I've been trying to setup a simple mail message to my mail server. I've given up on trying to get it to send externally (I don't need to worry about that now) and I'm only trying to send an email through to another account in the same domain (the domain on my hMailServer is called mynetwork.com). I've been trying to accomplish this with PHPMailer, I'll have the code for that below.
What I've tried (off the top of my head):
1. Followed these instructions https://www.hmailserver.com/documentati ... es_outside
2. Turned off all of my firewalls
3. Tried setting a relay with my ISP SMTP server.
4. Cried
These are my debug logs/code
PHPMailer Code
<?php
require 'php/PHPMailerAutoload.php';
date_default_timezone_set('Etc/UTC');
$email = $_POST['email'];
$mail = new PHPMailer;
$mail->SMTPDebug = SMTP::DEBUG_SERVER;
$mail->isSMTP();
$mail->SMTPSecure = "tls";
$mail->SMTPAuth = true;
$mail->Port = 587;
$mail->Host = "localhost";
$mail->Username = "Administrator";
$mail->Password = "********";
$mail->From = "ftn@mynetwork.com";
$mail->addAddress($email, 'Test User');
$to = $email;
$subject = "This is a test";
$text = "Your email test worked!";
$mail->Subject = $subject;
$mail->Body = $text;
try {
$mail->send();
echo "<h1>Success</h1>";
} catch (Exception $e) {
echo "<h1>Failure</h1>";
2020-12-19 22:22:55 SERVER -> CLIENT: 220 *****-PC ESMTP
2020-12-19 22:22:55 CLIENT -> SERVER: EHLO localhost
2020-12-19 22:22:55 SERVER -> CLIENT: 250-*****-PC250-SIZE 20480000250-AUTH LOGIN250 HELP
2020-12-19 22:22:55 CLIENT -> SERVER: STARTTLS
2020-12-19 22:22:55 SERVER -> CLIENT: 503 Bad sequence of commands
2020-12-19 22:22:55 SMTP ERROR: STARTTLS command failed: 503 Bad sequence of commands
SMTP Error: Could not connect to SMTP host.
2020-12-19 22:22:55 CLIENT -> SERVER: QUIT
2020-12-19 22:22:55 SERVER -> CLIENT: 221 goodbye
SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
"DEBUG" 5144 "2020-12-19 02:10:23.751" "Received shutdown-request from Windows."
"APPLICATION" 5144 "2020-12-19 02:10:23.751" "Stopping servers..."
"DEBUG" 5144 "2020-12-19 02:10:23.751" "Application::StopServers() - Removing server work queue"
"DEBUG" 5144 "2020-12-19 02:10:23.751" "WorkQueueManager::RemoveQueue - Server queue"
"DEBUG" 5144 "2020-12-19 02:10:23.751" "Stopping working queue Server queue."
"DEBUG" 5144 "2020-12-19 02:10:23.751" "Interupt and join threads in working queue Server queue"
"DEBUG" 4644 "2020-12-19 02:10:23.751" "IOService::Stop()"
"DEBUG" 4644 "2020-12-19 02:10:23.751" "IOService::DoWork() - removing Queue IOCP Queue"
"DEBUG" 4644 "2020-12-19 02:10:23.766" "WorkQueueManager::RemoveQueue - IOCPQueue"
"DEBUG" 4644 "2020-12-19 02:10:23.766" "Stopping working queue IOCPQueue."
"DEBUG" 4644 "2020-12-19 02:10:23.766" "Interupt and join threads in working queue IOCPQueue"
"DEBUG" 9212 "2020-12-19 02:10:23.766" "Worker exited in work queue Server queue"
"DEBUG" 9208 "2020-12-19 02:10:23.766" "Worker exited in work queue Server queue"
"DEBUG" 8272 "2020-12-19 02:10:23.766" "Worker exited in work queue Server queue"
"DEBUG" 9220 "2020-12-19 02:10:23.766" "TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG" 9244 "2020-12-19 02:10:23.766" "TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG" 9220 "2020-12-19 02:10:23.766" "Ending session 2"
"DEBUG" 9244 "2020-12-19 02:10:23.766" "Ending session 5"
"DEBUG" 5144 "2020-12-19 02:10:23.782" "Still 2 remaining threads in queue Server queue. First task: IOService"
"DEBUG" 9244 "2020-12-19 02:10:23.782" "Worker exited in work queue IOCPQueue"
"DEBUG" 9220 "2020-12-19 02:10:23.782" "Worker exited in work queue IOCPQueue"
"DEBUG" 9236 "2020-12-19 02:10:23.782" "Worker exited in work queue IOCPQueue"
"DEBUG" 9256 "2020-12-19 02:10:23.782" "Worker exited in work queue IOCPQueue"
"DEBUG" 9252 "2020-12-19 02:10:23.798" "Worker exited in work queue IOCPQueue"
"DEBUG" 9240 "2020-12-19 02:10:23.798" "Worker exited in work queue IOCPQueue"
"DEBUG" 9224 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9204 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9264 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9260 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9232 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9248 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 9228 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 7292 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 5584 "2020-12-19 02:10:23.813" "Worker exited in work queue IOCPQueue"
"DEBUG" 4644 "2020-12-19 02:10:23.813" "Still 3 remaining threads in queue IOCPQueue. First task: <Unknown>"
"DEBUG" 5144 "2020-12-19 02:10:24.063" "Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG" 4644 "2020-12-19 02:10:24.079" "All threads are joined in queue IOCPQueue."
"DEBUG" 4644 "2020-12-19 02:10:24.079" "WorkQueueManager::RemoveQueue - Stopped IOCPQueue"
"DEBUG" 4644 "2020-12-19 02:10:24.079" "WorkQueueManager::RemoveQueue - Erased IOCPQueue"
"DEBUG" 4644 "2020-12-19 02:10:24.079" "IOService::Stop() - Complete"
"DEBUG" 4644 "2020-12-19 02:10:24.079" "Destructing work queue IOCPQueue"
"DEBUG" 4644 "2020-12-19 02:10:24.329" "Worker exited in work queue Server queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "All threads are joined in queue Server queue."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Stopped Server queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Erased Server queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Destructing work queue Server queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Clearing caches"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Destructing IOCP"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "IOService::~IOService - Destructing"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "TCPServer::~TCPServer"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Destructing DeliveryManager"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - SMTP delivery queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Stopping working queue SMTP delivery queue."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Interupt and join threads in working queue SMTP delivery queue"
"DEBUG" 6956 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 708 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 8600 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 8564 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 696 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 8732 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 8612 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 8316 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 704 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 700 "2020-12-19 02:10:24.329" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "All threads are joined in queue SMTP delivery queue."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Stopped SMTP delivery queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Erased SMTP delivery queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Destructing work queue SMTP delivery queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Destructing FetchManager"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "ExternalFetchManager::~ExternalFetchManager"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - External fetch queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Stopping working queue External fetch queue."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Interupt and join threads in working queue External fetch queue"
"DEBUG" 7052 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 5456 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 7008 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 7004 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 7044 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 8936 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 8888 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 7048 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 7016 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 6996 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 6992 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 5588 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 8828 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 5580 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 8816 "2020-12-19 02:10:24.329" "Worker exited in work queue External fetch queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "All threads are joined in queue External fetch queue."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Stopped External fetch queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Erased External fetch queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Destructing work queue External fetch queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "ExternalFetchManager::~ExternalFetchManager - Removed queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Destructing Scheduler"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Application::StopServers() - Destructing Rest"
"APPLICATION" 5144 "2020-12-19 02:10:24.329" "Servers stopped."
"DEBUG" 5144 "2020-12-19 02:10:24.329" "WorkQueueManager::RemoveQueue - Maintenance queue"
"DEBUG" 5144 "2020-12-19 02:10:24.329" "Stopping working queue Maintenance queue."
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Interupt and join threads in working queue Maintenance queue"
"DEBUG" 6220 "2020-12-19 02:10:24.344" "Worker exited in work queue Maintenance queue"
"DEBUG" 6216 "2020-12-19 02:10:24.344" "Worker exited in work queue Maintenance queue"
"DEBUG" 6228 "2020-12-19 02:10:24.344" "Worker exited in work queue Maintenance queue"
"DEBUG" 6224 "2020-12-19 02:10:24.344" "Worker exited in work queue Maintenance queue"
"DEBUG" 6212 "2020-12-19 02:10:24.344" "Worker exited in work queue Maintenance queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "All threads are joined in queue Maintenance queue."
"DEBUG" 5144 "2020-12-19 02:10:24.344" "WorkQueueManager::RemoveQueue - Stopped Maintenance queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "WorkQueueManager::RemoveQueue - Erased Maintenance queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Destructing work queue Maintenance queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "WorkQueueManager::RemoveQueue - Asynchronous task queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Stopping working queue Asynchronous task queue."
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Interupt and join threads in working queue Asynchronous task queue"
"DEBUG" 8544 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8556 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8540 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8528 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8552 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8524 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8512 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8508 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8548 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8536 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8532 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8520 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8516 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8504 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 8500 "2020-12-19 02:10:24.344" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "All threads are joined in queue Asynchronous task queue."
"DEBUG" 5144 "2020-12-19 02:10:24.344" "WorkQueueManager::RemoveQueue - Stopped Asynchronous task queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "WorkQueueManager::RemoveQueue - Erased Asynchronous task queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Destructing work queue Asynchronous task queue"
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Application::ExitInstance - Closing database connection..."
"DEBUG" 5144 "2020-12-19 02:10:24.344" "Application::ExitInstance - Deleting caches..."
"DEBUG" 5180 "2020-12-19 14:18:48.567" "Application::InitInstance - Configuration loaded."
"DEBUG" 5180 "2020-12-19 14:18:48.582" "Creating work queue Asynchronous task queue"
"DEBUG" 5180 "2020-12-19 14:18:48.582" "Starting work queue Asynchronous task queue"
"DEBUG" 6152 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 8188 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 5680 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7368 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 4064 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 5180 "2020-12-19 14:18:48.582" "Started work queue Asynchronous task queue"
"APPLICATION" 5180 "2020-12-19 14:18:48.582" "Starting servers..."
"DEBUG" 7628 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7244 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 8180 "2020-12-19 14:18:48.582" "Running worker in work queue Asynchronous task queue"
"DEBUG" 8184 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 6860 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 6208 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7364 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7344 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7292 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 7516 "2020-12-19 14:18:48.598" "Running worker in work queue Asynchronous task queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Creating work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Starting work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Started work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Adding task Scheduler to work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Adding task IOService to work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Creating work queue SMTP delivery queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Starting work queue SMTP delivery queue"
"DEBUG" 8868 "2020-12-19 14:18:49.394" "Running worker in work queue Server queue"
"DEBUG" 8868 "2020-12-19 14:18:49.394" "Executing task Scheduler in work queue Server queue"
"DEBUG" 4616 "2020-12-19 14:18:49.394" "Running worker in work queue Server queue"
"DEBUG" 4616 "2020-12-19 14:18:49.394" "Executing task IOService in work queue Server queue"
"DEBUG" 4616 "2020-12-19 14:18:49.394" "IOService::Start()"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Started work queue SMTP delivery queue"
"DEBUG" 8856 "2020-12-19 14:18:49.394" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9080 "2020-12-19 14:18:49.394" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9128 "2020-12-19 14:18:49.394" "Running worker in work queue SMTP delivery queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Adding task SMTPDeliveryManager to work queue Server queue"
"DEBUG" 8636 "2020-12-19 14:18:49.394" "Running worker in work queue SMTP delivery queue"
"DEBUG" 712 "2020-12-19 14:18:49.394" "Running worker in work queue SMTP delivery queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Creating work queue External fetch queue"
"DEBUG" 5180 "2020-12-19 14:18:49.394" "Starting work queue External fetch queue"
"DEBUG" 9232 "2020-12-19 14:18:49.394" "Running worker in work queue External fetch queue"
"DEBUG" 4684 "2020-12-19 14:18:49.394" "Running worker in work queue Server queue"
"DEBUG" 9236 "2020-12-19 14:18:49.394" "Running worker in work queue External fetch queue"
"DEBUG" 4684 "2020-12-19 14:18:49.394" "Executing task SMTPDeliveryManager in work queue Server queue"
"DEBUG" 9248 "2020-12-19 14:18:49.394" "Running worker in work queue External fetch queue"
"DEBUG" 8832 "2020-12-19 14:18:49.394" "Running worker in work queue Server queue"
"DEBUG" 5180 "2020-12-19 14:18:49.410" "Started work queue External fetch queue"
"DEBUG" 4684 "2020-12-19 14:18:49.410" "SMTPDeliveryManager::Start()"
"DEBUG" 9268 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 8652 "2020-12-19 14:18:49.410" "Running worker in work queue SMTP delivery queue"
"DEBUG" 7748 "2020-12-19 14:18:49.410" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9252 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 9212 "2020-12-19 14:18:49.410" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9068 "2020-12-19 14:18:49.410" "Running worker in work queue SMTP delivery queue"
"DEBUG" 5180 "2020-12-19 14:18:49.410" "Adding task ExternalFetchManager to work queue Server queue"
"DEBUG" 9272 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Creating session 1"
"DEBUG" 9288 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 9220 "2020-12-19 14:18:49.410" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9228 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 9240 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 8832 "2020-12-19 14:18:49.410" "Executing task ExternalFetchManager in work queue Server queue"
"DEBUG" 8832 "2020-12-19 14:18:49.410" "ExternalFetchManager::Start()"
"DEBUG" 9244 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Creating session 2"
"APPLICATION" 5180 "2020-12-19 14:18:49.410" "Servers started."
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Creating work queue IOCPQueue"
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Starting work queue IOCPQueue"
"DEBUG" 9256 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 9264 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Started work queue IOCPQueue"
"DEBUG" 4616 "2020-12-19 14:18:49.410" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 9276 "2020-12-19 14:18:49.410" "Running worker in work queue External fetch queue"
"DEBUG" 9328 "2020-12-19 14:18:49.410" "Running worker in work queue IOCPQueue"
"DEBUG" 4616 "2020-12-19 14:18:49.426" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 9332 "2020-12-19 14:18:49.410" "Running worker in work queue IOCPQueue"
"DEBUG" 9328 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9332 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9344 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9280 "2020-12-19 14:18:49.426" "Running worker in work queue External fetch queue"
"DEBUG" 9292 "2020-12-19 14:18:49.426" "Running worker in work queue External fetch queue"
"DEBUG" 9344 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9348 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9348 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9364 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9376 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9380 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9360 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9364 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9376 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9380 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9360 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9324 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9336 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9340 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9352 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9356 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9368 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9324 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9336 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9340 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9372 "2020-12-19 14:18:49.426" "Running worker in work queue IOCPQueue"
"DEBUG" 9372 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9352 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9356 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9368 "2020-12-19 14:18:49.426" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9368 "2020-12-19 15:46:52.019" "Creating session 3"
"TCPIP" 9368 "2020-12-19 15:46:52.021" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 15:46:52.022" "TCP connection started for session 2"
"SMTPD" 9368 2 "2020-12-19 15:46:52.022" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 2 "2020-12-19 15:46:52.032" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 2 "2020-12-19 15:46:52.032" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 2 "2020-12-19 15:46:52.034" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 2 "2020-12-19 15:46:52.034" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 2 "2020-12-19 15:46:52.036" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 2 "2020-12-19 15:46:52.036" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 15:46:52.036" "Ending session 2"
"DEBUG" 9368 "2020-12-19 16:31:35.240" "Creating session 4"
"TCPIP" 9368 "2020-12-19 16:31:35.241" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:31:35.242" "TCP connection started for session 3"
"SMTPD" 9368 3 "2020-12-19 16:31:35.242" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 3 "2020-12-19 16:31:35.242" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 3 "2020-12-19 16:31:35.243" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9352 3 "2020-12-19 16:31:35.243" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9352 3 "2020-12-19 16:31:35.243" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 3 "2020-12-19 16:31:35.244" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 3 "2020-12-19 16:31:35.244" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 16:31:35.244" "Ending session 3"
"DEBUG" 9368 "2020-12-19 16:33:37.920" "Creating session 5"
"TCPIP" 9368 "2020-12-19 16:33:37.920" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:33:37.921" "TCP connection started for session 4"
"SMTPD" 9368 4 "2020-12-19 16:33:37.922" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 4 "2020-12-19 16:33:37.931" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 4 "2020-12-19 16:33:37.931" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 4 "2020-12-19 16:33:37.932" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 4 "2020-12-19 16:33:37.932" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 4 "2020-12-19 16:33:37.932" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 4 "2020-12-19 16:33:37.933" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 16:33:37.933" "Ending session 4"
"DEBUG" 9368 "2020-12-19 16:34:17.433" "Creating session 6"
"TCPIP" 9368 "2020-12-19 16:34:17.433" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:34:17.435" "TCP connection started for session 5"
"SMTPD" 9368 5 "2020-12-19 16:34:17.435" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 5 "2020-12-19 16:34:17.435" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 5 "2020-12-19 16:34:17.435" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9352 5 "2020-12-19 16:34:17.436" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9352 5 "2020-12-19 16:34:17.436" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 5 "2020-12-19 16:34:17.436" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 5 "2020-12-19 16:34:17.437" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9368 "2020-12-19 16:34:17.437" "Ending session 5"
"DEBUG" 9368 "2020-12-19 16:40:26.800" "Creating session 7"
"TCPIP" 9368 "2020-12-19 16:40:26.800" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:40:26.801" "TCP connection started for session 6"
"SMTPD" 9368 6 "2020-12-19 16:40:26.801" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 6 "2020-12-19 16:40:26.810" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 6 "2020-12-19 16:40:26.810" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 6 "2020-12-19 16:40:26.811" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 6 "2020-12-19 16:40:26.811" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 6 "2020-12-19 16:40:26.811" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 6 "2020-12-19 16:40:26.812" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 16:40:26.812" "Ending session 6"
"DEBUG" 9368 "2020-12-19 16:42:07.115" "Creating session 8"
"TCPIP" 9368 "2020-12-19 16:42:07.116" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:42:07.117" "TCP connection started for session 7"
"SMTPD" 9368 7 "2020-12-19 16:42:07.117" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 7 "2020-12-19 16:42:07.125" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 7 "2020-12-19 16:42:07.125" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 7 "2020-12-19 16:42:07.126" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 7 "2020-12-19 16:42:07.126" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 7 "2020-12-19 16:42:07.127" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 7 "2020-12-19 16:42:07.127" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 16:42:07.127" "Ending session 7"
"DEBUG" 9368 "2020-12-19 16:42:30.069" "Creating session 9"
"TCPIP" 9368 "2020-12-19 16:42:30.069" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:42:30.070" "TCP connection started for session 8"
"SMTPD" 9368 8 "2020-12-19 16:42:30.070" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 8 "2020-12-19 16:42:30.080" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 8 "2020-12-19 16:42:30.080" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 8 "2020-12-19 16:42:30.081" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 8 "2020-12-19 16:42:30.081" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9356 8 "2020-12-19 16:42:30.082" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9356 8 "2020-12-19 16:42:30.082" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9352 "2020-12-19 16:42:30.082" "Ending session 8"
"DEBUG" 9368 "2020-12-19 16:43:31.224" "Creating session 10"
"TCPIP" 9368 "2020-12-19 16:43:31.224" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:43:31.225" "TCP connection started for session 9"
"SMTPD" 9368 9 "2020-12-19 16:43:31.226" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"DEBUG" 9368 "2020-12-19 16:43:31.236" "The read operation failed. Bytes transferred: 0 Remote IP: 127.0.0.1, Session: 9, Code: 10054, Message: An existing connection was forcibly closed by the remote host"
"DEBUG" 9368 "2020-12-19 16:43:31.236" "Ending session 9"
"DEBUG" 9368 "2020-12-19 16:44:12.921" "Creating session 11"
"TCPIP" 9368 "2020-12-19 16:44:12.921" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 16:44:12.922" "TCP connection started for session 10"
"SMTPD" 9368 10 "2020-12-19 16:44:12.922" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9356 10 "2020-12-19 16:44:12.931" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9356 10 "2020-12-19 16:44:12.931" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 10 "2020-12-19 16:44:12.932" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 10 "2020-12-19 16:44:12.932" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 10 "2020-12-19 16:44:12.932" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 10 "2020-12-19 16:44:12.932" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9368 "2020-12-19 16:44:12.933" "Ending session 10"
"DEBUG" 9368 "2020-12-19 16:50:15.092" "Creating session 12"
"TCPIP" 9368 "2020-12-19 16:50:15.093" "TCP - 127.0.0.1 connected to 127.0.0.1:25."
"DEBUG" 9368 "2020-12-19 16:50:15.094" "TCP connection started for session 1"
"SMTPD" 9368 1 "2020-12-19 16:50:15.094" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 1 "2020-12-19 16:50:15.103" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 1 "2020-12-19 16:50:15.103" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9368 1 "2020-12-19 16:50:15.104" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9368 1 "2020-12-19 16:50:15.104" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 1 "2020-12-19 16:50:15.104" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 1 "2020-12-19 16:50:15.104" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 16:50:15.105" "Ending session 1"
"DEBUG" 9368 "2020-12-19 17:18:43.320" "Creating session 13"
"TCPIP" 9368 "2020-12-19 17:18:43.321" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 17:18:43.322" "TCP connection started for session 11"
"SMTPD" 9368 11 "2020-12-19 17:18:43.322" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 11 "2020-12-19 17:18:43.331" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 11 "2020-12-19 17:18:43.331" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9368 11 "2020-12-19 17:18:43.332" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9368 11 "2020-12-19 17:18:43.332" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 11 "2020-12-19 17:18:43.332" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 11 "2020-12-19 17:18:43.332" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 17:18:43.333" "Ending session 11"
"DEBUG" 9368 "2020-12-19 17:19:45.329" "Creating session 14"
"TCPIP" 9368 "2020-12-19 17:19:45.329" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 17:19:45.331" "TCP connection started for session 13"
"SMTPD" 9368 13 "2020-12-19 17:19:45.331" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9356 13 "2020-12-19 17:19:45.332" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9356 13 "2020-12-19 17:19:45.332" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9356 13 "2020-12-19 17:19:45.333" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9356 13 "2020-12-19 17:19:45.333" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 13 "2020-12-19 17:19:45.333" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 13 "2020-12-19 17:19:45.333" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9352 "2020-12-19 17:19:45.334" "Ending session 13"
"DEBUG" 9368 "2020-12-19 17:20:00.212" "Creating session 15"
"TCPIP" 9368 "2020-12-19 17:20:00.212" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 17:20:00.213" "TCP connection started for session 14"
"SMTPD" 9368 14 "2020-12-19 17:20:00.214" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9356 14 "2020-12-19 17:20:00.222" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9356 14 "2020-12-19 17:20:00.222" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9368 14 "2020-12-19 17:20:00.223" "127.0.0.1" "RECEIVED: AUTH LOGIN"
"SMTPD" 9368 14 "2020-12-19 17:20:00.223" "127.0.0.1" "SENT: 530 A SSL/TLS-connection is required for authentication."
"SMTPD" 9368 14 "2020-12-19 17:20:00.224" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 14 "2020-12-19 17:20:00.224" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 17:20:00.224" "Ending session 14"
"DEBUG" 9368 "2020-12-19 17:21:20.364" "Creating session 16"
"TCPIP" 9368 "2020-12-19 17:21:20.364" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 17:21:20.366" "TCP connection started for session 15"
"SMTPD" 9368 15 "2020-12-19 17:21:20.366" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9356 15 "2020-12-19 17:21:20.374" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9356 15 "2020-12-19 17:21:20.374" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9352 15 "2020-12-19 17:21:20.375" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9352 15 "2020-12-19 17:21:20.375" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9368 15 "2020-12-19 17:21:20.375" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9368 15 "2020-12-19 17:21:20.375" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9356 "2020-12-19 17:21:20.376" "Ending session 15"
"DEBUG" 9368 "2020-12-19 17:22:55.068" "Creating session 17"
"TCPIP" 9368 "2020-12-19 17:22:55.069" "TCP - 127.0.0.1 connected to 127.0.0.1:587."
"DEBUG" 9368 "2020-12-19 17:22:55.070" "TCP connection started for session 16"
"SMTPD" 9368 16 "2020-12-19 17:22:55.070" "127.0.0.1" "SENT: 220 **REPLACED FOR PRIVACY**-PC ESMTP"
"SMTPD" 9352 16 "2020-12-19 17:22:55.079" "127.0.0.1" "RECEIVED: EHLO localhost"
"SMTPD" 9352 16 "2020-12-19 17:22:55.079" "127.0.0.1" "SENT: 250-**REPLACED FOR PRIVACY**-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 9352 16 "2020-12-19 17:22:55.079" "127.0.0.1" "RECEIVED: STARTTLS"
"SMTPD" 9352 16 "2020-12-19 17:22:55.079" "127.0.0.1" "SENT: 503 Bad sequence of commands"
"SMTPD" 9352 16 "2020-12-19 17:22:55.080" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 9352 16 "2020-12-19 17:22:55.080" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 9368 "2020-12-19 17:22:55.080" "Ending session 16"
Thank you.
