table with an entry for each account that indicated (among other things) the account name, the user name, and the number of emails available for reading. That table was handy for getting a general idea of what was going on.
Thanks!
Thanks!
Re: Display number of emails pending in each account?
it is not presented in the gui.BenevolentDeity wrote: ↑2020-10-05 14:18Hello,
Thanks!
you can just go into your hmailserver Data folder where all domains reside, and via file explorer right click on a user choosing "properties" and read how many files a user has in their dir..
shouldnt be to hard to bat script something to put up as a report for a script knowledgeable person, but if you want it live to see if someones inbox is filling up in realtime someone have to do a good hack i guess
Do you mean unread mail?BenevolentDeity wrote: ↑2020-10-05 14:18Is there any way to display the number of emails available for reading in each account?
- jimimaseye
- Moderator
There are these that you might find useful starters:
https://www.hmailserver.com/forum/viewt ... 20&t=28052
https://www.hmailserver.com/forum/viewt ... 20&t=35156
A bit of tailoring to look at message flags and you can get filter it to how you like.
I think perhaps the OP is talking about POP3 accounts, not IMAP
This works. It takes a long time to loop through every message. I think on any but the smallest servers, it will run into execution timeouts. But it does work
Is there a way to count unread messages instead of looping through them?
Counts unread messages for every active user.
PHP:
Probably better to do this by some other script and just have the results emailed. I did it in PHP because I thought it would be refresh, bang, results.
Edit - many thanks to Jimi's email cleardown script for help with the COM stuff.
PHP:
<?php
$hMSAdminPass = "supersecretpassword";
$hMS = new COM("hMailServer.Application");
$hMS->Authenticate("Administrator", $hMSAdminPass);
echo "Unread Messages <br><br>";
echo "<table>";
for ($i = 0; $i < ($hMS->Domains->Count); $i++) {
$hMSDomain = $hMS->Domains->Item($i);
if ($hMSDomain->Active){
for ($j = 0; $j < ($hMSDomain->Accounts->Count); $j++) {
$hMSAccount = $hMSDomain->Accounts->Item($j);
if ($hMSAccount->Active) {
echo "<tr><td>".$hMSAccount->Address."</td>";
$l = 0;
for ($m = 0; $m < ($hMSAccount->IMAPFolders->ItemByName('INBOX')->Messages->Count); $m++) {
$hMSMessage = $hMSAccount->IMAPFolders->ItemByName('INBOX')->Messages->Item($m);
If ($hMSMessage->Flag(1)) {$l++;}
echo "<td>".($hMSAccount->IMAPFolders->ItemByName('INBOX')->Messages->Count - $l)."</td></tr>";
echo "</table>";
i think the cmailserver interface spoken of is this ( i might be wrong )
Just toying around now. Here's one to display message count for every folder.
I assume this would work for POP just as easily, although IMAP must be enabled (I think) in order to get the counts. I don't see POP anywhere in the COM documentation.
This counts the messages in each folder for each account. If the userbase were using POP exclusively, then only the INBOX would show up. The output is like below:
The first two are accounts for automated messages. The second one only has an INBOX because no one has ever logged in. Its just for sending. I assume this is how a POP only account would appear.
The first account is also an automated sending account, but one time I logged in via webmail and the webmail client created the folders automatically. Otherwise, there would only be an INBOX.
The third account is an actual user with user-created folders.
This one is very fast because it doesn't loop through each message.
PHP:
I like PHP because you just pull it up on a browser for real time information.
battery@mydomain.tld INBOX 0
Sent 0
Drafts 0
Spam 0
Trash 0
Archive 0
TOTAL MESSAGES: 0
brother-mfc@mydomain.tld INBOX 0
TOTAL MESSAGES: 0
actualuser@mydomain.tld INBOX 2450
Trash 3
Sent 855
Drafts 0
Archive 0
Spam 1
Bank 41
Dingbat 41
Junk E-mail 3
TOTAL MESSAGES: 3394
PHP:
<?php
echo "All Messages <br><br>";
echo "<table>";
$totalCount = 0;
for ($k = 0; $k < ($hMSAccount->IMAPFolders->Count); $k++) {
$hMSIMAPFolder = $hMSAccount->IMAPFolders->Item($k);
$totalCount += $hMSIMAPFolder->Messages->Count;
if ($hMSIMAPFolder->Name == "INBOX"){
echo "<tr><td>".$hMSAccount->Address."</td><td>".$hMSIMAPFolder->Name."</td><td style='text-align:right;'>".number_format($hMSIMAPFolder->Messages->Count)."</td></tr>";
} else {
echo "<tr><td></td><td>".$hMSIMAPFolder->Name."</td><td style='text-align:right;'>".number_format($hMSIMAPFolder->Messages->Count)."</td></tr>";
echo "<tr style='font-weight:bold;'><td></td><td>TOTAL MESSAGES:</td><td style='text-align:right;'>".number_format($totalCount)."</td></tr>";
echo "<tr><td colspan='3'><hr></td></td></tr>";
echo "</table>";
SELECT COUNT(hm_messages.messageid)
FROM hm_messages
INNER JOIN hm_accounts ON hm_messages.messageaccountid = hm_accounts.accountid
WHERE hm_accounts.accountaddress = 'wile.e.coyote@acme.inc' AND RIGHT(BIN(hm_messages.messageflags),1) = '0';
Beeyooteefool! I'll push out an update tonight.SorenR wrote: ↑2020-10-06 21:42You are welccome...Code: Select all
SELECT COUNT(hm_messages.messageid) FROM hm_messages INNER JOIN hm_accounts ON hm_messages.messageaccountid = hm_accounts.accountid WHERE hm_accounts.accountaddress = 'wile.e.coyote@acme.inc' AND RIGHT(BIN(hm_messages.messageflags),1) = '0';
I'm tired in my head and soon off to bed so I won't add any more to this but (!) you should be able to create a query that will list all accounts in a domain and their number of unread messages in one go ...palinka wrote: ↑2020-10-06 21:58Beeyooteefool! I'll push out an update tonight.SorenR wrote: ↑2020-10-06 21:42You are welccome...Code: Select all
That's probably true, but it was way easier to recycle! I recycle everything.SorenR wrote: ↑2020-10-06 22:02I'm tired in my head and soon off to bed so I won't add any more to this but (!) you should be able to create a query that will list all accounts in a domain and their number of unread messages in one go ...palinka wrote: ↑2020-10-06 21:58Beeyooteefool! I'll push out an update tonight.SorenR wrote: ↑2020-10-06 21:42You are welccome...Code: Select all
Also, the COM script cycles through all accounts on all domains, so you get a result for every ACTIVE account in one simple page.
Muuuuuuuccchhhhhhh FASTER than before... Thank ye kindly.
PHP:
<?php
/* Database Variables
'dbtype' = database server type
For MySQL use dbtype = 'mysql'
For MSSQL use dbtype = 'mssql'
'driver' = connection type
For MySQL use driver = 'mysql'
For MSSQL use driver = 'mssql'
For ODBC use driver = 'odbc'
* When opting for ODBC use correct DSN! *
* Example: "MariaDB ODBC 3.0 Driver" *
* Exact spelling is critical! *
$Database = array (
'dbtype' => 'mysql',
'host' => 'localhost',
'username' => 'hmailserver',
'password' => 'supersecretpassword',
'dbname' => 'hmailserver',
'driver' => 'mysql',
'port' => '3306',
'dsn' => 'MariaDB ODBC 3.0 Driver'
/* hMailServer COM Authentication
Password for hMailServer "Administrator"
If ($Database['driver'] == 'mysql') {
$pdo = new PDO("mysql:host=".$Database['host'].";port=".$Database['port'].";dbname=".$Database['dbname'], $Database['username'], $Database['password']);
} ElseIf ($Database['driver'] == 'mssql') {
$pdo = new PDO("sqlsrv:Server=".$Database['host'].",".$Database['port'].";Database=".$Database['dbname'], $Database['username'], $Database['password']);
} ElseIf ($Database['driver'] == 'odbc') {
$pdo = new PDO("odbc:Driver={".$Database['dsn']."};Server=".$Database['host'].";Port=".$Database['port'].";Database=".$Database['dbname'].";User=".$Database['username'].";Password=".$Database['password'].";");
} Else {
echo "Configuration Error - No database driver specified";
echo "<table>";
$sql = $pdo->prepare("
SELECT COUNT(hm_messages.messageid) AS unread
FROM hm_messages
WHERE hm_accounts.accountaddress = '".$hMSAccount->Address."' AND RIGHT(BIN(hm_messages.messageflags),1) = '0';
$sql->execute();
$unread = $sql->fetchColumn();
echo "<td>".$unread."</td></tr>";
echo "</table>";
SELECT hm_accounts.accountaddress, COUNT(*)
FROM hm_messages
WHERE RIGHT(BIN(hm_messages.messageflags),1) = '0'
GROUP BY hm_accounts.accountaddress;
BUT ! You only need to run one SQL query so it should be faster
Perfection. Anyway, what's the point of looking at accounts with NO unread messages if your goal is to look at accounts WITH unread messages?SorenR wrote: ↑2020-10-06 23:01OK, it will ONLY list accounts with unread messages...Code: Select all
SELECT hm_accounts.accountaddress, COUNT(*) FROM hm_messages INNER JOIN hm_accounts ON hm_messages.messageaccountid = hm_accounts.accountid WHERE RIGHT(BIN(hm_messages.messageflags),1) = '0' GROUP BY hm_accounts.accountaddress;
BUT ! You only need to run one SQL query so it should be faster![]()
This greatly simplifies things.
<?php
$Database = array (
'port' => '3306',
} Else {
echo "<table>";
SELECT hm_accounts.accountaddress AS address, COUNT(*) AS countunread
FROM hm_messages
$sql->execute();
while($row = $sql->fetch(PDO::FETCH_ASSOC)){
echo "<tr><td>".$row['address']."</td><td style='text-align:right;'>".number_format($row['countunread'])."</td></tr>";
echo "</table>";
Found one minor flaw. Your all in one query outputs in alphabetical order by address, instead of by domain, then by address. Its not really a flaw, just a nitpick. Using the COM with your first query, and then using if unread > 0, puts them back into orderly fashion, without the no-unread accounts.
palinka wrote: ↑2020-10-06 23:32Found one minor flaw. Your all in one query outputs in alphabetical order by address, instead of by domain, then by address. Its not really a flaw, just a nitpick. Using the COM with your first query, and then using if unread > 0, puts them back into orderly fashion, without the no-unread accounts.![]()
SELECT hm_accounts.accountaddress,COUNT(*)
FROM hm_messages
ORDER BY SUBSTRING_INDEX(hm_accounts.accountaddress, "@", -1)
Haha! That's great, man! Crowd sourcing is awesome!tunis wrote: ↑2020-10-07 13:30Code: Select all
SELECT hm_accounts.accountaddress,COUNT(*) FROM hm_messages INNER JOIN hm_accounts ON hm_messages.messageaccountid = hm_accounts.accountid WHERE RIGHT(BIN(hm_messages.messageflags),1) = '0' GROUP BY hm_accounts.accountaddress ORDER BY SUBSTRING_INDEX(hm_accounts.accountaddress, "@", -1)
I made one small modification.tunis wrote: ↑2020-10-07 13:30Code: Select all
WHERE RIGHT(BIN(hm_messages.messageflags),1) = '0' AND accountactive = '1'
So only active accounts are displayed. I think we can put a fork in this one!
Final Version: PHP (MySQL only, also enabled mobile viewport):
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
</head>
<body style="font-family:Verdana;">
<?php
$Database = array (
'port' => '3306'
echo "<table>";
FROM hm_messages
ORDER BY SUBSTRING_INDEX(hm_accounts.accountaddress, '@', -1)
$sql->execute();
echo "</table>";
</body>
</html>
