Script to link Active Directory with hmail
yeykol82
Post by yeykol82 » 2017-04-06 04:48
I found this script for Powershell to link Active Directory with hmail....has anybody tested it before?
......See attachment......or below
Import-Module ActiveDirectory
# This script creates an Active Directory user and an hMailServer user
# (C) 2015 Patrick Lambert provided under MIT license - http://dendory.net
# The Active Directory domain to use:
$domain = Get-ADDomain
# The base DN for accounts (DC=example,DC=com):
$dn = $domain.DistinguishedName
# The domain used for emails (example.com):
$dnsroot = $domain.DNSRoot;
# Enter your hMailServer password here:
$hmail_password = "xxxxxxxxxxxxxxx"
# Max size of account mailbox (in megs):
$hmail_maxsize = 100
# End of configuration
$letters = 'a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v','w','x','y','z','A','B','C','D','E','F','G','H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z'
$symbols = '!','?','*','&','%','$','#'
do
Write-Host "AD HMAIL ADD - (C) 2015 Patrick Lambert - http://dendory.net"
Write-Host
do { $cn = Read-Host "User ID" } while($cn -eq "")
do { $fn = Read-Host "First name" } while($fn -eq "")
do { $ln = Read-Host "Last name" } while($ln -eq "")
$ou = Read-Host "Organizational unit [default: List available OUs]"
if($ou -eq "")
Get-ADOrganizationalUnit -Filter * | Select Name | Format-Table
do { $ou = Read-Host "Organizational unit" } while($ou -eq "")
if($ou -eq "") { $ou = "Users" }
$defemail = "$fn.$ln@$dnsroot"
$defemail = $defemail -replace '\s',''
$email = Read-Host "Email address [default: $defemail]"
if($email -eq "") { $email = $defemail }
$upn = "$cn@$dnsroot"
# Doing ran this way to ensure we have letters, symbols and numbers. Should find a way to mix them more securely
$ran = $letters | Get-Random
$ran += $letters | Get-Random
$ran += $symbols | Get-Random
$ran += Get-Random -minimum 1000 -maximum 9999
$pwd = Read-Host "Initial password [default: $ran]"
if($pwd -eq "") { $pwd = $ran }
Write-Host
Write-Host "* Adding AD account..."
# Any specific additional attribute for dsadd can be added here
dsadd user "CN=$cn,OU=$ou,$dn" -upn "$upn" -email "$email" -fn "$fn" -ln "$ln" -pwd $pwd -display "$fn $ln" -disabled no
Write-Host "* Adding hMailServer account..."
# This creates a COM object against the hMailServer API
$hm = New-Object -ComObject hMailServer.Application
$hm.Authenticate("Administrator", $hmail_password) | Out-Null
$hmdom = $hm.Domains.ItemByName($dnsroot)
$hmact = $hmdom.Accounts.Add()
# Filling attributes for the email account based on current information, including AD integration for the password
$hmact.Address = $email
$hmact.Active = $true
$hmact.IsAD = $true
$hmact.MaxSize = $hmail_maxsize
$hmact.ADDomain = $dn
$hmact.ADUsername = $cn
$hmact.PersonFirstName = $fn
$hmact.PersonLastName = $ln
$hmact.save()
Write-Host "Done."
Read-Host "Press ENTER to add another user, CTRL-C to quit"
cls
while($true)
adhmailadd.7z
(1.41 KiB) Downloaded 236 times
