Using hMail as SMTP Relay for Scanners
lance.peterson
Post by lance.peterson » 2020-10-08 16:57
We had an inhouse Email Security Gateway that we took to the cloud. So our internal copiers pointed there, now that it's gone I'm hoping to use a simple hMail for that purpose. When I point the copier to it the logs indicate it doesn't see the account, which I haven't put all the accounts in it as I just want to relay off hMail. Anyone know how to set this up appropriately. I haven't been able to find any documentation on this on the website.
Re: Using hMail as SMTP Relay for Scanners
Post by jimimaseye » 2020-10-08 17:50
Without a Domain:
Delete INTERNET ip range.
Create new IP RANE for the IP ADDRESS of your internal printer
Set allow EXTERNAL to EXTERNAL Deliveries
OR
With a Domain:
create an authenticating account (eg, Authenticate@yourdomain.com )
use this address as the authentication account in your printer.
Create new IP RANGE for the IP ADDRESS of your internal printer
Set allow LOCAL to EXTERNAL Deliveries with Authentication (disable all other options)
lance.peterson
Post by lance.peterson » 2020-10-08 18:49
Ok so I attempted to do this without a domain. Attached are the screenshots. Do they look correct?
Here is what the logs say.
"SMTPD" 3124 18 "2020-10-08 11:42:05.236" "172.16.6.57" "SENT: 220 co.XXXX.XXX.XXX ESMTP"
"SMTPD" 3828 18 "2020-10-08 11:42:05.236" "172.16.6.57" "RECEIVED: HELO RODMULTI"
"SMTPD" 3828 18 "2020-10-08 11:42:05.236" "172.16.6.57" "SENT: 250 Hello."
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "RECEIVED: MAIL FROM:<copier@co.XXX.XX.XX>"
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "SENT: 250 OK"
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "RECEIVED: RCPT TO:<firstname.lastname@co.XX.XX.XX>"
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "SENT: 530 SMTP authentication is required."
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "RECEIVED: QUIT"
"SMTPD" 5748 18 "2020-10-08 11:42:05.252" "172.16.6.57" "SENT: 221 goodbye"
Post by palinka » 2020-10-08 19:17
Uncheck "external to external email addresses" under "require smtp authentication".
lance.peterson
Post by lance.peterson » 2020-10-08 19:47
I no longer get the error message but now it's in the delivery queue and doesn't appear to want to go anywhere. See attachment.
johang
Post by johang » 2020-10-08 20:42
lance.peterson wrote:
2020-10-08 19:47
what do your log say ( add everything to log TCP/IP SMTP DEBUG APPLICATION ) and try again
lance.peterson
Post by lance.peterson » 2020-10-08 20:57
"DEBUG" 3124 "2020-10-08 13:52:33.449" "Creating session 29"
"TCPIP" 3124 "2020-10-08 13:52:33.449" "TCP - 172.16.X.57 connected to 172.16.X.48:25."
"DEBUG" 3124 "2020-10-08 13:52:33.449" "TCP connection started for session 22"
"SMTPD" 3124 22 "2020-10-08 13:52:33.465" "172.16.x.57" "SENT: 220 co.XX.xx.xx ESMTP"
"SMTPD" 3124 22 "2020-10-08 13:52:33.481" "172.16.x.57" "RECEIVED: HELO RODMULTI"
"SMTPD" 3124 22 "2020-10-08 13:52:33.481" "172.16.x.57" "SENT: 250 Hello."
"SMTPD" 5748 22 "2020-10-08 13:52:33.496" "172.16.x.57" "RECEIVED: MAIL FROM:<x@co.x.x.x>"
"SMTPD" 5748 22 "2020-10-08 13:52:33.512" "172.16.x.57" "SENT: 250 OK"
"SMTPD" 3124 22 "2020-10-08 13:52:33.512" "172.16.x.57" "RECEIVED: RCPT TO:<x.x@co.xx.x.x>"
"SMTPD" 3124 22 "2020-10-08 13:52:33.527" "172.16.x.57" "SENT: 250 OK"
"SMTPD" 2168 22 "2020-10-08 13:52:33.543" "172.16.x.57" "RECEIVED: RCPT TO:<x.x@co.x.x.x>"
"SMTPD" 2168 22 "2020-10-08 13:52:33.543" "172.16.x.57" "SENT: 250 OK"
"SMTPD" 2788 22 "2020-10-08 13:52:33.559" "172.16.x.57" "RECEIVED: DATA"
"SMTPD" 2788 22 "2020-10-08 13:52:33.559" "172.16.x.57" "SENT: 354 OK, send."
"DEBUG" 2788 "2020-10-08 13:52:34.508" "Could not retrieve PTR record for IP (false)! 172.16.x.57"
"DEBUG" 2788 "2020-10-08 13:52:34.508" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 512 "2020-10-08 13:52:34.508" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 512 "2020-10-08 13:52:34.508" "Saving message: {F5164411-9249-431A-8742-8E6C6B1A85E1}.eml"
"DEBUG" 512 "2020-10-08 13:52:34.508" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 512 22 "2020-10-08 13:52:34.508" "172.16.x.57" "SENT: 250 Queued (0.928 seconds)"
"DEBUG" 2412 "2020-10-08 13:52:34.524" "Adding task DeliveryTask to work queue SMTP delivery queue"
"SMTPD" 2168 22 "2020-10-08 13:52:34.524" "172.16.x.57" "RECEIVED: QUIT"
"SMTPD" 2168 22 "2020-10-08 13:52:34.524" "172.16.x.57" "SENT: 221 goodbye"
"DEBUG" 716 "2020-10-08 13:52:34.524" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 716 "2020-10-08 13:52:34.524" "Delivering message..."
"APPLICATION" 716 "2020-10-08 13:52:34.524" "SMTPDeliverer - Message 3: Delivering message from copier@co.x.x.x to x.x@co.x.x.x, x.x@co.xx.x.x. File: C:\Program Files (x86)\hMailServer\Data\{F5164411-9249-431A-8742-8E6C6B1A85E1}.eml"
"DEBUG" 716 "2020-10-08 13:52:34.524" "Applying rules"
"DEBUG" 716 "2020-10-08 13:52:34.524" "Performing local delivery"
"DEBUG" 716 "2020-10-08 13:52:34.524" "Local delivery completed"
"DEBUG" 5748 "2020-10-08 13:52:34.524" "Ending session 22"
"APPLICATION" 716 "2020-10-08 13:52:34.555" "SMTPDeliverer - Message 3: Relaying to host smtp-relay.gmail.com."
"DEBUG" 716 "2020-10-08 13:52:34.555" "Starting external delivery process. Server: smtp-relay.gmail.com (74.125.202.28), Port: 587, Security: 1, User name: copier"
"DEBUG" 716 "2020-10-08 13:52:34.555" "Creating session 30"
"TCPIP" 716 "2020-10-08 13:52:34.555" "Connecting to 74.125.202.28:587..."
"DEBUG" 2788 "2020-10-08 13:52:34.570" "TCP connection started for session 30"
"DEBUG" 2788 "2020-10-08 13:52:34.570" "Performing SSL/TLS handshake for session 30. Verify certificate: True, Expected remote host name: smtp-relay.gmail.com"
"TCPIP" 5748 "2020-10-08 13:52:34.633" "TCPConnection - TLS/SSL handshake failed. Session Id: 30, Remote IP: 74.125.202.28, Error code: 336031996, Message: unknown protocol"
"DEBUG" 5748 "2020-10-08 13:52:34.633" "Ending session 30"
"DEBUG" 716 "2020-10-08 13:52:34.633" "External delivery process completed"
"DEBUG" 716 "2020-10-08 13:52:34.633" "Summarizing delivery result"
"DEBUG" 716 "2020-10-08 13:52:34.649" "Summarized delivery results"
"DEBUG" 716 "2020-10-08 13:52:34.649" "SD::RescheduleDelivery_"
"DEBUG" 716 "2020-10-08 13:52:34.649" "Retrieving retry options."
"DEBUG" 716 "2020-10-08 13:52:34.649" "Starting rescheduling."
"APPLICATION" 716 "2020-10-08 13:52:34.649" "SMTPDeliverer - Message 3: Message could not be delivered. Scheduling it for later delivery in 10 minutes."
"DEBUG" 716 "2020-10-08 13:52:34.649" "PersistentMessage::SetNextTryTime()"
"DEBUG" 716 "2020-10-08 13:52:34.649" "PersistentMessage::~SetNextTryTime()"
"DEBUG" 716 "2020-10-08 13:52:34.649" "Message rescheduled for later delivery."
"APPLICATION" 716 "2020-10-08 13:52:34.649" "SMTPDeliverer - Message 3: Message delivery thread completed."
johang
Post by johang » 2020-10-08 21:11
do you have a firewall messing with the SSL trying to inspect it so it fails ?
do you have an antivirus that is getting into the "conversation" ?
did you disable SSL v 3.0 in [Settings][Advanced][SSL/TLS] ?
Post by palinka » 2020-10-09 00:03
2020-10-08 20:57
In settings > advanced > ssl/tls, uncheck "verify remote server ssl/tls certificates".
If I remember correctly, gmail uses a self signed certificate. Can't be verified.
Edit - if you want to verify gmail certificates, have a look here: https://www.hmailserver.com/forum/viewtopic.php?t=32158
johang
Post by johang » 2020-10-09 08:20
2020-10-09 00:03
:oops: :oops: that was a very much better answer then mine ..
lance.peterson
Post by lance.peterson » 2020-10-22 19:50
I was able to get it working with your instruction previously. I had set this server up with a temporary IP. My plan was to shut off the old device that we need to send back and then re-IP this new Server to what the other IP was so we didn't have to touch each machine to change the IP and touch the code of some applications. I did that and it wasn't working after that. Here is the log from the email I tried to send after the re-IP. Any suggestions for this would be great.
"DEBUG" 2572 "2020-10-22 12:35:11.085" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Delivering message..."
"APPLICATION" 2612 "2020-10-22 12:35:11.085" "SMTPDeliverer - Message 47: Delivering message from copier@co.barron.wi.us to lance.peterson@co.barron.wi.us. File: C:\Program Files (x86)\hMailServer\Data\{036AA217-5371-4B1B-8794-8ADEF464012E}.eml"
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Applying rules"
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Performing local delivery"
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Local delivery completed"
"TCPIP" 2612 "2020-10-22 12:35:11.085" "DNS MX lookup: co.barron.wi.us"
"TCPIP" 2612 "2020-10-22 12:35:11.085" "DNS - MX Result: 2 IP addresses were found."
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Starting external delivery process. Server: smtp2.co.barron.wi.us (172.16.6.100), Port: 25, Security: 2, User name: "
"DEBUG" 2612 "2020-10-22 12:35:11.085" "Creating session 64"
"TCPIP" 2612 "2020-10-22 12:35:11.100" "Connecting to 172.16.6.100:25..."
"DEBUG" 2612 "2020-10-22 12:35:11.100" "SMTPDeliverer - Message 47 - Connection failed: Could not connect to 172.16.6.100 on port 25 since this would mean connecting to myself."
"TCPIP" 2612 "2020-10-22 12:35:11.100" "TCPConnection - Could not connect to 172.16.6.100 on port 25 since this would mean connecting to myself."
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Ending session 64"
"DEBUG" 2612 "2020-10-22 12:35:11.100" "External delivery process completed"
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Summarizing delivery result"
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Summarized delivery results"
"DEBUG" 2612 "2020-10-22 12:35:11.100" "SD::RescheduleDelivery_"
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Retrieving retry options."
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Aborting delivery."
"APPLICATION" 2612 "2020-10-22 12:35:11.100" "SMTPDeliverer - Message 47: Message could not be delivered. Returning error log to sender."
"DEBUG" 2612 "2020-10-22 12:35:11.100" "Message not rescheduled for later delivery."
"DEBUG" 2612 "2020-10-22 12:35:11.100" "SD::SubmitErrorLog_"
"DEBUG" 2612 "2020-10-22 12:35:11.116" "Saving message: {DF90E4E4-AEB5-4B0D-82F3-6374007E3CFD}.eml"
"DEBUG" 2612 "2020-10-22 12:35:11.116" "SD::~SubmitErrorLog_"
"DEBUG" 2612 "2020-10-22 12:35:11.116" "Deleting message"
"DEBUG" 2612 "2020-10-22 12:35:11.116" "Deleting message file."
"APPLICATION" 2612 "2020-10-22 12:35:11.116" "SMTPDeliverer - Message 47: Message delivery thread completed."
Post by jimimaseye » 2020-10-22 20:55
The clue is here:
2020-10-22 19:50
lance.peterson
Post by lance.peterson » 2020-10-22 21:07
What I did change was under SMTP>Delivery of email I changed to smtp.gmail.com, from co.barron.wi.us. The text below from the VBS script. The IP I want to change it to is 172.16.6.100
2020-10-22   Hmailserver: 5.6.7-B2425
DOMAINS
     (No Domains Entered)
IP RANGES
IP: 172.16.6.1 - 172.16.6.250     Priority: 0     Name: Copiers
     POP3:  False                              Antivirus:  False
     Local To Local       - False
     Local To External    - False
     External To Local    - False
     External To External -  True              External To External - False
IP: 172.16.89.1 - 172.16.89.250     Priority: 0     Name: Servers
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 10   Plain Text:        False  Bind:
                     Host: EXTERNAL.TLD        Empty sender:       True  Batch recipients:   400
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-10-22.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-10-22.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
Post by jimimaseye » 2020-10-22 22:51
Toe dns lookup from that internal server is being ripped differently to that of the external dns servers.
https://mxtoolbox.com/SuperTool.aspx?ac ... n=toolpage
This shows mx records for co.barron.wi.us to be pointing at d227320a/b.ess.barracudanetworks.com yet your hms is resolving tosmtp2.co.barron.wi.us
So check your local dns tables.
