change roundcube skins via webadmin
tester02
Post by tester02 » 2017-01-25 22:50
I host some domains for friends with a roundcube webmail interface. Since they all have different tastes I want to offer the domain admin the choice to select and change their standart roundcubeskin as they like. Since there is now an alternative webadmin script in development I tried to make the roundcube-look changeable via that webadmin interface.
I found no way to use the object based way and used instead the GET array. But maybe someone can enlighten me how to make it better.
Necessary additions and changes for the webadmin code:
background_domain_save.php
   $SkinDesktop = hmailGetVar("SkinDesktop", "litecube");
   $SkinTablet = hmailGetVar("SkinTablet", "litecube");
   $SkinPhone = hmailGetVar("SkinPhone", "litecube");
   header("Location: index.php?page=domain&action=edit&domainid=$domainid&skin_desktop=$SkinDesktop&skin_tablet=$SkinTablet&skin_phone=$SkinPhone");
hm_domain.php
<?php
	PrintCheckboxRow("domainantispamenablegreylisting", $obLanguage->String("Enabled"), $domainantispamenablegreylistingchecked);
        </div>
        <h3><a href="#"><?php EchoTranslation("Webmail Skin")?></a></h3>
        <div class="hidden">
            <?php
                $path = "../mail/skins/";
                $DomainSkin = "";
                if (isset($_GET['skin_desktop']) && $_GET['skin_desktop'] != "" &&
                    isset($_GET['skin_tablet']) && $_GET['skin_tablet'] != "" &&
                    isset($_GET['skin_phone']) && $_GET['skin_phone'] != "") {
                    $SkinDesktop = htmlspecialchars(stripslashes($_GET['skin_desktop']));
	                 $SkinTablet = htmlspecialchars(stripslashes($_GET['skin_tablet']));
	                 $SkinPhone = htmlspecialchars(stripslashes($_GET['skin_phone']));
                    $zuordnung = parse_ini_file($path."skins.ini");
                    foreach($zuordnung as $key=>$value){
                        if (strpos(strtolower($domainname), strtolower($key)) !== false){
                            $zuordnung[$key] = $SkinDesktop.",".$SkinTablet.",".$SkinPhone;
                            $fp = fopen($path."skins.ini", 'w');
                            foreach($zuordnung as $schluessel=>$wert) {
                                fputs($fp, $schluessel."=\"".$wert."\"\r\n");
                            fclose($fp);
			            $testwert_desktop = strstr($zuordnung[$key],",",TRUE);
			            $testwert_tablet = strstr(substr(strstr($zuordnung[$key],",",FALSE),1),",",TRUE);
			            $testwert_phone = substr(strstr(substr(strstr($zuordnung[$key],",",FALSE),1),",",FALSE),1);
            <br><br>
			<?php EchoTranslation("Desktop-Skin:")?>
            <br>
			<select name="SkinDesktop" class="medium">
            <?php
				$scanned_directory = array_diff(scandir($path), array('..', '.'));
				foreach ($scanned_directory as $testdir){
					if (is_dir($path.'/'.$testdir)){
                        if ($testwert_desktop == $testdir){
                            echo "<option value=\"".$testdir."\" selected>".$testdir."</option>";
                        } else {
                            echo "<option value=\"".$testdir."\">".$testdir."</option>";
            </select>
            <br>
            <?php EchoTranslation("Tablet-Skin:")?>
            <br>
				<select name="SkinTablet" class="medium">
                <?php
                        if ($testwert_tablet == $testdir){
                        } else {
				</select>
            <br>
			<?php EchoTranslation("Phone-Skin:")?>
            <br>
            <select name="SkinPhone" class="medium">
                <?php
                        if ($testwert_phone == $testdir){
                        } else {
				</select>
            <br>
            <br>"larry" and "classic" are NOT tailored for mobile devices!
            <br>
        </div>
<?php
	PrintSaveButton();
and the roundcube additions
defaults.inc.php
$zuordnung = parse_ini_file("..\mail\skins\skins.ini");
$skin_wert = "";
switch ($_SERVER['HTTP_HOST']) {
    case "xyz.ab":
    case "www.xyz.ab":
        $skin_logo = '.\skins\roundcube_xyz_logo.png';
        $name = 'XYZ';
                if (strpos(strtolower($_SERVER['HTTP_HOST']), strtolower($key)) !== false){
                    $skin_desktop_wert = strstr($zuordnung[$key],",",TRUE);
                    $skin_tablet_wert = strstr(substr(strstr($zuordnung[$key],",",FALSE),1),",",TRUE);
                    $skin_phone_wert = substr(strstr(substr(strstr($zuordnung[$key],",",FALSE),1),",",FALSE),1);
        break;
    // add some more cases here for every other domain
    default:
        $name = '';
        $skin_desktop_wert = "some_skin";
        $skin_tablet_wert = "some_other_skin";
        $skin_phone_wert = "again_some_other_skin";
// skin name: folder from skins
$config['desktop_skin'] = $skin_desktop_wert;
$config['tablet_skin'] = $skin_tablet_wert;
$config['phone_skin'] = $skin_phone_wert;
// skin logo
$config['login_branding_XYZ'] = $skin_logo;
//add some lines here for every skin you have
//header logo best 200px x 50px
$config['header_branding_XYZ'] = $skin_logo;
// Name your service. This is displayed on the login screen and in the window title
$config['product_name'] = $name.' webmail ';
// Add this user-agent to message headers when sending
$config['useragent'] = $name.' webmail ';
