Mail Log Analyze
yigalr01
Mail Log Analyze
Post by yigalr01 » 2020-12-13 15:31
Hello
Can you please recommend me any software for easy analyzing Hmailserver logfiles ?
They are simple, but then we have large number of emails , there is difficult to follow them
Re: Mail Log Analyze
Post by palinka » 2020-12-13 15:43
Try this: https://log.damnation.org.uk/
Are you looking for something in particular in your logs?
yigalr01
Post by yigalr01 » 2020-12-13 15:51
Thank you ,
I know this site very nice but my logfiles is about 200 MB and more and I need offline software for analyzing this files
I am looking for most to understand if mail was successfully delivered to some people !
This is the main task for this log files :)
But may be very good to have some more detailed statists like how many mails was sent today , how off them was failed etc...
Post by palinka » 2020-12-13 16:03
yigalr01 wrote:
2020-12-13 15:51
Thank you ,
In that case, enable AWStats logging. It logs only the result of each transaction, with from, to, and a couple of other things.
yigalr01
Post by yigalr01 » 2020-12-13 16:33
Ok Thank you
How can I receive the status off sent email from the AWStats log ?
I can only see from to without status...
Post by palinka » 2020-12-13 16:43
yigalr01 wrote:
2020-12-13 16:33
Ok Thank you
Status is 2nd to last.
250 = OK (success)
5xx = Fail
Post by palinka » 2020-12-13 16:46
Here's a simple powershell script that will parse your hmailserver logs and spit out SMTPC entries only.
It takes a while to run because it has to read each line. 200mb of logs will take a while.
### SCRIPT VARIABLES ###
$LogDir = "C:\hMailServer\Logs" #<-- hMailServer Log Folder
<#	First find logs   #>
Get-ChildItem $LogDir | Where {$_.Name -match "^hmailserver_[0-9]{4}-[0-9]{2}-[0-9]{2}.log$"} | ForEach {
	$LogName = $_
	<#	Convert log lines to objects   #>
	Get-Content "$LogDir\$LogName" | ConvertFrom-String -Delimiter "`t" -PropertyNames Protocol, ThreadID, Session, DateTime, IPAddress, Message | ForEach {
		<#	If SMTPC proceed, discard all others   #>
		If ($_.Protocol -match "SMTPC") {
			Write-Output "$($_.Session) : $($_.Message)" | Out-File "$PSScriptRoot\SMTPC.log" -Append -Encoding ASCII
			Write-Host "$($_.Session) : $($_.Message)"
Post by SorenR » 2020-12-13 18:03
yigalr01 wrote:
2020-12-13 16:33
Ok Thank you
https://awstats.sourceforge.io/
