MaxMinds GeoIP for local MySQL
Post by palinka » 2019-10-23 03:36
Downloads, unzips and loads MaxMinds GeoLite2 csv data into MySQL for local use.
Powershell:
SYNOPSIS
	Install MaxMindas geoip database on MySQL
DESCRIPTION
	Download and unzip MaxMinds cvs geoip data, then populate MySQL with csv data
INSTRUCTIONS
	REQUIRED: PSipcalc.ps1 : https://www.powershelladmin.com/wiki/Calculate_and_enumerate_subnets_with_PSipcalc : copy into same folder as this powershell script.
	Create or obtain credentials for database on which to install table `geo_ip`.
	Use SQL below to create columns on `geo_ip`.
	Update user variables.
	Run once per month via task scheduler.
SPECIAL INSTRUCTIONS
	Loading the database takes over one hour. Set your scheduled task for after midnight.
SQL
	CREATE TABLE IF NOT EXISTS `geo_ip` (
	  `minip` varchar(15) NOT NULL,
	  `maxip` varchar(15) NOT NULL,
	  `geoname_id` int(7) NOT NULL,
	  `countrycode` varchar(2) NOT NULL,
	  `countryname` varchar(48) NOT NULL
	) ENGINE=InnoDB DEFAULT CHARSET=latin1;
	COMMIT;
SAMPLE QUERY
	SELECT countrycode, countryname FROM geo_ip WHERE INET_ATON('182.253.228.22') >= INET_ATON(minip) AND INET_ATON('182.253.228.22') <= INET_ATON(maxip)
### User Variables ###
$GeoIPDir = 'C:\scripts\geolite2' 	# Location of files. No trailing "\" please
$MySQLAdminUserName = 'geoip'
$MySQLAdminPassword = 'supersecretpassword'
$MySQLDatabase = 'geoip'
$MySQLHost = 'localhost'
### End User Variables ###
Function MySQLQuery($Query) {
	$DBErrorLog = '$GeoIPDir\DBError.log'
	$ConnectionString = "server=" + $MySQLHost + ";port=3306;uid=" + $MySQLAdminUserName + ";pwd=" + $MySQLAdminPassword + ";database=" + $MySQLDatabase
	Try {
	  [void][System.Reflection.Assembly]::LoadWithPartialName("MySql.Data")
	  $Connection = New-Object MySql.Data.MySqlClient.MySqlConnection
	  $Connection.ConnectionString = $ConnectionString
	  $Connection.Open()
	  $Command = New-Object MySql.Data.MySqlClient.MySqlCommand($Query, $Connection)
	  $DataAdapter = New-Object MySql.Data.MySqlClient.MySqlDataAdapter($Command)
	  $DataSet = New-Object System.Data.DataSet
	  $RecordCount = $dataAdapter.Fill($dataSet, "data")
	  $DataSet.Tables[0]
	Catch {
	  Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Unable to run query : $query `n$Error[0]" | out-file $DBErrorLog -append
	Finally {
	  $Connection.Close()
#	Delete old files, download GeoLite2-Country-CSV zip file, uncompress, rename folder
Remove-Item -Recurse -Force $GeoIPDir\"GeoLite2-Country-CSV"
Remove-Item -Force -Path $GeoIPDir\"GeoLite2-Country-CSV.zip"
$url = "https://geolite.maxmind.com/download/geoip/database/GeoLite2-Country-CSV.zip"
$output = "$GeoIPDir\GeoLite2-Country-CSV.zip"
$MMErrorLog = "$GeoIPDir\error.log"
Start-BitsTransfer -Source $url -Destination $output
Expand-Archive $output -DestinationPath $GeoIPDir
$MMFolder = Get-ChildItem $GeoIPDir | Where-Object {$_.PSIsContainer -eq $true} | Sort-Object
If ($MMFolder -match 'GeoLite2-Country-CSV_[0-9]{8}'){
	Rename-Item -Path $GeoIPDir\$MMFolder $GeoIPDir\"GeoLite2-Country-CSV"
} Else {
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : `n$Error[0]" | Out-File $MMErrorLog
$PSIPCalc = '$GeoIPDir\PSipcalc.ps1'
$CountryBlocksIPV4 = '$GeoIPDir\GeoLite2-Country-CSV\GeoLite2-Country-Blocks-IPv4.csv'
$GeoIPObjects = import-csv -Path $CountryBlocksIPV4 -Delimiter "," -Header network,geoname_id,registered_country_geoname_id,represented_country_geoname_id,is_anonymous_proxy,is_satellite_provider
$GeoIPObjects | foreach-object {
	$Network = $_.network
	$GeoNameID = $_.geoname_id
	If ($GeoNameID -match '[0-9]{1,12}'){
		& $CIDRParse -NetworkAddress $Network | where-object {
			$MinIP = $_.NetworkAddress
			IF([string]::IsNullOrWhiteSpace($_.Broadcast)){
				$MaxIP = $_.NetworkAddress
			} Else {
				$MaxIP = $_.Broadcast
		$Query = "INSERT INTO geo_ip (minip,maxip,geoname_id) VALUES ('$MinIP','$MaxIP','$GeoNameID')"
		MySQLQuery($Query)
$CountryLocations = "$GeoIPDir\GeoLite2-Country-CSV\GeoLite2-Country-Locations-en.csv"
$GeoIPNameObjects = import-csv -Path $CountryLocations -Delimiter "," -Header geoname_id,locale_code,continent_code,continent_name,country_iso_code,country_name,is_in_european_union
$GeoIPNameObjects | foreach-object {
	$CountryCode = $_.country_iso_code
	$CountryName = $_.country_name
		$Query = "UPDATE geo_ip SET countrycode='$CountryCode', countryname='$CountryName' WHERE geoname_id='$GeoNameID'"
		MySQLQuery($Query)
EventHandlers.vbs:
'	GeoIP LOCAL Country CODE Lookup
Function GeoIPCC(sIPAddress)
	dim cn, rs, connectionString, m_CountryName, m_CountryCode
	set cn = CreateObject("ADODB.Connection")
	set rs = CreateObject("ADODB.Recordset")
	connectionString = "Driver={MariaDB ODBC 3.0 Driver}; Server=localhost; Database=geoip; User=geoip; Password=supersecretpassword;"
	cn.Open connectionString
	rs.open "SELECT countrycode, countryname FROM geo_ip WHERE INET_ATON('" & sIPAddress & "') >= INET_ATON(minip) AND INET_ATON('" & sIPAddress & "') <= INET_ATON(maxip)", cn, 3
	rs.MoveFirst
	while not rs.eof
		m_CountryCode = rs.Fields(0)
		m_CountryName = rs.Fields(1)
		rs.MoveNext
	wend
	cn.close
	GeoIPCC = m_CountryCode
'	GeoIP LOCAL Country NAME Lookup
Function GeoIPCN(sIPAddress)
	rs.MoveFirst
	while not rs.eof
		rs.MoveNext
	wend
	cn.close
	GeoIPCN = m_CountryName
Re: MaxMinds GeoIP for local MySQL
Post by palinka » 2019-10-23 04:03
Some pointers with error handling the vbs would be great.
Post by SorenR » 2019-10-23 10:18
Brainstorming ... Not fully testet ... The trick is how to use "ByVal" and "ByRef". :mrgreen:
ByVal = Parse a copy of the variable, does not change content of original variable. (Default)
ByRef = Parse reference to variable, will change content of the original variable.
Save code to "geoiptest.vbs" and try it from command prompt.
Sub GeoIPLookup(ByVal sIPAddress, ByRef m_CountryCode, ByRef m_CountryName)
    oConn.Open "Driver={MariaDB ODBC 3.0 Driver}; Server=localhost; Database=geoip; User=geoip; Password=supersecretpassword;"
    If oConn.State <> 1 Then
'       EventLog.Write( "Sub GeoIPLookup - ERROR: Could not connect to database" )
        WScript.Echo( "Sub GeoIPLookup - ERROR: Could not connect to database" )
        m_CountryCode = "XX"
        m_CountryName = "ERROR"
        Exit Sub
    m_CountryCode = "NF"
    m_CountryName = "NOT FOUND"
    Set oRecord = oConn.Execute("SELECT countrycode, countryname FROM geo_ip WHERE INET_ATON('" & sIPAddress & "') >= INET_ATON(minip) AND INET_ATON('" & sIPAddress & "') <= INET_ATON(maxip)")
    Do Until oRecord.EOF
        m_CountryCode = oRecord("countrycode")
        m_CountryName = oRecord("countryname")
        oRecord.MoveNext
    Loop
    oConn.Close
    Set oRecord = Nothing
'   Using GeoIPLookup
Dim sIPAddress, m_CountryCode, m_CountryName
Call GeoIPLookup("127.0.0.1", m_CountryCode, m_CountryName)
WScript.Echo( "m_CountryCode = " & m_CountryCode )
WScript.Echo( "m_CountryName = " & m_CountryName )
WScript.Quit 0
Post by palinka » 2019-10-23 12:39
2019-10-23 10:18
Awesome, man! Thanks! The test works like a charm.
Only one issue: NF = Norfolk Island :mrgreen:
Post by SorenR » 2019-10-23 17:35
2019-10-23 12:39
Like I wrote ... "Not fully tested" :mrgreen:
Post by palinka » 2019-10-24 02:10
Update - no longer need 2 files and some other changes. Next task is to figure out how to update the database incrementally because it takes forever to load it in full.
GeoLite2MySQL.ps1
.SYNOPSIS
.DESCRIPTION
.FUNCTIONALITY
	1) If geoip table does not exist, it gets created
	2) Deletes all data from table if exists (required when updating database)
	3) Downloads MaxMinds geolite2 cvs data as zip file, uncompresses it, then renames the folder
	4) Reads IPv4 cvs data, then calculates the lowest and highest IP from each network in the database
	5) Inserts lowest and highest IP calculated above and geoname_id from IPv4 cvs file
	6) Reads geo-name cvs file and updates each record with country code and country name based on the geoname_id
.NOTES
	Run once per month or once per 3 months via task scheduler
.EXAMPLE
	Example query to return countrycode and countryname from database:
### User Variables
# https://www.quadrotech-it.com/blog/querying-mysql-from-powershell/
	Try {
	  $Connection.Open()
	  $DataSet.Tables[0]
	Catch {
	Finally {
	  $Connection.Close()
# Function from: https://www.ryandrane.com/2016/05/getting-ip-network-information-powershell/
Function Get-IPv4NetworkInfo
    Param
        [Parameter(ParameterSetName="IPandMask",Mandatory=$true)]
        [ValidateScript({$_ -match [ipaddress]$_})]
        [System.String]$IPAddress,
        [System.String]$SubnetMask,
        [Parameter(ParameterSetName="CIDR",Mandatory=$true)]
        [ValidateScript({$_ -match '^((25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.){3}(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)/([0-9]|[0-2][0-9]|3[0-2])$'})]
        [System.String]$CIDRAddress,
        [Switch]$IncludeIPRange
    # If @CIDRAddress is set
    if($CIDRAddress)
         # Separate our IP address, from subnet bit count
        $IPAddress, [int32]$MaskBits =  $CIDRAddress.Split('/')
        # Create array to hold our output mask
        $CIDRMask = @()
        # For loop to run through each octet,
        for($j = 0; $j -lt 4; $j++)
            # If there are 8 or more bits left
            if($MaskBits -gt 7)
                # Add 255 to mask array, and subtract 8 bits
                $CIDRMask += [byte]255
                $MaskBits -= 8
            else
                # bits are less than 8, calculate octet bits and
                # zero out our $MaskBits variable.
                $CIDRMask += [byte]255 -shl (8 - $MaskBits)
                $MaskBits = 0
        # Assign our newly created mask to the SubnetMask variable
        $SubnetMask = $CIDRMask -join '.'
    # Get Arrays of [Byte] objects, one for each octet in our IP and Mask
    $IPAddressBytes = ([ipaddress]::Parse($IPAddress)).GetAddressBytes()
    $SubnetMaskBytes = ([ipaddress]::Parse($SubnetMask)).GetAddressBytes()
    # Declare empty arrays to hold output
    $NetworkAddressBytes   = @()
    $BroadcastAddressBytes = @()
    $WildcardMaskBytes     = @()
    # Determine Broadcast / Network Addresses, as well as Wildcard Mask
    for($i = 0; $i -lt 4; $i++)
        # Compare each Octet in the host IP to the Mask using bitwise
        # to obtain our Network Address
        $NetworkAddressBytes +=  $IPAddressBytes[$i] -band $SubnetMaskBytes[$i]
        # Compare each Octet in the subnet mask to 255 to get our wildcard mask
        $WildcardMaskBytes +=  $SubnetMaskBytes[$i] -bxor 255
        # Compare each octet in network address to wildcard mask to get broadcast.
        $BroadcastAddressBytes += $NetworkAddressBytes[$i] -bxor $WildcardMaskBytes[$i]
    # Create variables to hold our NetworkAddress, WildcardMask, BroadcastAddress
    $NetworkAddress   = $NetworkAddressBytes -join '.'
    $BroadcastAddress = $BroadcastAddressBytes -join '.'
    $WildcardMask     = $WildcardMaskBytes -join '.'
    # Now that we have our Network, Widcard, and broadcast information,
    # We need to reverse the byte order in our Network and Broadcast addresses
    [array]::Reverse($NetworkAddressBytes)
    [array]::Reverse($BroadcastAddressBytes)
    # We also need to reverse the array of our IP address in order to get its
    # integer representation
    [array]::Reverse($IPAddressBytes)
    # Next we convert them both to 32-bit integers
    $NetworkAddressInt   = [System.BitConverter]::ToUInt32($NetworkAddressBytes,0)
    $BroadcastAddressInt = [System.BitConverter]::ToUInt32($BroadcastAddressBytes,0)
    $IPAddressInt        = [System.BitConverter]::ToUInt32($IPAddressBytes,0)
    #Calculate the number of hosts in our subnet, subtracting one to account for network address.
    $NumberOfHosts = ($BroadcastAddressInt - $NetworkAddressInt) - 1
    # Declare an empty array to hold our range of usable IPs.
    $IPRange = @()
    # If -IncludeIPRange specified, calculate it
    if ($IncludeIPRange)
        # Now run through our IP range and figure out the IP address for each.
        For ($j = 1; $j -le $NumberOfHosts; $j++)
            # Increment Network Address by our counter variable, then convert back
            # lto an IP address and extract as string, add to IPRange output array.
            $IPRange +=[ipaddress]([convert]::ToDouble($NetworkAddressInt + $j)) | Select-Object -ExpandProperty IPAddressToString
    # Create our output object
    $obj = New-Object -TypeName psobject
    # Add our properties to it
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "IPAddress"           -Value $IPAddress
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "SubnetMask"          -Value $SubnetMask
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "NetworkAddress"      -Value $NetworkAddress
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "BroadcastAddress"    -Value $BroadcastAddress
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "WildcardMask"        -Value $WildcardMask
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "NumberOfHostIPs"     -Value $NumberOfHosts
    Add-Member -InputObject $obj -MemberType NoteProperty -Name "IPRange"             -Value $IPRange
    # Return the object
    return $obj
#	Delete old files if exist
#	Download latest GeoLite2 data
#	Rename folder so script can find it
} Else {
#	Create table if it doesn't exist
$GeoIPTable = "geo_ip"
$Query = "
	CREATE TABLE IF NOT EXISTS $GeoIPTable (
	  minip varchar(15) NOT NULL,
	  maxip varchar(15) NOT NULL,
	  geoname_id int(7) NOT NULL,
	  countrycode varchar(2) NOT NULL,
	  countryname varchar(48) NOT NULL
	COMMIT;
MySQLQuery($Query)
#	Delete all data on table (required when updating data)
$Query = "DELETE FROM $GeoIPTable"
MySQLQuery($Query)
#	Read IPv4 cvs file, convert CIDR network address to lowest and highest IPs in range, then insert into database
$CountryBlocksIPV4 = "$GeoIPDir\GeoLite2-Country-CSV\GeoLite2-Country-Blocks-IPv4-test.csv"
		Get-IPv4NetworkInfo -CIDRAddress $Network | ForEach-Object {
			$MaxIP = $_.BroadcastAddress
		$Query = "INSERT INTO $GeoIPTable (minip,maxip,geoname_id) VALUES ('$MinIP','$MaxIP','$GeoNameID')"
		MySQLQuery($Query)
#	Read country info cvs and insert into database
		$Query = "UPDATE $GeoIPTable SET countrycode='$CountryCode', countryname='$CountryName' WHERE geoname_id='$GeoNameID'"
		MySQLQuery($Query)
Post by palinka » 2019-10-24 20:17
Revamped for incremental updates. That's pretty necessary since it takes my not-so-super hardware over 1 hour to fill the database. Incremental updates take a couple of minutes.
Future updates/bug fixes will be on GitHub: https://github.com/palinkas-jo-reggelt/GeoLite2MySQL
Features:
* You only fill in a few user variables - completely automated
* Script will create table
* Script will download files
* Automatically deletes old files and renames new ones as necessary
* Compares old to new for incremental table fill
* Run via scheduled task every Wednesday (MaxMinds releases data updates every Tuesday)
Sample query:
EventHandlers.vbs subroutine (Thanks, Soren!)
        Exit Sub
    m_CountryCode = "NX"
        oRecord.MoveNext
    Loop
    oConn.Close
Call subroutine:
	Dim m_CountryCode, m_CountryName
	Call GeoIPLookup(oClient.IPAddress, m_CountryCode, m_CountryName)
GeoLite2MySQL.ps1
.SYNOPSIS
.DESCRIPTION
.FUNCTIONALITY
	2) Deletes old files, renames previously "new" "old" in order to compare
	4) Compares new and old data for incremental changes
	5) Reads IPv4 cvs data, then calculates the lowest and highest IP from each network in the database
	6) Deletes obsolete records
	7) Inserts lowest and highest IP in range and geoname_id from IPv4 cvs file
	8) Reads geo-name cvs file and updates each record with country code and country name based on the geoname_id
	9) Includes various error checking to keep from blowing up a working database on error
.NOTES
	Run every Wednesday via task scheduler (MaxMinds releases updates on Tuesdays)
	Initial loading of the database takes over one hour - subsequent updates are incremental, so they only take a few minutes
.EXAMPLE
$GeoIPDir = 'C:\scripts\geolite2' 	# Location of files. No trailing "\" please. Please make sure folder exists.
	Try {
	  $Connection.Open()
	  $DataSet.Tables[0]
	Catch {
	Finally {
	  $Connection.Close()
# https://www.ryandrane.com/2016/05/getting-ip-network-information-powershell/
    Param
    if($CIDRAddress)
        $CIDRMask = @()
            if($MaskBits -gt 7)
                $MaskBits -= 8
            else
                $MaskBits = 0
    $IPRange = @()
    # Return the object
    return $obj
$ErrorLog = "$GeoIPDir\ErrorLog.log"
$ToAddIPv4 = "$GeoIPDir\ToAddIPv4.csv"
$ToDelIPv4 = "$GeoIPDir\ToDelIPv4.csv"
If (Test-Path $GeoIPDir\"GeoLite2-Country-CSV-Old") {Remove-Item -Recurse -Force $GeoIPDir\"GeoLite2-Country-CSV-Old"}
If (Test-Path $GeoIPDir\"GeoLite2-Country-CSV.zip") {Remove-Item -Force -Path $GeoIPDir\"GeoLite2-Country-CSV.zip"}
If (Test-Path $ToAddIPv4) {Remove-Item -Force -Path $ToAddIPv4}
If (Test-Path $ToDelIPv4) {Remove-Item -Force -Path $ToDelIPv4}
If (Test-Path "$GeoIPDir\GeoLite2-Country-CSV-New") {Rename-Item -Path "$GeoIPDir\GeoLite2-Country-CSV-New" "$GeoIPDir\GeoLite2-Country-CSV-Old"}
#	Check to make sure files deleted
If ((Test-Path $ToAddIPv4) -or (Test-Path $ToDelIPv4)){
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Failed to delete old ToDelIPv4.csv and/or ToAddIPv4.csv" | out-file $ErrorLog -append
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Quitting Script" | out-file $ErrorLog -append
	Exit
#	Create new comparison CSVs
New-Item $ToAddIPv4 -value "network,geoname_id,registered_country_geoname_id,represented_country_geoname_id,is_anonymous_proxy,is_satellite_provider`n"
New-Item $ToDelIPv4 -value "network,geoname_id,registered_country_geoname_id,represented_country_geoname_id,is_anonymous_proxy,is_satellite_provider`n"
#	Check to make sure new comparison CSVs created
If ((-not (Test-Path $ToAddIPv4)) -or (-not (Test-Path $ToDelIPv4))){
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : $ToAddIPv4 and/or $ToDelIPv4 do not exist" | out-file $ErrorLog -append
	Exit
#	Download latest GeoLite2 data and unzip
Try {
	Start-BitsTransfer -Source $url -Destination $output -ErrorAction Stop
	Expand-Archive $output -DestinationPath $GeoIPDir -ErrorAction Stop
Catch {
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Unable to download and/or unzip : `n$Error[0]" | out-file $ErrorLog -append
	Exit
Get-ChildItem $GeoIPDir | Where-Object {$_.PSIsContainer -eq $true} | ForEach {
	If ($_.Name -match 'GeoLite2-Country-CSV_[0-9]{8}') {
		$FolderName = $_.Name
Rename-Item "$GeoIPDir\$FolderName" "$GeoIPDir\GeoLite2-Country-CSV-New"
# If new downloaded folder does not exist or could not be renamed, then throw error
If (-not (Test-Path "$GeoIPDir\GeoLite2-Country-CSV-New")){
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : $GeoIPDir\GeoLite2-Country-CSV-New does not exist" | out-file $ErrorLog -append
	Exit
$Query = "
	COMMIT;
MySQLQuery($Query)
#	Compare Old and New data for changes
If ((Test-Path "$GeoIPDir\GeoLite2-Country-CSV-Old") -and (Test-Path "$GeoIPDir\GeoLite2-Country-CSV-New")){
$CompareCSVIPV4Old = Get-Content "$GeoIPDir\GeoLite2-Country-CSV-Old\GeoLite2-Country-Blocks-IPv4.csv"
$CompareCSVIPV4New = Get-Content "$GeoIPDir\GeoLite2-Country-CSV-New\GeoLite2-Country-Blocks-IPv4.csv"
	Compare-Object $CompareCSVIPV4Old $CompareCSVIPV4New | ForEach-Object {
		If ($_.SideIndicator -eq '=>') {
			Write-Output $_.InputObject | Out-File $ToAddIPv4 -Encoding ASCII -Append
		} Else {
			Write-Output $_.InputObject | Out-File $ToDelIPv4 -Encoding ASCII -Append
#	If database previously loaded then use ToAdd/ToDel to make incremental changes - otherwise, load entire CSV into database
#	First, check to see database has previously loaded entries
$Query = "SELECT COUNT(minip) AS numrows FROM $GeoIPTable"
MySQLQuery($Query) | ForEach {
	$EntryCount = $_.numrows
#	If pass 3 tests: exists old folder, exists new folder, database previously populated - THEN proceed to load table from incremental
If ((Test-Path "$GeoIPDir\GeoLite2-Country-CSV-Old") -and (Test-Path "$GeoIPDir\GeoLite2-Country-CSV-New") -and ($EntryCount -gt 0)){
	# 	Load table from incremental:
	# 	Read ToDelIPv4 cvs file, convert CIDR network address to lowest and highest IPs in range, then delete from database
	$GeoIPObjects = import-csv -Path $ToDelIPv4 -Delimiter "," -Header network,geoname_id,registered_country_geoname_id,represented_country_geoname_id,is_anonymous_proxy,is_satellite_provider
			$Query = "DELETE FROM $GeoIPTable WHERE minip='$MinIP' AND maxip='$MaxIP'"
			MySQLQuery($Query)
	# 	Read ToAddIPv4 cvs file, convert CIDR network address to lowest and highest IPs in range, then insert into database
	$GeoIPObjects = import-csv -Path $ToAddIPv4 -Delimiter "," -Header network,geoname_id,registered_country_geoname_id,represented_country_geoname_id,is_anonymous_proxy,is_satellite_provider
			MySQLQuery($Query)
	$CountryLocations = "$GeoIPDir\GeoLite2-Country-CSV-New\GeoLite2-Country-Locations-en.csv"
			$Query = "UPDATE $GeoIPTable SET countrycode='$CountryCode', countryname='$CountryName' WHERE geoname_id='$GeoNameID' AND countrycode='' AND countryname=''"
			MySQLQuery($Query)
#	If pass 2 tests: exists new folder, database UNpopulated - then proceed to load table as new
ElseIf ((Test-Path "$GeoIPDir\GeoLite2-Country-CSV-New") -and ($EntryCount -eq 0)){
	# 	Load table from NEW:
	# 	Read cvs file, convert CIDR network address to lowest and highest IPs in range, then insert into database
	$CountryBlocksIPV4 = "$GeoIPDir\GeoLite2-Country-CSV-New\GeoLite2-Country-Blocks-IPv4.csv"
			MySQLQuery($Query)
			MySQLQuery($Query)
#	Else Exit since neither incremental nor new load can be accomplished
Else {
	Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Unable to complete database load : Either Old or New data doesn't exist." | out-file $ErrorLog -append
	Exit
.SYNOPSIS
.DESCRIPTION
.FUNCTIONALITY
.NOTES
.EXAMPLE
### User Variables
#	Function from: https://www.quadrotech-it.com/blog/querying-mysql-from-powershell/
	Try {
	  $Connection.Open()
	  $DataSet.Tables[0]
	Catch {
	Finally {
	  $Connection.Close()
    Param
    if($CIDRAddress)
        $CIDRMask = @()
            if($MaskBits -gt 7)
                $MaskBits -= 8
            else
                $MaskBits = 0
    $IPRange = @()
    # Return the object
    return $obj
} Else {
$Query = "
	COMMIT;
MySQLQuery($Query)
MySQLQuery($Query)
		MySQLQuery($Query)
		MySQLQuery($Query)
Post by palinka » 2019-10-25 16:51
Added primary key to db table. Queries now 5 times faster.
Before: 1.5 seconds
After: 0.3 seconds
Post by palinka » 2019-10-25 17:35
Holy crap! I've been messing with the query and with a little googling got the time down to 0.05 seconds!
Sample query:
SELECT countrycode, countryname FROM `geoip` WHERE INET_ATON('14.1.224.229') BETWEEN INET_ATON(minip) AND INET_ATON(maxip) LIMIT 1
The "LIMIT 1" does the trick. It apparently cuts off the table scan when the first result is found. There should be only one result anyway, so this is perfect.
Went from 1.5 seconds to 0.3 seconds to 0.05 seconds. Not bad...
EDIT - testing an IP near the end of the table results in up to 0.9 seconds scan time. Still not bad. The lower the IP, the faster the query.
Post by palinka » 2019-10-25 22:18
I'm no MySQL expert. I looked around some more and found an even more efficient query.
SELECT * FROM (SELECT * FROM geoip WHERE INET_ATON('223.114.216.150') <= INET_ATON(maxip) LIMIT 1) AS A WHERE INET_ATON(minip) <= INET_ATON('223.114.216.150')
The IP is high, so its the longest possible query time. I ran it several times. The highest query time was 0.38 seconds. When the IP is low (like 15.15.15.15), the query time is consistently below 0.01 seconds. :mrgreen:
Post by palinka » 2019-10-26 14:20
2019-10-25 22:18
This ^^ does not work :(
It works sometimes but not all the time. I don't know why. Too bad.
Post by palinka » 2019-10-26 20:04
Bug fix update. I think this project is finished.
Files: https://github.com/palinkas-jo-reggelt/GeoLite2MySQL
Post by palinka » 2019-10-27 14:15
2019-10-26 14:20
2019-10-25 22:18
It turns out that I had a syntax error and ^this^ is indeed the fastest query (that I can come up with).
SELECT countrycode, countryname FROM (SELECT * FROM geoip WHERE INET_ATON('223.114.216.150') <= maxipaton LIMIT 1) AS A WHERE minipaton <= INET_ATON('223.114.216.150')
Plus, I added columns "minipaton" and "maxipaton" which are INET_ATON(minip) and INET_ATON(maxip) already tabulated, so it should save a millisecond or two on the query. :D
Post by palinka » 2019-10-27 17:13
Holy cow - I just boosted query speed with a nitrous oxide injected supercharger strapped to a rocket engine by changing the primary key to maxipaton. Now ALL queries are UNDER 0.01 seconds. :mrgreen:
So much to learn about database design.
Post by palinka » 2019-10-30 05:12
Just ran the first update. Maxminds releases updates weekly. I figured there wouldn't be many changes - I mean, how many IPs get swapped around between countries weekly? But there were about 2,000 changes. I looked at a few randomly. One went from USA to Russia, one went from Taiwan to Singapore, Korea to Singapore. Who knew these things bounced around so much?
Post by mattg » 2019-10-30 06:56
I don't think that they do...
Post by palinka » 2019-10-30 10:57
2019-10-30 06:56
Then maxminds had 2000 corrections?
I think many of these networks are probably multinational corporate owned and get shuffled around as needed. Some of the blocks are as small as a single ip.
Post by palinka » 2019-10-31 00:12
I added email notification with counts of the various things getting added and deleted during update.
Post by palinka » 2019-11-13 14:05
This week's update was a success. Everything worked and I got the email notification:
GeoIP update start: 11/13/2019 1:30:01 AM
339,851 : (A) Records in database prior to update
  5,809 : (B) Records removed from database
  7,637 : (C) Records inserted into database
341,679 : Tabulated (A - B + C) number of records (should match NEW IPV4 csv)
341,679 : Actual number of records in NEW IPV4 csv
341,679 : Queried number of records in database (should match NEW IPV4 csv)
GeoIP database update SUCCESS. All records accounted for.
GeoIP update successful.
GeoIP update finish: 11/13/2019 3:11:15 AM
Completed update in -01:41:14
I just have to fix the way the time to complete is reported.
Also, it takes a LOOOOOOONG time. Part of that is my wimpy hardware, I assume. I don't know how to make it more efficient. The tables and csv are pretty big. It takes a while just to read the full csv - at 340+k lines - to look for changes. I guess I don't really care how long it takes (within reason) as long as it gets the job done accurately.
Post by palinka » 2019-12-06 14:35
Looks like practically every week there are a couple thousand changes to the database.
GeoIP update start: 12/4/2019 1:30:02 AM
342,554 : (A) Records in database prior to update
  1,405 : (B) Records removed from database
  2,748 : (C) Records inserted into database
343,897 : Tabulated (A - B + C) number of records (should match NEW IPV4 csv)
343,897 : Actual number of records in NEW IPV4 csv
343,897 : Queried number of records in database (should match NEW IPV4 csv)
GeoIP update finish: 12/4/2019 2:11:31 AM
Completed update in 0 hours 41 minutes 29 seconds
Post by SorenR » 2019-12-06 14:54
2019-12-06 14:35
According to RIPE: "we made our final /22 IPv4 allocation from the last remaining addresses in our available pool."
So... Europe do not have any IPv4 addresses left. Time to trade!
These are just some of them...
https://iptrading.com/
https://www.ipv4connect.com/
https://ipv4brokers.net
Expect IPv4 allocations to shift continents with a snap of your fingers :mrgreen:
Post by palinka » 2019-12-06 15:16
2019-12-06 14:54
2019-12-06 14:35
That definitely explains a lot. And also shows why it's good to stay updated weekly. :mrgreen:
Post by SorenR » 2019-12-06 15:24
2019-12-06 15:16
2019-12-06 14:54
2019-12-06 14:35
Perhaps daily or hourly ??
Post by palinka » 2019-12-06 16:39
2019-12-06 15:24
2019-12-06 15:16
2019-12-06 14:54
I would, but maxmind only releases updates weekly. On Tuesdays, normally, so my scheduled task runs on Wednesday mornings.
Post by palinka » 2020-01-03 23:07
On Dec 31, MaxMind started requiring a license key to download the GeoLite2. Therefore, this week's update failed. I also discovered an issue in the script with renaming the extracted data folder.
More info on the change to license key API: https://blog.maxmind.com/2019/12/18/sig ... databases/
Updated scripts are here: https://github.com/palinkas-jo-reggelt/GeoLite2MySQL
Instructions for obtaining license key:
1) Register for a GeoLite2 account here: https://www.maxmind.com/en/geolite2/signup
2) After successful login to your MaxMind account, generate a new license key (Services > License Key > Generate New Key)
3) Update the license key variable at the top of GeoLite2MySQL.ps1
The license key is free.
Post by mattg » 2020-01-04 00:47
2020-01-03 23:07
For the moment, I'd suggest
Post by palinka » 2020-01-04 00:58
2020-01-04 00:47
2020-01-03 23:07
From what I read, it has to do with complying with regulation. It only applies to the free ones because a license/api key - and therefore also consent to their terms of agreement - has always been required for the pay versions.
I don't see this as a step toward putting the geolite2 databases behind a paywall. They've had a two tiered system for a while. The pay-for databases with a lot more info and the free ones with a lot less info.
Time will tell, I guess.
Post by palinka » 2020-03-24 22:32
I just committed a big update with bug fixes and a lot of cleanup.
* Fixed a regex bug that caused certain networks to be skipped when inserting into database
* Added choice of debug verbosity: to console, file, both or none (you still get email report no matter what you choose)
* Cleaned up debugging greatly
* Separated database and scheduled task creation into new SetupGeoLite2SQL.ps1
* Got rid of "Initial Load" altogether (a remnant from earlier code logic) - script is the same for first time database loading so "initial loading" was just redundant code
https://github.com/palinkas-jo-reggelt/GeoLite2SQL
Corona-chan is proving to be valuable for some things. :mrgreen:
Post by palinka » 2020-03-26 03:38
For some reason, MaxMind leaves a couple of geoname_id entries blank. Added a routine to retrieve this missing information from ip-api.com in order to make the database complete. The routine looks up json data from ip-api, then cross references the countrycode against the MaxMind country name csv and inserts the correct geoname_id into the database. Then, when the country name info gets loaded later in the script, the correct country name and country code get inserted into the database (instead of getting wiped via update with no information).
Files: https://github.com/palinkas-jo-reggelt/GeoLite2SQL
Post by palinka » 2020-10-04 04:29
Updated tonight.
* fixed a divide by 0 bug that only presented if option console verbose was enabled
* updated email function to attach debug log
* housekeeping
Post by palinka » 2020-10-07 16:02
I optimized a query and finally got a chance to test it last night (with the new weekly release of MaxMind data). 10 times faster now. YUUUUGE improvement.
I'm going to experiment with just deleting all the data and starting from scratch. That would remove several steps involving manipulating the CSVs and could further speed things up.
Post by palinka » 2020-10-08 03:25
2020-10-07 16:02
Well that was a bust. Good news is the most recent one works better than ever.
