Script to rename Attachment file type
Hello hmail-community
first: I Like hmailserver - it serves me well and I like how versatile it is.
Now to my problem: As you know there is a lot of macro-viruses out there, so I used the bloc attachments-policy to block all Word and Excel fiels, wich works fine. My users are informed and when they need a file, I grab it from the webserver for them. This is the annoying part....
what I did:
I editet the script I found here: viewtopic.php?t=26175#p165892 to save the Attachments to another place, so that users can grab it themselves, but that isnt optimal for several reasons (the crm we use and so on...)
what I want:
I want hmailserver to just edit the name of an attachment for example from "text.docx" to "text.docx.WARNING" so that users can just edit the name of the attachment to get it open. that would be a bump high enough, to avoid accidental opening of unwanted attachments, but it would otherwise not require them to write a ticket and wait until an admin has grabbed their file for them...
Googling did not bring results I understood or could put to use...
as I am not a coder, i can merely edit, I need a script to do that... I know how to put it to work, I just have no clue how to make it happen.
can someone please help me?
Thanks for all the fish!
Martin
what I did:
what I want:
Martin
- jimimaseye
- Moderator
Re: Script to rename Attachment file type
Untested. Try this for a start.
There are other ways to avoid this danger though. If you use Clam antivirus with Sane definitions then the various Office documents are already scanned for threats (and really quite effective) as well as other Zero hour releases. See here for installation: viewtopic.php?f=21&t=26829
Of course, there is also the policy of ensuring you turn off Automatic Macro Running in MS Office as well (always recommended) - that way even if they open a macro file it still will not do anything.
If oClient.username <> "" then
Dim ListOf4CharExtensions
ListOf4CharExtensions = ".ext docx xlsx .doc" ' Add more as necessary separated with space (must 4 characters!)
Dim i
For i = 0 To oMessage.Attachments.Count-1
if InStr(1,ListOf4CharExtensions,right(oMessage.Attachments.item(i).Filename,4),1) > 0 then
oMessage.Attachments.item(i).Filename = oMessage.Attachments.item(i).Filename & ".WARNING"
End if
oMessage.save
End if
Hello jimimaseye,
thanks for the fas treply and sorry for my slow one...
obviously I overestimated myself - I cant get the script to run.
I put it into the EventHandlers.vbs under "Sub OnAcceptMessage(oClient, oMessage)" but nothing happens.
I also put a modified form (see below) in another sub and called it via a rule:
Action: Run Function RenameAttachments
what is it I do not get?
may it be that a virus scanner is in the way (i.e. an attachment is scanned an can therefore not be renamend, or do those things happen sequential?)
hope you, or anybody can help me with this..
thanks
Martin
thanks
Martin
Sub RenameAttachments(oMessage)
ListOf4CharExtensions = ".ext docx xlsx .doc .pdf .xml" ' Add more as necessary separated with space (must 4 characters!)
Dim i
End if
oMessage.save
- jimimaseye
- Moderator
Have you followed the procedure to enable scripting? https://www.hmailserver.com/documentati ... ce_scripts (bottom) ?
Yes I have, I also have reloaded and also Checked the syntax every time.
[EDIT]
I am more the iterative-scripting type - I need a kind of breakpoint to see if the script is even run... do I find such information in any logfile?
[EDIT]
I just found aditional infos in a log...
[EDIT]
[EDIT]
I found an error: 800A000D
losly translated: type incompatible
Is the script I posted above plausible?
Strange enough:
the Error message states a Line, that is not even in the EventHandler.vbs - file.
at fist ist was at line 379 allthough the file had only 377 lines,
now I took all my scripts out and have a nearly empty default file with 31 lines, the error in the Log-file points to line 33...
I am way out in the dark, somebody please bring a light...
- jimimaseye
- Moderator
Dont worry, the old code wouldnt have worked anyway.
New code (tested and working).
Add unwanted extensions to the .Pattern = ".doc$|.xlsx$|.docx$" variable ensuring you finish each with dollar $ sign (and separate with pipe | )
Change the "secretpassword" (line 5) to suit:
Dim fso, filespec, obApp, PathStore, ListOf4CharExtensions, i, oRegExp
Call obApp.Authenticate("Administrator", "secretpassword" )
PathStore = obApp.Settings.Directories.DataDirectory
Set oRegExp = new RegExp
with oRegExp
.IgnoreCase = True
.Global = False
end with
if (oRegExp.test(oMessage.Attachments(i).Filename)) Then
filespec = PathStore & "\" & oMessage.Attachments.item(i).Filename & ".WARNING"
oMessage.Attachments(i).saveas(filespec)
oMessage.Attachments(i).delete
oMessage.Attachments.add(filespec)
oMessage.save
fso.DeleteFile(filespec)
End if
Set oRegExp = nothing
End sub
- jimimaseye
- Moderator
Dont forget the RULE to call it:
if Messagesize > 0 then
(this will run against all messages. Change your IF condition to suit your needs if you dont want it against all).
thanks again!
I am a bit reluctant to try the new code, as it requires Authetication to the server...
Why is this needed?
It is for example not needed in this viewtopic.php?t=26175#p165892 script?
thanks
Martin
Why is this needed?
thanks
Martin
- jimimaseye
- Moderator
What on earth do you think can happen?? If you fear someone seeing the password in the script then you have bigger problems - allowing unauthorised/untrusted people access to your mail server in the first place should be much more of a concern for you.
Its required just to obtain your datapath according to HMS install.
You really shouldnt worry about this. Really.
But if you really dont want to, then remove
and replace with
PathStore = "c:\pathto\yourDATAdirectory"
dear jimimaseye
please, I did not mean to offend you.
I am very gratefull for your help and it seems to bring me closer to a solution.
I just established a rule for myself, to not just copy and paste code if I do not have at least an idea what it might do on my system, and putting a plaintext password in a script is always a red-light-indicator.
After your explenation, I see, that your first version is the universal approach, wich is hasle free, I thank you very much for that.
only one issue:
It still does not work.
in the log it reads:
but once again the file only has 53 lines...
Here My EventHandler.vbs file (53 lines)
only one issue:
runtime error 800A000D - Types incompatible 'RenameAttachments' Line:55 Column: 0 - Code: (null)
' End Sub
' Sub OnSMTPData(oClient, oMessage)
' End Sub
'Sub OnAcceptMessage(oClient, oMessage)
'End Sub
' Sub OnDeliveryStart(oMessage)
' End Sub
' Sub OnDeliverMessage(oMessage)
' End Sub
' Sub OnBackupFailed(sReason)
' End Sub
' Sub OnBackupCompleted()
' End Sub
' Sub OnError(iSeverity, iCode, sSource, sDescription)
' End Sub
' Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
' End Sub
' Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
' End Sub
PathStore = "C:\Program Files (x86)\hMailServer\Data"
with oRegExp
.IgnoreCase = True
.Global = False
end with
oMessage.save
End if
End sub
I just did another test with your version of the script and the Password in it, it runs into the same error (just in line 56)...
Did you re-load the scripts after making the changes?
yes, I allways do.
The fact that The error now occurs in line 56 is a strong indicator, as the script with the password-line is one line longer...
Ahem... You "close" oRegExp before doing the test ???
Should it not be...
with oRegExp
.IgnoreCase = True
.Global = False
end with
oMessage.save
End if
with oRegExp
.IgnoreCase = True
.Global = False
if (.test(oMessage.Attachments(i).Filename)) Then
oMessage.save
End if
end with
- jimimaseye
- Moderator
Dunno. My version worked for me. Im no guru - I just SEARCHED and copied from others, read the documentation, googled to find a couple of answers I were unsure about, tested and it worked. (If only others were able to do the same. I must have a different internet/environment to some users).SorenR wrote:Ahem... You "close" oRegExp before doing the test ???
Should it not be...
For i = 0 To oMessage.Attachments.Count-1 with oRegExp .Pattern = ".doc$|.xlsx$|.docx$" .IgnoreCase = True .Global = False if (.test(oMessage.Attachments(i).Filename)) Then filespec = PathStore & "\" & oMessage.Attachments.item(i).Filename & ".WARNING" oMessage.Attachments(i).saveas(filespec) oMessage.Attachments(i).delete oMessage.Attachments.add(filespec) oMessage.save fso.DeleteFile(filespec) End if end with Next
No problems to me, no offence taken at all. I was just surprised to see your objection. Not wanting to type in your password in to your eventshandlers.vbs file is going to leave you HEAVILY restricted with any scripting you may want to do with Hmailserver.msdd wrote:dear jimimaseye
Try this... Changed the loop so that it does not create and destroy a RegEx object for each attachment if there are multiple attachments in the email... Oh yeah... Added commentsjimimaseye wrote:My version worked for me. Im no guru - I just SEARCHED and copied from others, read the documentation, googled to find a couple of answers I were unsure about, tested and it worked. (If only others were able to do the same. I must have a different internet/environment to some users).
Dim oFS, strFile, strPath, i
Set oFS = CreateObject("Scripting.FileSystemObject")
' Path for temporary files
strPath = "C:\Program Files (x86)\hMailServer\Data"
' Create RegEx object
.IgnoreCase = True
.Global = False
' Process attachments one by one
If (.Test(oMessage.Attachments(i).Filename)) Then
' Add new type to attachment file
strFile = strPath & "\" & oMessage.Attachments.item(i).Filename & ".WARNING"
' Save attachment on filesystem
oMessage.Attachments(i).Saveas(strFile)
' Delete attachment from email
oMessage.Attachments(i).Delete
' Add attachment from filesystem
oMessage.Attachments.Add(strFile)
' Save changes to email
' Delete file from filesystem
oFS.DeleteFile(strFile)
' Destroy RegEx object (same as; Set object = Nothing)
' Cleanup ...
Set oFS = Nothing
End sub
Alternative version without "With .. End With"
Dim oFS, oRegEx, strFile, strPath, i
oRegEx.Pattern = ".doc$|.xlsx$|.docx$"
oRegEx.IgnoreCase = True
oRegEx.Global = False
If (oRegEx.Test(oMessage.Attachments(i).Filename)) Then
Set oRegEx = Nothing
Set oFS = Nothing
End sub
Hello Forum,
I Used your help in the matter mentioned above, and it worked nearly flawlessly for quite a while now!
BUT: lately its seems that the script is manipulating the body of the email - namely:
some emails that have extensions wich are changed to .WARNING do not have any body left after passing through the script...
That is of course not acceptable and coursed some trouble at work...
does anybody of you see a reason in the script I am using why this may occur? As stated before most of the time the script does what its soppused to do but sometimes not...
Thank you for your help!
Martin
Martin
Call obApp.Authenticate("Administrator", "notmyactualpassword" )
with oRegExp
.Pattern = ".doc$|.xls$|.docx$|.xlsx$|.zip$|.7z$|.pps$|.ppsx$|.ppt$|pptx$"
.IgnoreCase = True
.Global = False
filespec = PathStore & "\" & oMessage.Attachments.item(i).Filename & ".WARNUNG"
oMessage.save
End if
end with
End sub
Which event call this sub ??
A general rule wich matches all incoming email:
If receipient list contains "@mydomainname" run function "RenameAttachments"
(see picture below)
(see picture below)
I have done some due dilligence on your code and changed it a bit...
"obApp.Settings.Directories.DataDirectory" is changed to "obApp.Settings.Directories.TempDirectory", there is no point in using the data directory.
RegEx; You need to escape the "." with "\." to remain a dot or it will represent "any one character". Additionally ".?" means there may be a character here - or not.. Don't forget the paranthesisisis (i hate that word) grouping your criteria.
Rearranged pattern based on "(\.doc)$|(\.docx)$" == "(\.doc.?)$"
Renamed the variables (that's my "OCD" speaking)
Moved code around a bit, there is no point in repeating code unnecessarily. Also I am wondering if not the correct procedure is to process attachments LIFO in order not to fu' the order of engagement.
Anyways, as you drive it from a rule, you can test run it with a named user.
Dim obApp, obFSO, strFile, strPath, i
strPath = obApp.Settings.Directories.TempDirectory
Set obFSO = CreateObject("Scripting.FileSystemObject")
.Pattern = "(\.doc.?)$|(\.xls.?)$|(\.zip)$|(\.7z)$|(\.pps.?)$|(\.ppt.?)$"
.IgnoreCase = True
.Global = False
For i = oMessage.Attachments.Count -1 To 0 Step -1
If (.test(oMessage.Attachments(i).Filename)) Then
strFile = strPath & "\" & oMessage.Attachments.item(i).Filename & ".WARNUNG"
oMessage.Attachments(i).saveas(strFile)
oMessage.Attachments.add(strFile)
oMessage.save
obFSO.DeleteFile(strFile)
End if
End sub
hi,
@SorenR: thanks for your improvements, I am now running a Test with your new script for several users. Lets see if the problem arises again.
Do you see any reason why the behavior I expereienced occured in the older Script I used?
Martin
Martin
Not sure but IIRC the RegEx search parms changed from initial script to problem script ...
Hello Again,
its been a while but the problem arose again.
It does only happen in some mails, but I fail to see a pattern. Only common thing: they all have attachments that get renamed through the script.
But not all mails with attachments lose their body...
Once again emails that got their attachment renamed properly lost all their body content. I used the script provided by SorenR from 2016/11/25
Would it be sensible to save the body content before the renaming operation and then reattach it after the operation is done?
Do you have any other approach to this?
Martin
Martin
- jimimaseye
- Moderator
You sure you are not looking at emails where they have been composed and the body is made up from an inline attachment? (And therefore removing the attachment effectively removes the body)?
My recommendation for diagnostic purposes:
Change the script so that when it has an attachment, it sends a copy of the original to a special quarantine/archive account before it modifies the email. That way, when you then find one of these 'disappearing body' messages, you can go back and see the original email to see what the pattern/cause is.
Hello jimimaseye,
I thought about that too, but as far as I can see this happens with text-emails as well.
I allready created a rule to place a copy of the email in an seperate folder but quickly realized, as my rule about renaming is run by every email, I just create a copy of every email - thats worthless. So I need to create the copy in the script.
Can you maybee give me a line of code to put in the script to achive that? I am not good enough at scripting and I do not want to introduce another source for errors...
Thank
Martin
Thank
Martin
- jimimaseye
- Moderator
Untested. Try this:
.IgnoreCase = True
.Global = False
if oMessage.Attachments.count > 0 then
Set newMessage = CreateObject("hMailServer.Message")
newMessage.From = oMessage.from
newMessage.FromAddress = oMessage.fromaddress
newMessage.Subject = oMessage.subject
newMessage.AddRecipient archiveaccount@yourdomain.com, archiveaccount@yourdomain.com
if SendHTMLBody <> "" then
newMessage.HTMLBody = oMessage.HTMLBody
else
newMessage.Body = oMessage.body
newMessage.attachments.add(oMessage.Attachments.item(i).Filename)
oMessage.save
End if
newMessage.save
End sub
Interesting ... I've seen something that sounds similar, although it has nothing to do with a script.
When the virus checker (ClamAV) detects a virus, I have it set to delete attachments. When it does this it sometimes munges the message body.
Here's a snipped of a raw .eml file that's been munged:
Here's (approximately) what it should look like:
(The first example is from a legit newsletter that was erroneously flagged (false positive) by ClamAV; the second snippet is from an earlier emailing of the same newsletter that didn't trigger a false-positive.)
As you can see, the content-type header is gone, as are the MIME boundary markers. Thus the email reader treats it as a plain text message, so you see mostly garbage.
I wonder if there could be a bug in the attachment deletion API that treats any MIME header as an attachment, or something like that?
Also interestingly, the original email didn't have any attachments ... even though hMS says it's deleting them ...
ras
...(typical headers)...
X-hMailServer-LoopCount: 1
Virus found:
The attachment(s) of this message was removed since a virus was detected in at least one of them.
=0ADecember 17, 2016=0A=0A---------------------------------------=
Content-Type: multipart/alternative; boundary=--boundary_83327305_32021b03-d9da-4d14-9ec8-ada6bcd80221
----boundary_83327305_32021b03-d9da-4d14-9ec8-ada6bcd80221
Content-Type: text/plain; charset=us-ascii
ras
thats an interesting fact.
On my hMS I also run ClamAV....
Hello Again,
I got the Script from jimimaseye running (there is a newNessage at the end ) caused me some headaches but I learned a lot about debugging.
Ok so now every mail with attachments is beeing copied to a dedicated post-box, but the copy has no attachments. As far as I understand the Script the copy should have the original attachments.
Is that right?
thanks
Martin
Is that right?
thanks
Martin
- jimimaseye
- Moderator
Sorry about that. Typo. Have now changed it in the original post.msdd wrote:Hello Again,
hi,
thank you. Here my second question again:
Martin
thanksOk so now every mail with attachments is beeing copied to a dedicated post-box, but the copy has no attachments. As far as I understand the Script the copy should have the original attachments.
Is that right?
Martin
- jimimaseye
- Moderator
As I said, it was untested and just a theory when I knocked it up. In hindsight my understanding of handling attachments as not sufficient and it wouldnt have worked (the filename didnt have a physical file behind it until its saved). HOWEVER..... what it does tell you is that the body of the message was distinct separately from the attachments - your original email was losing body when attachments were removed/readded whereas this one has a complete body even without the attachment.
So lets try a different approach. This one sends the ORIGINAL message to archive and creates a new message and sends it to the original intended recipient. So your archive message will be the original as it came it. Remember though that in actual fact this archive should be redundant if the newMessage (to the recipient) now gets the body and the warning attachment without problems. Anyway, see how it goes:
EDIT: just changed it to avoid crucial problem.
Dim obApp, obFSO, strFile, strPath, i, r
.IgnoreCase = True
.Global = False
else
For r = oMessage.recipients.Count -1 To 0 Step -1
newMessage.AddRecipient oMessage.Recipients(r).Address oMessage.Recipients(r).Address
oMessage.ClearRecipients()
oMessage.AddRecipient archiveaccount@yourdomain.com, archiveaccount@yourdomain.com
strFile = strFile & ".WARNUNG"
End if
newMessage.Attachments.add(strFile)
oMessage.save
newMessage.save
End sub
hello again.
first: Thank you very much for your help. I appreciate it a lot!
second: I Implemented your latest script, found a little error in this line:
corrected it to:
but it does not do a thing...
Neither does it create a duplicate in the archive folder, nor does it rename the attachments in the mail wich goes to the original receipient.
I am clueless how to troubleshoot this.... can you please help again?
Thanks,
Martin
Thanks,
Martin
- jimimaseye
- Moderator
My mistake.
Change the middle line that errors
to
(I was missing the comma, sorry.)
Tested and it all works for me.
newMessage.AddRecipient oMessage.Recipients(r).Address, oMessage.Recipients(r).Address
hi,
it works as far as I can tell, and together with my ruleset its a wonderull way to completly fill a drive with all the same file very fast.
... meaning: My rule was also applied to the newly created email, which then created a new email and so on...
I tried to clear that by putting a rule on the archive account to not process any rules, but thats not working.
I also tried to create a rule for any mail with my archiveacount in the recepeint list to stop rule processing and I put that before the Attachment renaming rule but that does not work either...
my status:
1. The script seems to work
2. One email generates an endless stream of copies in the archive....
my status:
- jimimaseye
- Moderator
Call the script as a function from the onacceptmessage section of eventshandler and not by a rule.
like so?
EDIT: it is script 5 so thats no typo...
call RenameAttachments5
- jimimaseye
- Moderator
RenameAttachments5(oMessage)
Don't forget to remove the rule and change the script to a FUNCTION (and not a SUB)
thank you so much!
I will test it tomarrow.
Have a nice day!
Have a nice day!
Hello Again,
i am getting there, thank you for taking me on this journey...
I think the on accesp message does not work for me, as I get my messages from a catch-all acount from our webserver.
I Think I have to use the instead... but that does not seem to be right as nothing happens...
I also tried but that produced a loop once again...
what am I missing?
I also tried
onDeliverMessage
what am I missing?
my workaround for the blank body issue, it seemed to happen consistently with html files, so here I save the attachments into a random folder, create an array of the attachment locations, delete the original attachments and then attach the renamed ones. There is also the option to add a disclaimer as an attachment using a preset file located in the Utilities folder. Thanks to those who did the original work on this.
Sub WarningAttachments(oMessage)
Dim oFS, oRegEx, strFile, strBoilerPlate, strPath, i, bNeedSave, bAddBoilerPlate, iRandom, arrAttachments()
'generate a random folder name
iRandom = Int((99999)*Rnd+1)
strPath = "C:\Program Files (x86)\hMailServer\Temp\" & iRandom
'path to our disclaimer
bAddBoilerPlate = True
strBoilerPlate = "C:\Program Files (x86)\hMailServer\Addons\Utilities\Attachement_Warning_Readme.txt"
oRegEx.Pattern = "(\.htm.?)$|(\.html.?)$"
bNeedSave = False
'throws an exception when reloading scripts if we Dim with the actual ammount, use this work-around instead
ReDim arrAttachments(oMessage.Attachments.Count)
'rename
'log this activity
EventLog.Write("Attachement Renamed for " & oMessage.To & ": " & oMessage.Attachments(i).Filename)
'create the temp folder to avoid clashes with other incoming messages
If NOT oFS.FolderExists(strPath) Then
oFS.CreateFolder(strPath)
End IF
'append the warning extension
'save the attachment
'add the path to the array
arrAttachments(i) = strFile
'delete the original
'flag that we need to save the message later
bNeedSave = True
If bNeedSave Then
If bAddBoilerPlate Then
'add the disclaimer
oMessage.Attachments.Add(strBoilerPlate)
'loop through the attachment array and re-attached to the message
For Each strFile in arrAttachments
If strFile <> "" Then
'cleanup
'save the message
'cleanup
oFS.DeleteFolder(strPath)
Set oFS = Nothing
Hallo porcupine,
thanks for your improvements. I have not worked on this issue (blank body) for a while but it still keeps anoying me.
I looked over the script you wrote but as I wrote above my skills are limited, so despite your very well commented scriot I do not realy understand your approach.
Here are my Questions:
- Is this script used in replacement of the scripts above?
- if so: where is the part where I define whitch attachments are to be appended?
- if not: is it to add to the scripts above - Where?
please advice!
Thank Martin
please advice!
Thank Martin
Hi Martin,
1, yes it replaces all other scripts, just add this line to your OnAcceptMessage "Sub":
2, I have added some more comments for you, to help with customizing it to your needs. Don't forget to set the path to your boilerplate file and the hmailserver temp folder
3, n/a
Same code but with more comments:
3, n/a
'set the path to the hmailserver temp folder, it must end with \
'set the path to your boilerplate message to the users
'set the extensions you want to rename, each must be in the format (\.htm.?)$ and separated with a |
'examples:
'oRegEx.Pattern = "(\.docx.?)$" 'renames .docx files
'oRegEx.Pattern = "(\.htm.?)$|(\.html.?)$" 'renames both .htm and .html files
bNeedSave = False
'rename
'log this activity
End IF
'append the warning extension, change WARNING to any other extension you would like
bNeedSave = True
If bNeedSave Then
'add the disclaimer
'cleanup
'save the message
'cleanup
Set oFS = Nothing
Hallo porcupine,
thanks for your work on that blank body problem.
firstly: you are right, theissue with the blank body does only happen with html mails. I boiled it down to html mails with embedde pictures...
secondly: even with your updated script (thanks for the comments, they help allot) it still occurs. As soon as a sender sends an email with an forbidden attachment (one that is listed under: oRegEx.Pattern = ) and this mail contains an embedded Image an email with a blank body comes out of the script.
I do not have any idea what to do now. I know too litle about the inner workings of hmailserver, but I guess that in emails with embedded pictures the body is treated like a special form of attachment which does not survive the script above (no matter which one)...
does anyone know more about this?
thanks
Martin
thanks
Martin
I can confirm that the body survives with the following html file (with an embedded image), sent as an attachment when using my version of the script:
<html>
<body>
Here you go!<br>
<img src="data:image/png;base64,
iVBORw0KGgoAAAANSUhEUgAAAAoAAAAKCAYAAACNMs+9AAAABGdBTUEAALGP
C/xhBQAAAAlwSFlzAAALEwAACxMBAJqcGAAAAAd0SU1FB9YGARc5KB0XV+IA
AAAddEVYdENvbW1lbnQAQ3JlYXRlZCB3aXRoIFRoZSBHSU1Q72QlbgAAAF1J
REFUGNO9zL0NglAAxPEfdLTs4BZM4DIO4C7OwQg2JoQ9LE1exdlYvBBeZ7jq
ch9//q1uH4TLzw4d6+ErXMMcXuHWxId3KOETnnXXV6MJpcq2MLaI97CER3N0
vr4MkhoXe0rZigAAAABJRU5ErkJggg==" alt="Red dot" />
</body>
</html>
This is how outlook embed images.
------=_NextPart_001_0014_01D3435D.9AD00560
Content-Type: text/html;
charset="iso-8859-1"
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
<img =
width=3D64 height=3D76 id=3D"Bildobjekt_x0020_1" =
src=3D"cid:image001.png@01D3435D.2DF692B0" =
alt=3Dimage-name>
</html>
------=_NextPart_001_0014_01D3435D.9AD00560--
------=_NextPart_000_0013_01D3435D.9AD00560
Content-Type: image/png;
name="image001.png"
Content-Transfer-Encoding: base64
Content-ID: <image001.png@01D3435D.2DF692B0>
iVBORw0KGgoAAAANSUhEUgAAAEAAAABMCAYAAADdq7GlAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJ
RK5CYII=
------=_NextPart_000_0013_01D3435D.9AD00560--
Hello Everyone, long time no see
but the problem is still anoying me neary every day... As I want to go on Holiday in January I need to fix this...
so here is the latest:
- The script is renaming attachments just fine.
- if an Email is an HTML-Mail with an embedded Image like the example from porcupine, everything is fine.
- if an Email is an HTML-Mail with an embedded Image like from Gmail or Outlook, the renaming works, but the body comes back as Empty
At the moment I save the email before it is dealt with by the script and if it looeses its body I manually restore it from the save... There needs to be another way...
What I can think of is saving the body temporaryly and then puting it back into the mail at the end... My coding capabilities are not suffiencent to do this, so if someone can help, please do so, its hihgly apreciated.
Thanks and Merry Christmas
Martin
Martin
Dear Forum,
I know the last post in this thread is (really) old now, buth the topic is still bugging me...
I Still have the problem, that when I receive HTML.EMails with one of the specified Attachments, the Attachment is propperly renamed, but I also lose the email Body...
for the last years, whenever this happended, the user called me.. that he has a blank mail again... and then I restored the Text from the Mailarchive by hand... this is annoying and takes time... As I want to go on vacation this year, I need a solution, that does not involve my work!
I Still do think, that the Idea to rename the dangerous attachments is a very good solution for our company, but the effect that sometimes mails go missing is quite a dealbreaker.
I herby offer a reward of 100 € as a donation to a charity of your choosing, to the one, who is willing to give his/her valued time to fix this topic once and for all!
So here is the outline, of whats to be achived:
- every incomming mail has to be checked
If it has an attachment which is considered Dangerous (i.e. .xlsx, .doc, .docx, .ppt, .vbs, .exe,....) the attachment hast to be renamed from FILENAME.EXTENSIOn to FILENAME.EXTENSION.WARNING
The Body of the Email has to preserved, no matter if it Plaintext or HTML
@likiyasiqa: thanks for your help its much apreciated!
I do not really see, what you point is. For the office Formats a .doc and a .docx exist, both of them are covered via the \.doc.?
- The finding of the files as mentioned above and the subsequent renaiming work flawless - its the problem that some html mails lose their body thats driving me crazy.
I am sorry - maybe I just do not understand the regex-problem...
thanks
thanks
it is long ago, but I think i finaly found a solution working for me...
The script is doing as i expect but there is one issue, whenever an email is passes through the sctipt in the logfile an error-entry is created. It allways ponts to the line "newMessage.Save" and states
basically something like "Object necessary"...
i can not find my error here, does someone have an idea?
VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'newMessage' - Line: 218 Column: 2 - Code: (null)"
Sub RenameAttachments4all(oMessage)
Dim obApp, obFSO, strFile, strPath, i, nameAttachment, newMessage
Call obApp.Authenticate("Administrator", "7MOa5v1" )
.Pattern = "(\.doc.?)$|(\.docx.?)$|(\.xls.?)$|(\.xlsx.?)$|(\.zip)$|(\.7z)$|(\.pps.?)$|(\.ppsx.?)$|(\.pptx.?)$|(\.ppt.?)$|(\.exe.?)$|(\.jar.?)$|(\.bat.?)$|(\.vbs.?)$|(\.vba.?)$|(\.hta.?)$|(\.cmd.?)$"
.IgnoreCase = True
.Global = False
newMessage.AddRecipient "_renameattachment@ditit.local", "_renameattachment@ditit.local"
if oMessage.HTMLBody <> "" then
else
end if
newMessage.Save
REM newMessage.attachments.add(oMessage.Attachments.item(i).Filename)
strFile = strPath & "\" & oMessage.Attachments.item(i).Filename & ".Warnung"
nameAttachment = nameAttachment & i & oMessage.Attachments.item(i).Filename & strFile& " - "
REM obFSO.DeleteFile(strFile)
End if
if newMessage.HTMLBody <> "" then
oMessage.HTMLBody = newMessage.HTMLBody
else
oMessage.Body = newMessage.body
End if
oMessage.save
End sub
- jimimaseye
- Moderator
Surely , this
Should be this
Oh, plenty errors. I have moved a few lines up and down to make for...next and if...then clauses meet. I have not tested the code, I have only looked at making clauses meet without breaking objects.msdd wrote: ↑2020-10-14 22:38it is long ago, but I think i finaly found a solution working for me...
The script is doing as i expect but there is one issue, whenever an email is passes through the sctipt in the logfile an error-entry is created. It allways ponts to the line "newMessage.Save" and statesVBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'newMessage' - Line: 218 Column: 2 - Code: (null)"
If oMessage.Attachments.count > 0 Then
Call obApp.Authenticate("Administrator", "******" )
If oMessage.HTMLBody <> "" Then
newMessage.Save
.IgnoreCase = True
.Global = False
Rem newMessage.attachments.add(oMessage.Attachments.item(i).Filename)
Rem obFSO.DeleteFile(strFile)
If newMessage.HTMLBody <> "" Then
oMessage.save
