Move emails to top of the queue based on certain priority header flags
Re: Move emails to top of the queue based on certain priority header flags
Post by SorenR » 2020-03-14 13:13
Basic error messaging...
http://www.csidata.com/custserv/onlineh ... vbs241.htm
Sub ShowError(Event)
    EventLog.Write( "Error ==> " & Event )
    EventLog.Write( "Error Description: " & err.Description )
    EventLog.Write( "Error Source: " & err.Source )
    EventLog.Write( "Error Number: " & err.Number )
    err.Clear
Dim oApp, oMail, oFSO, column, Match, Matches, Priority : Priority = False
'   Setting up DCOM access
Call oApp.Authenticate("Administrator", "test")
'   Read queue list and process line by line
Matches = Split(oApp.status.UndeliveredMessages, vbNewLine)
For Each Match In Matches
    column = Split( Match, vbTab )
    '   Create new temporary email structure and obtain filename
    Set oMail = CreateObject("hMailServer.Message")
    strFilename = oMail.Filename
    '   Copy original queued mail into temporary mail structure
    If oFSO.FileExists(column(5)) Then
        err.Clear
        On Error Resume Next
        oFSO.CopyFile column(5), strFilename, True
        On Error GoTo 0
        If err.Number <> 0 Then
            showError("Priority queue handler: column(5) = " & column(5) & " strFilename = " & strFilename)
            '   Reload temporary mail structure and IF "X-Priority" = 1 THEN update priority in queue
            oMail.RefreshContent
            If oMail.HeaderValue("X-Priority") = "1" Then
                oApp.GlobalObjects.DeliveryQueue.ResetDeliveryTime(CLng(column(0)))
                Priority = True
            '   Delete temporary mail structure
            oFSO.DeleteFile strFilename, True
            On Error GoTo 0
            If err.Number <> 0 Then showError("Priority queue handler: strFilename = " & strFilename)
'   Force delivery of prioritized mails.
If Priority Then oApp.GlobalObjects.DeliveryQueue.StartDelivery
'   Housekeeping ;-)
Set oApp = Nothing
Set oMail = Nothing
Set oFSO = Nothing
cblaze22
Post by cblaze22 » 2020-03-14 17:57
Yes other then that one issue where it oddly didnt find a file, yes.
If you create and copy an object, does that not open something? If it writes a new file to the server, doesnt that keep a handle on it.
Post by SorenR » 2020-03-14 18:14
cblaze22 wrote:
2020-03-14 17:57
Nope... You only open a file for reading or writing.
cblaze22
Post by cblaze22 » 2020-03-15 22:19
Well got another orphan email. The email looks to have an attachment, so a large file. I am wondering if the copyfile function is not done when the deletefile is hit and it doesnt see the file. The email was 10MB.
Does EventLog.Write work in a task scheduler VBScript? If so does it go into the HMailServer one.
Post by SorenR » 2020-03-15 23:18
cblaze22 wrote:
2020-03-15 22:19
You are running this from shell and not inside EventHandlers ??
Post by SorenR » 2020-03-15 23:30
EventLog should work when COM/DCOM is authenticated but if not, you should replace...
with...
Dim EventLog, oApp, oMail, oFSO, column, Match, Matches, Priority : Priority = False
Set EventLog = CreateObject("hMailServer.EventLog")
I use EventLog.Write() in some of my code outside EventHandlers.vbs...
cblaze22
Post by cblaze22 » 2020-03-16 03:26
I added that new line.
Yes I run it in task scheduler because it checks every minute the queue to resend important emails if the queue is super long.
