Sub Unsubscribe
Sub Unsubscribe
Post by palinka » 2019-05-25 15:43
First, this doesn't have its own topic, so now it does (was buried within other topics).
Now, I've been using this for a while and it works well. However, I noticed a couple of things.
1) Some unsubscribes require the recipient address. Original script has a set from address (unsubscribe@mydomain.tld)
2) I noticed that once in a while legit mailing list senders trigger the unsubscribe rule, which is IF spam score > 0 THEN run unsubscribe. So I want a whitelist.
In this case the message was clean but was triggered by "ransomware" because it contained a discussion about ransomware spam. ugh... :roll:
I think the whitelist part is easy enough, but I'm not sure exactly if my "send from original recipient" bit will work. What do you think?
Sub Unsubscribe(oMessage)
   ' RFC6068 The 'mailto' URI Scheme: subject, cc, bcc, in-reply-to, body etc.. ?first &second &third etc...
   Const            m_To = "List Administrator"
   Const        m_Sender = "Unsubscriber Daemon"
   Set m_SenderAddress = oMessage.OriginalAddress  '<--------- WILL THIS WORK????
   Dim a, b, strRegEx, Match, Matches, sMailTo, sURL, m_Subject, m_Body, doMail, doURL
   strRegEx = "apache.org|horde.org|lists.sourceforge.net"  '<--------- LOOKUP WHITELISTED DOMAIN
   If (Lookup(strRegEx, oClient.From) = True) Then Exit Sub  '<--------- IF WHITELISTED DOMAIN THEN EXIT
   strRegEx = "^[0-1]:[0-1]$"
   If Lookup(strRegEx, oMessage.HeaderValue("X-hMailServer-Unsubscribe")) Then
      a = Split(oMessage.HeaderValue("X-hMailServer-Unsubscribe"), ":")
      doMail = a(0)
      doURL = a(1)
      doMail = True
      doURL = True
   If doMail Then
      strRegEx = "([^\<]*?)(mailto:[\s\S]*?)(?=\>)"
      Set Matches = oLookup(strRegEx, oMessage.HeaderValue("List-Unsubscribe"), True)
      If Matches.Count > 0 Then
         For Each Match In Matches
            ' On Error Resume Next
            sMailTo = Mid(Trim(Match.Value), 8)
            a = Split(sMailTo, "?")
            If UBound(a) > 0 Then
               b = Split(a(1), "&")
               If (InStr(1, b(0), "subject=", 1) > 0) Then m_Subject = Replace(b(0), "subject=", "")
               If (InStr(1, b(0), "body=", 1) > 0) Then m_Body = Replace(b(0), "body=", "")
               If UBound(b) > 0 Then
                  If (InStr(1, b(1), "subject=", 1) > 0) Then m_Subject = Replace(b(1), "subject=", "")
                  If (InStr(1, b(1), "body=", 1) > 0) Then m_Body = Replace(b(1), "body=", "")
               .From = Chr(34) & m_Sender & Chr(34) & " <" & m_SenderAddress & ">"
               .FromAddress = m_SenderAddress
               .AddRecipient a(0), a(0)
               .AddRecipient m_Sender, m_SenderAddress
               .HeaderValue("To") = Chr(34) & m_To & Chr(34) & " <" & a(0) & ">"
               .HeaderValue("CC") = Chr(34) & m_Sender & Chr(34) & " <" & m_SenderAddress & ">"
                If Not m_Subject = Empty Then
                   .Subject = m_Subject
                   .Subject = "Unsubscribe Me"
                If Not m_Body    = Empty Then
                   .Body = m_Body
                   .Body = "This is an automated message generated by our unsubscriber algorithym. Please do not respond to this email as it will be ignored."
               .Save
            ' On Error Goto 0
            If (Err.Number <> 0) Then
               EventLog.Write( "ERROR: Sub Unsubscribe(oMessage)" )
               Err.Clear
               Exit Sub
   If doURL Then
      strRegEx = "([^\<]*?)((http|https):[\s\S]*?)(?=\>)"
            sURL = Trim(Match.Value)
            With CreateObject("MSXML2.ServerXMLHTTP.6.0")
               .setoption(2) = (.getoption(2) & " - SXH_SERVER_CERT_IGNORE_ALL_SERVER_ERRORS")
               .open "GET", sURL, False
               .setrequestheader "User-Agent", "online link validator (http://www.dead-links.com/)"
               .send ("")
            On Error Goto 0
               Err.Clear
               Exit Sub
Re: Sub Unsubscribe
Post by palinka » 2019-05-26 07:37
I think this may work. Still not sure if I'm using the correct recipient object.
   ' Const m_SenderAddress = "unsubscribe@mydomain.tld"
   strRegEx = "apache\.org|horde\.org|lists\.sourceforge\.net"  '<--------- LOOKUP WHITELISTED DOMAIN
   If (Lookup(strRegEx, oMessage.From) = True) Then Exit Sub  '<--------- IF WHITELISTED DOMAIN THEN EXIT
   strRegEx = "(([A-Za-z0-9\.\-\+]+)\@(mydomain1\.us|mydomain2\.com|mydomain3\.net))"  '<--------- LOOKUP LOCAL ADDRESSES
   If (Lookup(strRegEx, oMessage.Recipients) = True) Then m_SenderAddress = Match.Value  '<--------- IF ORIGINAL MESSAGE TO = LOCAL ADDRESS
   Else Exit Sub  '<--------- IF NOT LOCAL ADDRESS THEN EXIT
	<--SNIP-->
Re: Sub Unsubscribe
Post by palinka » 2019-05-26 14:57
I realized the when I changed the sender address to the original recipient that the postmaster would not be copied, so I added that.
Here's the whole thing including rule to call and functions that were not shown.
My changes to Soren's excellent and working script are un-tested so far (haven't received an unsubscribe message yet) and I'm still not sure if I have the recipient part nailed down. Anyway, here's what I have.
GLOBAL RULE
CRITERIA: USE AND
CUSTOM HEADER FIELD: X-hMailServer-Spam = YES
CUSTOM HEADER FIELD: X-hMailServer-Reason-Score < 8 (whatever your delete threshold is - there's no point in unsubscribing to deleted junk)
ACTION
SET HEADER VALUE: X-hMailServer-Unsubscribe = 1:0
RUN FUNCTION: Unsubscribe
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
   'Const    m_SenderAddress = "unsubscribe@mydomain.tld"
   Const        m_Postmaster = "Postmaster"
   Const m_PostmasterAddress = "postmaster@mydomain.tld"
   If (Lookup(strRegEx, oMessage.Recipients) = True) Then   '<--------- IF ORIGINAL MESSAGE TO = LOCAL ADDRESS
      m_SenderAddress = Match.Value    '<--------- SET SENDER ADDRESS AS ORIGINAL RECIPIENT IN MESSAGE THAT TRIGGERED SUB
      Exit Sub
      doMail = a(0)
      doURL = a(1)
      doMail = True
      doURL = True
   If doMail Then
               .AddRecipient m_Postmaster, m_PostmasterAddress   '<--------- COPY POSTMASTER, NOT ORIGINAL RECIPIENT
               .HeaderValue("CC") = Chr(34) & m_Postmaster & Chr(34) & " <" & m_PostmasterAddress & ">"
                   .Body = m_Body
               .Save
            ' On Error Goto 0
               Err.Clear
               Exit Sub
   If doURL Then
               .send ("")
            On Error Goto 0
               Err.Clear
               Exit Sub
Re: Sub Unsubscribe
Post by palinka » 2019-05-28 15:07
OK, I'm not very good at this. Finally got some hits. Was getting mismatch errors on Lookup. Also sorted out the recipient as unsubscriber sender. Had the wrong syntax. These things are corrected below. Should be working now.
Thanks again to Soren for this awesome and very useful script. All I did was tweak a couple of things.
Dim a, b, strRegEx, Match, Matches, sMailTo, sURL, m_Subject, m_Body, doMail, doURL, m_SenderAddress
   strRegEx = "spamassassin\.apache\.org|lists\.horde\.org|lists\.sourceforge\.net"
   If Lookup(strRegEx, oMessage.From) Then Exit Sub
   Set Matches = oLookup(strRegEx, oMessage.Recipients(0).OriginalAddress, False)
Re: Sub Unsubscribe
Post by palinka » 2019-05-28 19:19
Just got my first hit. Confirmed working. Original recipient of the message that triggered the rule became the sender of the unsubscribe message. :D
Re: Sub Unsubscribe
Post by SorenR » 2019-05-29 14:33
2019-05-25 15:43
      doMail = a(0)
      doURL = a(1)
      doMail = True
      doURL = True
   If doMail Then
                   .Body = m_Body
               .Save
            ' On Error Goto 0
               Err.Clear
               Exit Sub
   If doURL Then
               .send ("")
            On Error Goto 0
               Err.Clear
               Exit Sub
The only reason you end up here is because the mail is tagged as SPAM... Do the "green thing" and whitelist in your SPAM handling - save some CPU cycles. :mrgreen:
Re: Sub Unsubscribe
Post by palinka » 2019-05-29 16:07
2019-05-29 14:33
Yep. Sure enough. But fortunately, the unsubscribe that kicked off the thought process was to the spamassassin list, which kindly sent me back a message that unsubscribe@mydomain.tld was not on the list and couldn't be unsubscribed. So that got me thinking maybe that's why so many others keep sending mail after unsubscribing. The sender address is the one they try to unsubscribe.
I think this part is an improvement. :mrgreen:
Re: Sub Unsubscribe
Post by SorenR » 2019-05-29 16:58
2019-05-29 16:07
2019-05-29 14:33
I've got something cooking on that matter as we speak ... Progress is however VERY slow as I've received 6 spam mails this month (!) with a "mailto" list thingy... :roll:
Re: Sub Unsubscribe
Post by palinka » 2019-05-29 17:33
2019-05-29 16:58
LOL me too. Not many spasms getting through since i implemented your rules. And 2 gorillion autobans. :mrgreen:
Re: Sub Unsubscribe
Post by SorenR » 2019-06-05 14:41
The way I use this Sub is on a forwarded message by my SPAM account.
For this to work I have to record the original recipient of the message so I added this Sub
Sub XEnvelope(oMessage)
   Dim i, strTo, strOriginalTo
      If (i = 0) Then
         strTo = oMessage.Recipients(i).Address
         strOriginalTo = oMessage.Recipients(i).OriginalAddress
         strTo = strTo & ", " & oMessage.Recipients(i).Address
         strOriginalTo = strOriginalTo & ", " & oMessage.Recipients(i).OriginalAddress
   oMessage.HeaderValue("X-Envelope-To") = strTo
   oMessage.HeaderValue("X-Envelope-OriginalTo") = strOriginalTo
and call it ...
   '   Add X-Envelope... headers
   Call XEnvelope(oMessage)
The Unsubscribe code ...
   Const     sBcc = "Automated SPAM Handler"
   Const sBccAddr = "spam@lolle.org"
   Dim a, b, c, i, j, strRegEx, Match, Matches, sMailTo, sTo, sFrom, sSubject, sBody, sURL, doMail, doURL
      doMail = a(0)
      doURL = a(1)
      doMail = True
      doURL = True
   If doMail Then
         If (UBound(a) > 0) Then
            For i = LBound(b) To UBound(b)
               If (InStr(1, b(i), "subject=", 1) > 0) Then sSubject = Replace(b(i), "subject=", "")
               If (InStr(1, b(i), "body=", 1) > 0) Then sBody = Replace(b(i), "body=", "")
         sTo = Trim(a(0))
         '   ==> This is a forwarded message ! <==
         '   X-Envelope-OriginalTo may contain more that one address, process all of them.
         c = Split(oMessage.HeaderValue("X-Envelope-OriginalTo"), ",")
         For j = LBound(c) To UBound(c)
            sFrom = Trim(c(j))
'        '   ==> This is the orginal inbound message ! <==
'        '   oMessage.Recipients(j).OriginalAddress may contain more that one address, process all of them.
'        For j = 0 To oMessage.Recipients.Count-1
'           sFrom = Trim(oMessage.Recipients(j).OriginalAddress)
               .AddRecipient sTo, sTo
               .AddRecipient sBcc, sBccAddr
               .FromAddress = sFrom
               .HeaderValue("To") = Chr(34) & sTo & Chr(34) & " <" & sTo & ">"
               .HeaderValue("From") = Chr(34) & sFrom & Chr(34) & " <" & sFrom & ">"
               If Not IsEmpty(sSubject) Then .Subject = sSubject
               If Not IsEmpty(sBody) Then .Body = sBody
               .Save
   If doURL Then
            .send ("")
IF you are using this code on the original message you need to put comments on this code section ...
            sFrom = Trim(c(j))
and remove the comments on this code section.
Normally Sub Unsubscribe() will unsubscribe from whatever is listed in the header "List-Unsubscribe". There is a way to control if Sub Unsubscribe() should only unsubscribe via mailto or via url.
Before running the rule that execute Sub Unsubscribe() you can "Set header value" [X-hMailServer-Unsubscribe] to:
0:0 ==> Do nothing.
1:0 ==> Unsubscribe MailTo only
0:1 ==> Unsubscribe URL only
1:1 ==> Unsubscribe MailTo and URL (default)
Happy hunting!
I assumes no responsibility or liability for any errors or omissions in the content of this post. The information contained in this post is provided on an "as is" basis with no guarantees of completeness, accuracy, usefulness or timeliness...
Re: Sub Unsubscribe
Post by palinka » 2019-06-05 22:19
Maybe a dumb question, buuutttt…..
Is there any chance that ANY original recipient could be from an outside domain?
Re: Sub Unsubscribe
Post by palinka » 2019-06-05 22:47
And don't forget this:
              .Save
Just in case they run a spam check. Empty body and subject don't do too well against that. Also, "Unsubscribe Me" vs plain "Unsubscribe" lets me know that the target subject was empty. :mrgreen:
Re: Sub Unsubscribe
Post by SorenR » 2019-06-05 23:36
2019-06-05 22:47
              .Save
Spammers doing spam checks on people unsubscribing their spam mails ... who would have thought :roll:
RFC6068 specify the layout of the MailTo: command and if they do not include "body=" or "subject=" then either they made provisions to receive the mail without triggering their SPAM system ... OR ... they don't really give a sh... er ... Damn.
Anyways, found another problem. Got hit today with an address "h-opxqe_ewljs_bavosdw_rirkjve_qx@bounce.pharmacy-zb.com.ua" ... "bounce.pharmacy-zb.com.ua" do not exist but "pharmacy-zb.com.ua" do ... so I'll be addressing this issue. Perhaps doing a DNS lookup before generating the mail and maybe ... maybe altering the domain by removing the obvious "bounce".
Re: Sub Unsubscribe
Post by palinka » 2019-06-06 02:42
2019-06-05 23:36
Certainly you've been on God's green earth long enough to know that quite often the left hand doesn't always talk to the right hand. :mrgreen:
Anyway, what's the point of unsubscribing spam? My trigger rule is for spam < delete threshold, so it's almost all commercial messages that are poorly formatted and get tripped up in SA jam-link and stuff like that. Plus some false positives from spamcop. Nothing malicious - the stuff you actually want to unsubscribe. Anyway, all the bases are covered with anything in the subject and body. Doesn't hurt anything and it could help in the left hand/ right hand/ no coordination organizations.
