http://www.tacktech.com/display.cfm?ttid=197
Works under win 2003 (and probably any other windows too just not tried it myself) I set spamd.exe as a service with this info.
Set any exe as a service
Re: Set any exe as a service
Does that program allow you to set command switches on executables as well?
Shouldn't be a problem. Pls see attached screenshot.
Sweet, that seems much easier than microsofts SrvAny program. Thanks for the information and the time to make the screenshot.
if it is to run the SpamD.exe then try look at my app there is design to run the spamd.exe and check it is good
http://www.tooms.dk/software/spamdloade ... efault.asp
Any comment or statements is my own and have no relationship to my workplace
"The operation timed out when attempting to contact www.tooms.dk"
Sorry about that, the web server is online now.
Tooms
Tooms
Nice one thanks!
