ReCaptcha V1 on registration form will shutdown soon
daver
Post by daver » 2018-02-23 11:48
Recaptcha V1 will shutdown on March 31, 2018
You use it on registration form
It needs to be updated
Now is hard to register, I'll have to reload recapcha several time to get a "real" captcha to digit and register here.
Re: ReCaptcha V1 on registration form will shutdown soon
Post by martin » 2018-02-25 12:29
I'll look into this.
Martin Knafve
martin@hmailserver.com
https://twitter.com/knafve
Post by martin » 2018-02-25 13:11
Looks like I need to upgrade the phpBB software to the latest version. Will do an attempt of this later today.
Looks exciting:
https://www.phpbb.com/support/docs/en/3 ... upgrade31/
Martin Knafve
Post by jimimaseye » 2018-02-25 13:31
Ooh. Good luck with that. Hope the banner hammer plugin still works after.
Post by martin » 2018-02-25 15:50
That was fun...
I've upgraded to latest phpbb-version and after fiddling around in various places I think the forum is back to "almost same feature set as before". :)
I've upgraded banhammer to latest version and tested it quickly and it seems to still work. Please let me know if it doesn't work for you.
Also confirmed that the captcha during registration is now using the new ReCaptcha version.
Martin Knafve
Post by jimimaseye » 2018-02-25 15:58
Cheers. Noted.
I've just sent you an email about another issue.
Post by jimimaseye » 2018-02-25 19:07
This is normal text
This is bold
this is red text
this is SMALLl text
this is small red text
this is
    code text
end
[code]this is SMALL
code text
end[/code]
1, This is showing that anything that has a combination of [SIZE] followed by [ CODE ] breaks the code formatting.
2, Between here -->
<-- and here is an opening code tag without a matching closing tag (edit the post to see).
It shows everything that follows in code despite there no being close.  (This same error doesnt happen with a mismatched [bold] tag as you can see.
Post by jimimaseye » 2018-02-28 20:32
Test test test.
This is looking more like the old style of input (with exception of the size issue).
skrzat
Post by skrzat » 2018-03-06 23:54
After upgrade this forum doesn't work on Tapatalk :(
skrzat
Post by skrzat » 2018-10-22 22:51
Will it ever work on Tapatalk?
