trigger an event when an email is SENT
naren
Post by naren » 2019-04-30 09:15
How to write script to trigger an event when an email is SENT from an account.
The basic scenario is, i want to do some operation when an email was SENT to an external account using hmailserver. but i am not able to find an event which triggers/fires when an email was SENT.
(or)
Is there a way to find out the type of an email whether it's SENT/RECEIVED in any of the events in EventHandler.Vb ?
Thanks.
Re: trigger an event when an email is SENT
Post by mattg » 2019-04-30 09:31
Use a global rule to catch the message then call a function as one of the actions
naren
Post by naren » 2019-05-01 05:12
Thanks for the reply @mattg.
I am not sure how to create global rule and then call a function. if possible can please share some example.
Post by mattg » 2019-05-01 05:32
In the admin GUI
Rules >> Add
criteria
from contains 'me@example.com'
action
Run Function 'MyFunction'
In your eventhandlers add
Sub MyFunction(oMessage)
'do stuff here
end sub
In admin GUI enable scripts
naren
Post by naren » 2019-05-01 08:10
But this global rule will apply only for one account(me@example.com). But in my scenario, we need this functionality for all the accounts.
So how to create a global rule for all the accounts which will trigger a function when an email was SENT ?
Post by mattg » 2019-05-01 08:16
from contains '@example.com'
if multiple domains use OR with multiple criteria
naren
Post by naren » 2019-05-01 08:28
Great. Thank you @mattg. This should work.
Thank you.
naren
Post by naren » 2019-05-01 09:20
This worked.
Now i am able to trigger an event on email SENT
But, oMessage.ID is always returning the MessageID of message corresponding to INBOX folder.
How to get the MessageID of SENT folder ?
Post by mattg » 2019-05-01 10:54
Messages are added to SENT by an IMAP client, the actual messages are sent via SMTP
Catching when an IMAP client logs in is much trickier
naren
Post by naren » 2019-05-02 08:34
we would require to read the SENT message_id to continue our implementation.
Can you please let us know how proceed further on this ?
Post by SorenR » 2019-05-02 08:58
naren wrote:
2019-05-02 08:34
Are your clients required to authenticate with the server to send emails?
Is this "event" active for all users or only single domains?
Accessing a "sent mail" is really a R/O operation as you cannot legally change anything!
There may be multiple ways to do this pending your answers.
naren
Post by naren » 2019-05-02 09:21
this event will be active for all the users.
Post by SorenR » 2019-05-02 10:04
naren wrote:
2019-05-02 09:21
Do you need to modify the message before delivery or is it only for reference?
Post by SorenR » 2019-05-02 13:19
Hmm... This is like me driving to town on weekends... I'll be running all the red lights and not using my turn signals - I'm not coming to town to watch the coloured lights and it's nobody's business where I'm going... :roll:
naren
Post by naren » 2019-05-03 04:17
2019-05-02 10:04
naren wrote:
2019-05-02 09:21
we just want to read the message headers for mapping and store the message in data base.
Post by mattg » 2019-05-03 05:05
Then why can't you do that from the SMTP message that is passing through?
Why do you need the copy placed in the SENT folder?
naren
Post by naren » 2019-05-03 05:20
we need to read the SENT message_id for our implementation.
Post by mattg » 2019-05-03 07:27
Yes you keep saying that, but why?
What is the use case?
Post by SorenR » 2019-05-03 07:42
2019-05-03 07:27
I'm thinking vbscript OnAcceptMessage() and check for oMessage.FromAddress = user@domain and then do stuff to/with email ...OR... global rule if from = xxxx then forward copy to "carboncopy@mydomain.tld" and have an account rule run function on email ??
Post by mattg » 2019-05-03 08:47
The thing is that I can copy mail to a sent folder without actually sending the mail, I can also turn off adding to a a sent folder in my mail client, or changing the folder.
My various mail clients all use a different 'sent' folder each by default, so I have a sent from my iphone, sent form desktop, and sent from my webmail folder
Also, I could name my sent folder 'banana' and set my mail client to save sent messages there.
The only way that I could see this to be done is to search for all folders named 'sent' (or 'banana') and trawl through each of the messages one at a time, much like the delete script does...
Post by SorenR » 2019-05-03 12:45
2019-05-03 08:47
or catch it on the way out ...
naren
Post by naren » 2019-05-03 17:04
Thank you @mattg and @SorenR.
I think for now we will go with global rule if from...
Hopefully this should solve our issue.
