BATCH: Check, START and STOP
Post by Dravion » 2018-12-06 12:26
Little a helper for hMailServer Service handling
1) Checks the Service state
2) Returns Sucess or Fail on Service operation
3) Surpresses SC noisy messages with >nul
File: sc_start.bat
@REM - Check if hMailServer is stopped and if it is, start the Service
@ECHO OFF
@for /F "tokens=3 delims=: " %%H in ('sc query "hMailServer" ^| findstr "STATE"') do (
  if /I "%%H" NEQ "RUNNING" (
   @ECHO hMailServer Service is NOT running, starting it...
   @sc start "hMailServer" >nul
   if "%ERRORLEVEL%"=="0" (
		@ECHO SUCCESS: Service was started, go ahead.
	) else (
		@ECHO WARNING: Service could NOT be started.
File: sc_stop.bat
@REM - Check if hMailServer is stopped and if it is, stop the Service
@ECHO OFF
  if /I "%%H" EQU "RUNNING" (
   @ECHO hMailServer Service is running, stopping it...
   @sc stop "hMailServer" >nul
		@ECHO SUCCESS: Service was stopped, go ahead.
	) else (
		@ECHO WARNING: Service could NOT be stopped.
Screenshot
