Block attack based on Greeting not having effect
Jorgo
Post by Jorgo » 2019-12-27 18:29
First of all, please bear with me as I am practically a noob when it comes to programming. That said, I have tried a script which is supposed to auto ban attackers when they use weird identification in their HELO/EHLO but it seems to have no effect (no ban is resulting). This is the script (substituted my password):
       .Global = False
       .Pattern = strRegEx
       .IgnoreCase = True
       Lookup = .Test(strMatch)
Sub OnHELO(oClient)
      ' Exclude local LAN from test
      If (Left(oClient.IPAddress, 10) = "192.168.1.") Then Exit Sub
      strRegEx = "(127\.0\.0\.1|mail\.jorgo\.org|mydomain|User|scanner\.sslsonar\.org|zg-0911)"
      If (Lookup(strRegEx, oClient.HELO) = True) Then
          ' Validate HELO/EHLO greeting
          Result.Value = 2
          Result.Message = "5.7.1 Your access to this mail system has been rejected due to the sending\n" &_
                           "      MTA's poor reputation. If you believe that this failure is in error,\n" &_
                           "      please contact the intended recipient via alternate means."
          EventLog.Write(HELO & vbTab & oClient.IPAddress & vbTab & oClient.Port)
          Call AutoBan(oClient.IPAddress, "HELO " & oClient.HELO, 2, "d")
' sType can be one of the following:
' "yyyy" Year, "m" Month, "d" Day, "h" Hour, "n" Minute, "s" Second
    Call oApp.Authenticate(ADMINISTRATOR, MYPASSWORD)
    With LockFile(oApp.Settings.Directories.TempDirectory & "\autoban.lck")
       On Error Resume Next
       If (oApp.Settings.SecurityRanges.ItemByName("Auto-ban: (" & sReason & ") " & sIPAddress) Is Nothing) Then
             .Name = "Auto-ban: (" & sReason & ") " & IPAddress
             .LowerIP = sIPAddress
             .UpperIP = sIPAddress
             .Priority = 20
             .Expires = True
             .Save
       On Error Goto 0
       .Close
I guess ADMINISTRATOR needs no replacing... and sType and iDuration values are read from the database?
I've already added
[Settings]
DisableAUTHList=25
to hmailserver.ini so no real harm can be done there but I would still like to ban them. Connection attempts look like this:
"TCPIP"	728	"2019-12-27 17:23:50.013"	"TCP - 193.56.28.68 connected to 192.168.1.185:25."
"SMTPD"	728	11	"2019-12-27 17:23:50.014"	"193.56.28.68"	"SENT: 220 xxlspeed.spdns.de ESMTP"
"SMTPD"	10100	11	"2019-12-27 17:23:50.059"	"193.56.28.68"	"RECEIVED: EHLO User"
"SMTPD"	10100	11	"2019-12-27 17:23:50.059"	"193.56.28.68"	"SENT: 250-xxlspeed.spdns.de[nl]250-SIZE 20480000[nl]250 HELP"
"SMTPD"	6176	11	"2019-12-27 17:23:50.114"	"193.56.28.68"	"RECEIVED: RSET"
"SMTPD"	6176	11	"2019-12-27 17:23:50.115"	"193.56.28.68"	"SENT: 250 OK"
"SMTPD"	728	11	"2019-12-27 17:23:50.158"	"193.56.28.68"	"RECEIVED: AUTH LOGIN"
"SMTPD"	728	11	"2019-12-27 17:23:50.159"	"193.56.28.68"	"SENT: 504 Authentication not enabled."
"SMTPD"	4460	11	"2019-12-27 17:23:50.202"	"193.56.28.68"	"RECEIVED: QUIT"
"SMTPD"	4460	11	"2019-12-27 17:23:50.203"	"193.56.28.68"	"SENT: 221 goodbye"
Can you spot anything in the code which I need to remedy? Thanks in advance!
Re: Block attack based on Greeting not having effect
Post by SorenR » 2019-12-27 18:56
I presume this is supposed to be "oClient.HELO" since there is no variable called "HELO" :roll:
Did you remove the "ERROR" lines in the output?
You'd better get your reading glasses... sType and iDuration are passed in the call to AutoBan.
Jorgo
Post by Jorgo » 2019-12-27 19:04
I changed that one line to
          EventLog.Write(oClient.HELO & vbTab & oClient.IPAddress & vbTab & oClient.Port)
Still no ban, and no errors are written to the log. The Attacker tries every 6 minutes so I have lots of tries to test :-)
So, do I have to insert actual values here
like
.ExpiresTime = DateAdd(m, 1, Now())
? Again, excuse me for asking stupid questions.
Post by SorenR » 2019-12-28 00:13
Jorgo wrote:
2019-12-27 19:04
like
1)
strRegEx string use of parantheses fixed.
2)
ADMINISTRATOR is a constant = "Administrator"
PASSWORD is a constant = "hMailserver Administrator password"
3)
means 2 days...
You should use
Call AutoBan(oClient.IPAddress, "HELO " & oClient.HELO, 1, "m")
I never really expected it would be that hard to understand when I made these functions... You are the first!
4) This should be functioning code. You have mixed revisions of code that could never work together.
REMEMBER! You must use a version of hMailServer modified by RvdH to include the "Sub OnHELO(oClient)" trigger OR the latest 5.7 64bit alpha version of hMailServer.
'   COM authentication
Private Const ADMINISTRATOR = "Administrator"
Private Const MYPASSWORD = "hMailServer Administrator Password"
Function Wait(sec)
        .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
Function LockFile(strPath)
    Const Append = 8
    Const Unicode = -1
    Dim i
        For i = 0 To 30
            Err.Clear
            Set LockFile = .OpenTextFile(strPath, Append, True, Unicode)
            If (Not Err.Number = 70) Then Exit For
            Wait(1)
    If (Err.Number = 70) Then
        Err.Clear
    ElseIf (Err.Number <> 0) Then
        Err.Clear
    On Error Goto 0
        .Pattern = strRegEx
        .Global = False
        .MultiLine = True
        .IgnoreCase = True
Sub OnHELO(oClient)
      strRegEx = "(127\.0\.0\.1)|(mail\.jorgo\.org)|(mydomain)|(User)|(scanner\.sslsonar\.org)|(zg-0911)"
          Result.Value = 2
             .Priority = 20
             .Expires = True
             .Save
       On Error Goto 0
       .Close
And YES... I initially wrote the OnHELO trigger for my 5.4.2 hMailServer AND the vbs code around it like the script code above.
Jorgo
Post by Jorgo » 2019-12-28 02:02
2019-12-28 00:13
I come from a completely different discipline than mathematics, I'm much better at interpreting the law than programming code. Here I learn best from examples and I am very grateful for your explanations. I was able to make it work by updating to the latest x64 version and now everything works as expected.
Thanks again for your updated code and should you ever need legal expertise in data protection or IT matters maybe I can return the favour! :D
Post by palinka » 2019-12-28 03:09
2019-12-28 00:13
Well, not exactly the first. :mrgreen:
Post by SorenR » 2019-12-28 04:37
Jorgo wrote:
2019-12-28 02:02
2019-12-28 00:13
Glad that it worked for you in the end. You mention law ... EU law?
Jorgo
Post by Jorgo » 2019-12-28 12:47
Yup.
Post by mattg » 2019-12-29 01:21
ALSO,
I find that with ONHelo sometimes the sending server has no greeting, when there is no security on the connection (SSL/TLS), but when asked to secure a connection via StartTLS, that the sending server THEN sends a greeting
Post by SorenR » 2019-12-29 03:31
2019-12-29 01:21
ALSO,
Not good... No greeting with EHLO/HELO is non-compliant behavior and should be rejected on the spot.
Post by jimimaseye » 2019-12-29 12:02
But, although technically non- compliant to RFC, the sender and connecting server may be genuine and rejecting it may mean lost valuable emails. The sender may not be aware of the cause of his rejection and not be associated to the admin of the sending server. Given that is is compliant once TLS is established would it not be prudent to ignore? (We know the world of email is full of non compliance. Eg, Just see how many servers rejects rfc compliant email addresses with a "+" or "-" in it).
Post by palinka » 2019-12-29 15:46
2019-12-29 01:21
ALSO,
I have never once seen this and this is something I track closely with my firewall ban project - and through my logging. One of my filters validates helo ("HELO-Inv")
I agree with Soren. Empty helo = rejectionable event.
Post by SorenR » 2019-12-29 22:18
Well....
S: 220 smtp.server.com Simple Mail Transfer Service Ready
C: EHLO client.example.com
S: 250-smtp.server.com Hello client.example.com
S: 250-SIZE 1000000
S: 250-AUTH LOGIN PLAIN CRAM-MD5
S: 250-STARTTLS
S: 250 HELP
C: STARTTLS
S: 220 TLS go ahead
S: 250-SIZE 1000000
S: 250 HELP
Tell me HOW the connecting server can know in advance to use TLS thus it does not need to send a RFC compliant EHLO <greeting> at initial contact...
No greeting, no cookie!
Post by jimimaseye » 2019-12-29 22:25
Perhaps matt meant that the EHLO word was received but no domain or ip address following?
Post by SorenR » 2019-12-29 22:37
2019-12-29 22:25
I got that much, it's still non-compliant regardless of TLS in any way or shape.
Post by mattg » 2019-12-30 01:03
My comment was more about the OnHELO not recording the HELO, rather than the server not sending a HELO
I've been looking in my logs
No recent examples that I can see
viewtopic.php?f=2&t=32833&hilit=greylis ... st#p205051
That was July 2018
Just looking through my old logs, I re-started recording OnHELO responses about then and can't see a single instance of HELO not being recorded. I can't see when I was previously recording the OnHELO results, but was obviously a long time before that.
I'm thinking my experience of not seeing a value at OnHELO may have been when I first started using that, long long ago. I expect that in it's current form, OnHELO works as expected.
I found this trying to implement on-the-fly greylist >> whitelisting for large mail senders like gMail, office365 etc
https://www.hmailserver.com/forum/viewt ... 21&t=29238
It looks like back then (Feb 2016) I was using OnSMTPdata before OnHELO was implemented, so I really may have remembered this incorrectly. Looks like this is WHY OnHELO was developed.
(Fun excuse to see how far back my logs go - I have logs going back to December 2011)
Jorgo
Post by Jorgo » 2019-12-30 02:58
@SorenR
Could the code you posted be changed to ban the whole subnet of a presumed spammer/attacker? Right now it only bans the specific IP adress but I've seen some instances where the same thing repeats from another adress in the same /24 subnet. Expanding the ban to the whole /24 subnet as a preemptive strike would be nice and keep the ban list smaller....
Post by SorenR » 2019-12-30 04:28
Jorgo wrote:
2019-12-30 02:58
@SorenR
Call BanClassC(oClient.IPAddress)
Function BanClassC(sIPAddress) : BanClassC = False
    Dim a : a = Split(sIPAddress, ".")
    Dim strBan : strBan = "( Class C Network ) " & a(0) & "." & a(1) & "." & a(2) & ".0 - " & a(0) & "." & a(1) & "." & a(2) & ".255"
    Dim oSecurityRange : Set oSecurityRange = oApp.Settings.SecurityRanges.ItemByName(strBan)
    If Err.Number = 9 Then
            .Name = strBan
            .LowerIP = a(0) & "." & a(1) & "." & a(2) & ".0"
            .UpperIP = a(0) & "." & a(1) & "." & a(2) & ".255"
            .Priority = 20
            .Expires = True
            .ExpiresTime = DateAdd("m", 1, Now())
            .Save
        BanClassC = True
    On Error Goto 0
    Set oApp = Nothing
Post by palinka » 2019-12-30 04:55
Jorgo wrote:
2019-12-30 02:58
@SorenR
You could try this: http://hmailserver.com/forum/viewtopic.php?f=20&t=34599
It doesn't ban entire ranges, which could end up in false positives, but rather uses HELO domain presented to determine spamminess. It works well with a certain type of brand new spammers (not yet listed by spamhaus, etc.)
Jorgo
Post by Jorgo » 2020-01-06 11:51
I just found out that blocking 127.0.0.1 in HELO is not a good idea, since my own smartphone software (K9-Mail) uses this greeting...
Post by SorenR » 2020-01-06 16:00
Jorgo wrote:
2020-01-06 11:51
Perhaps you should spend some time figuring out WHY your phone identifies itself as 127.0.0.1 as this is clearly VERY wrong!
RFC says "EHLO" SP ( Domain / address-literal ) CRLF
"Domain" is the client FQDN. Sometimes the workstation hostname is used and a non-compliant hostname can be handled using a whitelist.
"address-literal" uses four small decimal integers separated by dots and enclosed by brackets such as [123.255.37.2]
IF a usable FQDN (or hostname) is not obtainable, the greeting should contain "[<client ip address>]" to stay RFC compliant.
127.0.0.1 is generally regarded as a source of SPAM as it is a NON-routable IP address and thus cannot be the origin of an IP packet sent to a remote IP address.
It seems the devs of K9 are illiterate or simply stupid...
https://github.com/k9mail/k-9/issues/1399
Jorgo
Post by Jorgo » 2020-01-18 19:12
Today I've seen this:
"SMTPD"	4420	119	"2020-01-18 15:39:30.541"	"223.71.167.164"	"RECEIVED: EHLO []"
How would I add an empty EHLO to the regEx String?
Post by SorenR » 2020-01-18 19:22
Jorgo wrote:
2020-01-18 19:12
It's not empty... It's a pair of brackets ;-)
Post by palinka » 2020-01-18 21:34
Jorgo wrote:
2020-01-18 19:12
Empty regex string. :D
Would not pickup "[]".
Jorgo
Post by Jorgo » 2020-01-18 22:08
Thanks guys! Of course, having no clue I assumed that the brackets were added by the server software to show the greeting enclosed within.
Post by SorenR » 2020-01-18 23:18
2020-01-18 21:34
Jorgo wrote:
2020-01-18 19:12
Wrong... The brackets are NOT added by hMailServer.
The RFC says brackets are ONLY used with address literals like "[223.71.167.164]"...
Jorgo
Post by Jorgo » 2020-02-07 00:06
Got another idea... would I be correct in assuming that any valid greeting needs to have a period somewhere?
If so, is there a REGEX that matches a string with a period explicitly missing?
Hm... probably this one
including empty string
Post by mattg » 2020-02-07 01:58
DO iPv6 Addresses have a period (.) in them, or do they have colons (:)?
I have many machines that send automated emails via scripts, via my server that simply have a local computer name as the greeting.
This would be things like 'DB-Server' in a workgroup with no automatic FQDN added to the server name.
Post by SorenR » 2020-02-07 03:09
Jorgo wrote:
2020-02-07 00:06
IF strRegEx is true for oClient.HELO then greeting is RFC Compliant - OK - Fine - As it should be - H.U.A.
For my own server, my explicit whitelist and the above RegEx determine if message initially is to be treated as SPAM or worse.
P.S.: I don't use IPv6.
