Three lines of powershell
mats
Post by mats » 2023-02-02 22:26
Is all it takes to make RDP use a (letsencrypt) certificate from the local certstore
$TSGeneralSetting = Get-WmiObject "Win32_TSGeneralSetting" -ComputerName "." -Namespace root\cimv2\terminalservices -Filter "TerminalName='RDP-tcp'"
$TSGeneralSetting.SSLCertificateSHA1Hash = (Get-ChildItem -Path Cert:\LocalMachine\my | WHERE {$_.Subject -match "[b]CN=mail.example.com[/b]" } | Sort-Object -Descending NotBefore | Select -First 1).Thumbprint
$TSGeneralSetting.put()
Change mail.example.com as needed
I will test it with the certifytheweb client and see if it will autoupdate on cert renew
