Sending and receiving emails error – Please help
RDA
Post by RDA » 2020-12-17 02:51
I have configured three domain in my server to manage mails. I have my webserver in the same network and share the certificate with HMailServer.
Previously all worked but for some reason it’s not working now. I ran the diagnostic script and add the result below.
Guys thanks in advanced for all your support…!
RDA
2020-12-17   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - abxx.lk                        Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain1.com
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - inxxxxx.uk                     Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain2.com
        Greylisting:     False
   "Domain3.com" - itxxxx.co.uk                   Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: webmaster@Domain3.com
        Greylisting:     False
IP RANGES
     POP3:  False                              Antivirus:   True
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
                              Minutes Before Reset:           60  (1.00 hours, 0.04 days)
                              Minutes to Autoban:            150  (2.50 hours, 0.10 days)
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                                               Max number commands: 100  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Add X-HmailServer-Subject:  True    Verify DKIM:       False
              Subject Text: "[SPAM]"
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              [@t]Domain1[dot]lk
              0.0.0.0            to    255.255.255.255              [@t]Domain2[dot]co[dot]uk
              0.0.0.0            to    255.255.255.255              [@t]Domain3[dot]uk
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: True,  Notify Receiver: True
  Max Message Size: 0
     CLAM AV:   True   !!!! CONFLICT !!!!       Hostname: 127.0.0.1    Port: 3310
     CLAMWIN:   True   !!!! CONFLICT !!!!       Executable: C:\Program Files\ClamAV\clamdscan.exe    Path: C:\Program Files\ClamAV\database\main.cvd
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   Domain1.com
       Certificate: \\172.16.10.50\SambaShare\Domain1.com\fullchain.pem
       Private key: \\172.16.10.50\SambaShare\Domain1.com\privkey.pem
   Domain2.com
       Certificate: \\172.16.10.50\SambaShare\Domain2.com\fullchain.pem
       Private key: \\172.16.10.50\SambaShare\Domain2.com\privkey.pem
   Domain3.com
       Certificate: \\172.16.10.50\SambaShare\Domain3.com\fullchain.pem
       Private key: \\172.16.10.50\SambaShare\Domain3.com\privkey.pem
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
ECDHE-RSA-AES128-GCM-SHA256
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: Domain2.com
               0.0.0.0         / 110   / POP3   -   StartTLS Optional   Cert: Domain2.com
               0.0.0.0         / 143   / IMAP   -   StartTLS Optional   Cert: Domain2.com
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: Domain1.com
               0.0.0.0         / 587   / SMTP   -   SSL/TLS             Cert: Domain3.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: Domain1.com
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: Domain1.com
  Paths:-
    Current:  F:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-12-17.log
    Error:    F:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-12-17.log
    Event:    F:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  F:\Program Files (x86)\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory E:\HmailBU is writable.
HMAILSERVER.INI
Program folder:  F:\Program Files (x86)\hMailServer\
Database folder:
Data folder:     F:\Program Files (x86)\hMailServer\Data
Log folder:      F:\Program Files (x86)\hMailServer\Logs
Temp folder:     F:\Program Files (x86)\hMailServer\Temp
Event folder:    F:\Program Files (x86)\hMailServer\Events
Type=              MYSQL
Username=          root
Port=              3306
Server=            localhost
Internal=          0
[Settings]
DisableAUTHList=25
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
jim.bus
Re: Sending and receiving emails error – Please help
Post by jim.bus » 2020-12-17 07:13
Read the Help Documentation for Anitvirus. It doesn't state you will get a conflict but it does state Clamwin runs very slow on a busy server. However, this might be what is causing your Conflict. The Help Documentation seems to favor ClamAV.
RDA
Post by RDA » 2020-12-17 08:32
Hi ,
That's what I'm using not the 'Clam win'. see the configuration details and please tell me if there's anything to be change.
jim.bus
Post by jim.bus » 2020-12-17 09:35
RDA wrote:
2020-12-17 08:32
Hi ,
Your Diagnostics says you are using both and your configuration setup you displayed in your prior post says you are using both ClamAV and ClamWin.
See your attachments in your Prior Post. You have specified to use both ClamAV and ClamWin.
Post by jimimaseye » 2020-12-17 10:16
Clamwin and clamav are different. You should disable clamwin if possible. Further information and explanation here: https://www.hmailserver.com/forum/viewt ... 21&t=26829
RDA
Post by RDA » 2020-12-17 13:54
Thanks for the support. I'm receiving email now but can't send ???
Post by palinka » 2020-12-17 14:19
RDA wrote:
2020-12-17 13:54
Any error logs?
Can you try to send a message, wait a minute, then post the logs around that message try?
RDA
Post by RDA » 2020-12-17 15:28
"DEBUG" 4680 "2020-12-17 13:12:50.277" "Creating session 27"
"TCPIP" 4680 "2020-12-17 13:12:50.277" "TCP - 185.30.177.60 connected to 172.16.10.155:993."
"DEBUG" 4680 "2020-12-17 13:12:50.277" "TCP connection started for session 21"
"DEBUG" 4680 "2020-12-17 13:12:50.277" "Performing SSL/TLS handshake for session 21. Verify certificate: False"
"TCPIP" 4684 "2020-12-17 13:12:50.370" "TCPConnection - TLS/SSL handshake completed. Session Id: 21, Remote IP: 185.30.177.60, Version: TLSv1.2,
Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"IMAPD" 4684 21 "2020-12-17 13:12:50.370" "185.30.177.60" "SENT: * OK IMAPrev1"
"IMAPD" 4680 21 "2020-12-17 13:12:50.527" "185.30.177.60" "RECEIVED: 1 LOGIN user1@Domain2 ***"
"IMAPD" 4680 21 "2020-12-17 13:12:50.605" "185.30.177.60" "SENT: 1 OK LOGIN completed"
"IMAPD" 4672 21 "2020-12-17 13:12:50.667" "185.30.177.60" "RECEIVED: 2 CAPABILITY"
"IMAPD" 4672 21 "2020-12-17 13:12:50.667" "185.30.177.60" "SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE
RIGHTS=texk[nl]2 OK CAPABILITY completed"
"IMAPD" 4684 21 "2020-12-17 13:12:50.730" "185.30.177.60" "RECEIVED: 3 NAMESPACE"
"IMAPD" 4684 21 "2020-12-17 13:12:50.730" "185.30.177.60" "SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]3 OK namespace command
complete"
"IMAPD" 4672 21 "2020-12-17 13:12:50.792" "185.30.177.60" "RECEIVED: 4 CREATE "Sent Messages""
"DEBUG" 4672 "2020-12-17 13:12:50.792" "Creating IMAP folder Sent Messages"
"IMAPD" 4672 21 "2020-12-17 13:12:50.808" "185.30.177.60" "SENT: 4 OK CREATE Completed"
"IMAPD" 4684 21 "2020-12-17 13:12:50.855" "185.30.177.60" "RECEIVED: 5 LIST "" "*""
"IMAPD" 4684 21 "2020-12-17 13:12:50.855" "185.30.177.60" "SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]* LIST (\HasNoChildren) "." "Deleted
Messages"[nl]* LIST (\HasNoChildren) "." "Sent Messages"[nl]5 OK LIST completed"
"IMAPD" 4680 21 "2020-12-17 13:12:50.917" "185.30.177.60" "RECEIVED: 6 MYRIGHTS "Deleted Messages""
"IMAPD" 4680 21 "2020-12-17 13:12:50.917" "185.30.177.60" "SENT: * MYRIGHTS "Deleted Messages" lrswipkxtea[nl]6 OK Myrights complete"
"IMAPD" 4672 21 "2020-12-17 13:12:50.980" "185.30.177.60" "RECEIVED: 7 MYRIGHTS "INBOX""
"IMAPD" 4672 21 "2020-12-17 13:12:50.980" "185.30.177.60" "SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]7 OK Myrights complete"
"IMAPD" 4684 21 "2020-12-17 13:12:51.042" "185.30.177.60" "RECEIVED: 8 MYRIGHTS "Sent Messages""
"IMAPD" 4684 21 "2020-12-17 13:12:51.042" "185.30.177.60" "SENT: * MYRIGHTS "Sent Messages" lrswipkxtea[nl]8 OK Myrights complete"
"IMAPD" 4672 21 "2020-12-17 13:12:51.105" "185.30.177.60" "RECEIVED: 9 APPEND "Sent Messages" (\Seen) {1965}"
"IMAPD" 4672 21 "2020-12-17 13:12:51.105" "185.30.177.60" "SENT: + Ready for literal data"
"DEBUG" 4680 "2020-12-17 13:12:51.324" "Saving message: {F08A777C-AA60-4EC1-915B-573FF9D77268}.eml"
"IMAPD" 4680 21 "2020-12-17 13:12:51.339" "185.30.177.60" "SENT: 9 OK APPEND completed"
"IMAPD" 4684 21 "2020-12-17 13:12:51.402" "185.30.177.60" "RECEIVED: 10 SELECT "Sent Messages""
"DEBUG" 4684 "2020-12-17 13:12:51.402" "Reading messages from database."
"IMAPD" 4684 21 "2020-12-17 13:12:51.402" "185.30.177.60" "SENT: * 1 EXISTS[nl]* 1 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered
\Flagged)[nl]* OK [UIDVALIDITY 1608210770] current uidvalidity[nl]* OK [UIDNEXT 2] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered
\Flagged)] limited[nl]10 OK [READ-WRITE] SELECT completed"
"IMAPD" 4684 21 "2020-12-17 13:12:51.449" "185.30.177.60" "RECEIVED: 11 FETCH 1:* (UID BODY.PEEK[HEADER.FIELDS (X-Append-Orig-Uidl)])"
"IMAPD" 4684 21 "2020-12-17 13:12:51.449" "185.30.177.60" "SENT: * 1 FETCH (UID 1 BODY[HEADER.FIELDS (X-Append-Orig-Uidl)] {51}"
"IMAPD" 4684 21 "2020-12-17 13:12:51.449" "185.30.177.60" "SENT: )"
"IMAPD" 4684 21 "2020-12-17 13:12:51.449" "185.30.177.60" "SENT: 11 OK FETCH completed"
"IMAPD" 4696 21 "2020-12-17 13:12:51.683" "185.30.177.60" "RECEIVED: 12 LIST "" "*""
"IMAPD" 4696 21 "2020-12-17 13:12:51.683" "185.30.177.60" "SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]* LIST (\HasNoChildren) "." "Deleted
Messages"[nl]* LIST (\HasNoChildren) "." "Sent Messages"[nl]12 OK LIST completed"
"IMAPD" 4684 21 "2020-12-17 13:12:51.730" "185.30.177.60" "RECEIVED: 13 MYRIGHTS "Deleted Messages""
"IMAPD" 4684 21 "2020-12-17 13:12:51.730" "185.30.177.60" "SENT: * MYRIGHTS "Deleted Messages" lrswipkxtea[nl]13 OK Myrights complete"
"IMAPD" 4696 21 "2020-12-17 13:12:51.792" "185.30.177.60" "RECEIVED: 14 MYRIGHTS "INBOX""
"IMAPD" 4696 21 "2020-12-17 13:12:51.792" "185.30.177.60" "SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]14 OK Myrights complete"
"IMAPD" 4676 21 "2020-12-17 13:12:51.855" "185.30.177.60" "RECEIVED: 15 MYRIGHTS "Sent Messages""
"IMAPD" 4676 21 "2020-12-17 13:12:51.855" "185.30.177.60" "SENT: * MYRIGHTS "Sent Messages" lrswipkxtea[nl]15 OK Myrights complete"
"IMAPD" 4684 21 "2020-12-17 13:12:51.902" "185.30.177.60" "RECEIVED: 16 STATUS "Deleted Messages" (UIDNEXT MESSAGES UNSEEN UIDVALIDITY)"
"DEBUG" 4684 "2020-12-17 13:12:51.917" "Reading messages from database."
"IMAPD" 4684 21 "2020-12-17 13:12:51.917" "185.30.177.60" "SENT: * STATUS "Deleted Messages" (MESSAGES 2 UNSEEN 2 UIDNEXT 3 UIDVALIDITY
1608190807)[nl]16 OK Status completed"
"IMAPD" 4680 21 "2020-12-17 13:12:51.964" "185.30.177.60" "RECEIVED: 17 STATUS "Sent Messages" (UIDNEXT MESSAGES UNSEEN UIDVALIDITY)"
"IMAPD" 4680 21 "2020-12-17 13:12:51.964" "185.30.177.60" "SENT: * STATUS "Sent Messages" (MESSAGES 1 UNSEEN 0 UIDNEXT 2 UIDVALIDITY
1608210770)[nl]17 OK Status completed"
"IMAPD" 4696 21 "2020-12-17 13:12:52.245" "185.30.177.60" "RECEIVED: 18 FETCH 1:* (UID FLAGS INTERNALDATE)"
"IMAPD" 4696 21 "2020-12-17 13:12:52.245" "185.30.177.60" "SENT: * 1 FETCH (UID 1 FLAGS (\Seen) INTERNALDATE "17-Dec-2020 13:12:51 +0000")"
"IMAPD" 4696 21 "2020-12-17 13:12:52.245" "185.30.177.60" "SENT: 18 OK FETCH completed"
"IMAPD" 4684 21 "2020-12-17 13:12:52.605" "185.30.177.60" "RECEIVED: 19 UID FETCH 1 (RFC822.SIZE BODY.PEEK[])"
"IMAPD" 4684 21 "2020-12-17 13:12:52.605" "185.30.177.60" "SENT: * 1 FETCH (UID 1 RFC822.SIZE 1967 BODY[] {1967}"
"IMAPD" 4684 21 "2020-12-17 13:12:52.605" "185.30.177.60" "SENT: )"
"IMAPD" 4684 21 "2020-12-17 13:12:52.605" "185.30.177.60" "SENT: 19 OK UID completed"
"IMAPD" 4684 21 "2020-12-17 13:12:52.855" "185.30.177.60" "RECEIVED: 20 STATUS "INBOX" (UIDNEXT MESSAGES UNSEEN UIDVALIDITY)"
"IMAPD" 4684 21 "2020-12-17 13:12:52.855" "185.30.177.60" "SENT: * STATUS "INBOX" (MESSAGES 7 UNSEEN 0 UIDNEXT 10 UIDVALIDITY 1608115561)
[nl]20 OK Status completed"
"IMAPD" 4680 21 "2020-12-17 13:12:52.933" "185.30.177.60" "RECEIVED: 21 LOGOUT"
"IMAPD" 4680 21 "2020-12-17 13:12:52.933" "185.30.177.60" "SENT: * BYE Have a nice day[nl]21 OK Logout completed"
"DEBUG" 4684 "2020-12-17 13:12:52.933" "Ending session 21"
"DEBUG" 4684 "2020-12-17 13:19:57.902" "Creating session 28"
"TCPIP" 4684 "2020-12-17 13:19:57.902" "TCP - 185.30.176.197 connected to 172.16.10.155:587."
"DEBUG" 4684 "2020-12-17 13:19:57.902" "TCP connection started for session 5"
"DEBUG" 4684 "2020-12-17 13:19:57.902" "Performing SSL/TLS handshake for session 5. Verify certificate: False"
Post by SorenR » 2020-12-17 15:44
RDA wrote:
2020-12-17 13:54
enable SMTP logging and post the log where it fails.
Post by palinka » 2020-12-17 16:03
2020-12-17 15:44
RDA wrote:
2020-12-17 13:54
And disable IMAP logging. It cuts out mucho log spam.
RDA
Post by RDA » 2020-12-17 16:03
I have already enable, see below
RDA
Post by RDA » 2020-12-17 16:13
DEBUG" 4696 "2020-12-17 14:07:25.449" "Creating session 69"
"TCPIP" 4696 "2020-12-17 14:07:25.449" "TCP - 185.30.177.35 connected to 172.16.10.155:25."
"DEBUG" 4696 "2020-12-17 14:07:25.449" "TCP connection started for session 68"
"SMTPD" 4696 68 "2020-12-17 14:07:25.449" "185.30.177.35" "SENT: 220 Domain1; Domain2; Domain3 ESMTP"
"SMTPD" 4672 68 "2020-12-17 14:07:25.511" "185.30.177.35" "RECEIVED: EHLO f11.my.com"
"SMTPD" 4672 68 "2020-12-17 14:07:25.511" "185.30.177.35" "SENT: 250-Domain1; Domain2; Domain3[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250 HELP"
"SMTPD" 4680 68 "2020-12-17 14:07:25.574" "185.30.177.35" "RECEIVED: STARTTLS"
"SMTPD" 4680 68 "2020-12-17 14:07:25.574" "185.30.177.35" "SENT: 220 Ready to start TLS"
"DEBUG" 4672 "2020-12-17 14:07:25.574" "Performing SSL/TLS handshake for session 68. Verify certificate: False"
"DEBUG" 4680 "2020-12-17 14:07:25.667" "Creating session 70"
"TCPIP" 4680 "2020-12-17 14:07:25.667" "TCP - 185.30.177.59 connected to 172.16.10.155:993."
"DEBUG" 4680 "2020-12-17 14:07:25.667" "TCP connection started for session 67"
"DEBUG" 4680 "2020-12-17 14:07:25.667" "Performing SSL/TLS handshake for session 67. Verify certificate: False"
"TCPIP" 4676 "2020-12-17 14:07:25.730" "TCPConnection - TLS/SSL handshake completed. Session Id: 68, Remote IP: 185.30.177.35, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"TCPIP" 4696 "2020-12-17 14:07:25.761" "TCPConnection - TLS/SSL handshake completed. Session Id: 67, Remote IP: 185.30.177.59, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"SMTPD" 4676 68 "2020-12-17 14:07:25.792" "185.30.177.35" "RECEIVED: EHLO f11.my.com"
"SMTPD" 4676 68 "2020-12-17 14:07:25.792" "185.30.177.35" "SENT: 250-Domain1; Domain2; Domain3[nl]250-SIZE 20480000[nl]250 HELP"
"SMTPD" 4696 68 "2020-12-17 14:07:25.855" "185.30.177.35" "RECEIVED: QUIT"
"SMTPD" 4696 68 "2020-12-17 14:07:25.855" "185.30.177.35" "SENT: 221 goodbye"
"DEBUG" 4676 "2020-12-17 14:07:25.855" "Ending session 68"
"DEBUG" 4676 "2020-12-17 14:07:26.511" "Saving message: {F5ED8552-42DF-47F9-82C8-C8A9D7A58A48}.eml"
"DEBUG" 4672 "2020-12-17 14:07:26.620" "Reading messages from database."
"DEBUG" 4696 "2020-12-17 14:07:28.183" "Ending session 67"
johang
Post by johang » 2020-12-17 17:52
RDA wrote:
2020-12-17 16:13
take away starttls optional on port 25 ( and then you can fiddle with with starttsl on another port to test what is wrong )
