Problem with AutoBan
adrianmihai83
Post by adrianmihai83 » 2020-02-05 20:11
I am facing the following problem when trying to add to IpRanges some ip's. I have the latest RvdH build.
On short, the part for autoban is:
Private Const PASSWORD = "my-password"
Private Const TEMPDIR  = "C:\Program Files (x86)\hMailServer\Temp"
'	Function LockFile - https://www.hmailserver.com/forum/viewtopic.php?p=212052
Function LockFile(strPath)
   Const Append = 8
   Const Unicode = -1
   Dim i
   On Error Resume Next
      For i = 0 To 30
         Err.Clear
         Set LockFile = .OpenTextFile(strPath, Append, True, Unicode)
         If (Not Err.Number = 70) Then Exit For
         Wait(1)
   If (Err.Number = 70) Then
      Err.Clear
   ElseIf (Err.Number <> 0) Then
      Err.Clear
   On Error Goto 0
'	Function AutoBan - https://www.hmailserver.com/forum/viewtopic.php?p=212052
   With LockFile(TEMPDIR & "\autoban.lck")
      Dim oSecurityRange : Set oSecurityRange = oApp.Settings.SecurityRanges.ItemByName("(" & sReason & ") " & sIPAddress)
      If Err.Number = 9 Then
            .LowerIP = sIPAddress
            .UpperIP = sIPAddress
            .Priority = 20
            .Expires = True
            .Save
         AutoBan = True
      On Error Goto 0
      .Close
   Set oApp = Nothing
And I call the function as follows:
Call AutoBan(oClient.IPAddress, oGeoip("countryCode") & " - GeoIP - " & oClient.IpAddress, 30, "h")
oGeoip is working because I do print some messages in the hmailserver_events.log in the script, no messages from the AutoBan function though even though I know that it is called after some of the messages that I print from the script before calling the function.
No Ip is added in IpRanges. Checked the temp folder in hMailServer and no autolock.lck file was created automaticaly, created it myself. Checked the permission and the SYSTEM account, the one that hMailServer is running under, has read/write permission on Temp folder.
This is really odd. I used to do autoban with the following function, without LockFile and everything was working:
Sub AutoBan(IPAddress, NumberOfDays, ReasonForBan)
   'custom event
   'uses functions:
   EventLog.Write("Autoban IP Address started for IP = " & IPAddress & " For " & NumberofDays & " days for reason " & Reasonforban)
   Dim oApp
'       Give this script permission to access all
'       hMailServer settings.
   Dim i
   For i = 0 To oApp.Settings.SecurityRanges.Count -1
      If IPAddress = oApp.Settings.SecurityRanges.Item(i).LowerIP Then Exit sub
   EventLog.Write("Autoban IP range being set for IP Address " & IPAddress)
   With oApp.Settings.SecurityRanges.Add()
      .lowerip = ipaddress
      .upperip = ipaddress
      .priority = 20
      .allowdeliveryfromlocaltolocal = False
      .allowdeliveryfromlocaltoremote = False
      .allowdeliveryfromremotetolocal = False
      .allowdeliveryfromremotetoremote = False
      .allowimapconnections = False
      .allowsmtpconnections = False
      .allowpop3connections = False
      .expires = True
      .ExpiresTime = DateAdd("d", NumberOfDays, Now())
      .name = ReasonForBan & " - banned for " & NumberOfDays & " days - " & ipaddress
      .save
      If (Err.Number = 0) Then
         EventLog.Write("Autoban IP range saved for IP Address " & IPAddress)
         Err.Clear
      On Error Goto 0
At 4-5 hours hMailServer just stops working without any errors, I had only Application and SMTP logging enabled. When in this state, I cannot send/receive any emails. Also webmail (Afterlogic) does not work, when trying to login I get the error: "Can't connect to IMAP4 server, check IMAP4 server settings" and in the log of Afterlogic I get: "[INFO] Error: Socket connection has been refused by remote host. InnerException message follows: No connection could be made because the target machine actively refused it 127.0.0.1:993"
Now I have activated in hMailServer logging for IMAP, TCP/IP and Debug but as I said, it is crashing once every 4-5 hours, now it is working...
Do you have any opinion on this?
adrianmihai83
Re: Problem with AutoBan
Post by adrianmihai83 » 2020-02-05 21:27
Some more insight, there is a problem with Disconnect function. I disabled the disconnect function and the script went to AutoBan and added the ip to IpRanges.
My Disconnect function is:
'	Function Disconnect - http://hmailserver.com/forum/viewtopic.php?f=7&t=34058
'	Download disconnect.exe from: https://d-fault.nl/files/Disconnect.zip
Function Disconnect(sIPAddress)
	EventLog.Write("Disconnect.exe " & sIPAddress & "")
		.Run """C:\Program Files (x86)\hMailServer\Events\Disconnect.exe"" " & sIPAddress & "", 0, True
		'REM EventLog.Write("Disconnect.exe " & sIPAddress & "")
Disconnect.exe is present in the Events folder
I belive that has something to do with WScript
Post by SorenR » 2020-02-05 22:14
You are missing this...
    Function Wait(sec)
            .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
Post by palinka » 2020-02-05 22:18
adrianmihai83 wrote:
2020-02-05 21:27
Very strange. My own code is identical and I don't have any problems. REM all calls to disconnect and wait a day or two. See if you have any other issues.
Also, try the windows cure-all: rebooting.
Post by palinka » 2020-02-05 22:24
2020-02-05 22:14
    Function Wait(sec)
Eagle eye!
adrianmihai83
Post by adrianmihai83 » 2020-02-05 23:26
I do have the wait function inside my script, just did not put it in the first place:
'	Function Wait - https://www.hmailserver.com/forum/viewtopic.php?p=212052
Function Wait(sec)
     .Run "timeout /T " & Int(sec), 0, True                                     ' Windows 7/2003/2008 or later
'     .Run "sleep -m " & Int(sec * 1000), 0, True                                ' Windows 2003 Resource Kit
'     .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True    ' Windows 10 Powershell
Also have Include and Lookup and other functions but they are not relevant to my problem, everything is working except calling the disconnect function:
And in the disconnect function I have placed the two EventLog.Write, all I can see in the log is "Entering disconnect..." and that's it, no "Exit disconnect."
	EventLog.Write("Entered disconnect...")
	EventLog.Write("Exit disconnect")
My system is 2008 server R2, and yes, on another similar system, same script is running without a problem...
Post by SorenR » 2020-02-05 23:54
Try this, it's using 8DOT3 directory name to avoid the spaces.
From a CMD prompt do "dir /X" to list 8DOT3 names.
		.Run "C:\PROGRA~2\hMailServer\Events\Disconnect.exe " & sIPAddress, 0, True
adrianmihai83
Post by adrianmihai83 » 2020-02-06 11:33
Not working... :(
Thanks SorenR for the suggestion.
Post by mattg » 2020-02-06 12:25
Make your 'my computer IP range' (127.0.0.1) have a priority of 120
That will stop your webmail being blocked by Autoban
adrianmihai83
Post by adrianmihai83 » 2020-02-06 12:54
Thanks mattg, but that was not the problem, localhost has priority 80. The problem is with the disconnect function from the script, after calling it a couple of times and failing, hMailServer freezes.
Post by SorenR » 2020-02-06 15:00
2020-02-06 11:33
Not working... :(
Maybe change "True" to "False" so that the script does not wait for the shell command to finish. You have a problem with the "disconnect.exe"...
Post by mattg » 2020-02-06 17:00
2020-02-06 12:54
The reason that I said 120, is that the autoban entries are set to 100
80 is too low
adrianmihai83
Post by adrianmihai83 » 2020-02-06 22:11
mattg, autoban entries are set at priority 20, my localhost is never banned
SorenR, I tried the following thing just to be sure that problem comes from disconnect.
1. telnet from another computer to the mail server
2. in cmd, ran Disconnect.exe to see all connections
3. tried Disconnect.exe Ip_Address without any other parameters and everything worked, connection was closed
4. tried anything after Ip_Address like ", 0, True" or " 0, True" or some variations and I get this error results:
Unhandled Exception: System.Exception: Invalid IP address
   at ConnectionManager.Disconnecter.IPStringToInt(String IP)
   at ConnectionManager.Disconnecter.CloseRemoteIP(String IP)
   at ConnectionManager.Starter.Main(String[] args)
or
Unhandled Exception: System.FormatException: Input string was not in a correct format.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   at System.Byte.Parse(String s, NumberStyles style, NumberFormatInfo info)
Is there any list of parameters for this program?
Post by SorenR » 2020-02-06 22:28
    Dim strCommand, intWindowStyle, bWaitOnReturn
    strCommand = "C:\PROGRA~2\hMailServer\Events\Disconnect.exe " & sIPAddress
    intWindowStyle = 0
    bWaitOnReturn = True
        .Run strCommand, intWindowStyle, bWaitOnReturn
        EventLog.Write(strCommand)
'  Syntax
'        objShell.Run (strCommand, [intWindowStyle], [bWaitOnReturn])
'  Key
'     objShell    :  A WScript.Shell object
'     strCommand  :  The Command to be executed
'     intWindowStyle
'     (Optional)  :  Int value indicating the appearance of
'                    the program's window.
'                    Not all programs make use of this.
'   bWaitOnReturn :  Wait for the command to complete before
'                    continuing execution of the wsh script.
https://ss64.com/vb/run.html
Post by mattg » 2020-02-07 02:03
2020-02-06 22:11
As long as you are sure for your setup, because this has changed in some builds
https://github.com/hmailserver/hmailserver/issues/306
This is what makes me think autoban
2020-02-05 20:11
...and in the log of Afterlogic I get: "[INFO] Error: Socket connection has been refused by remote host. InnerException message follows: No connection could be made because the target machine actively refused it 127.0.0.1:993"
adrianmihai83
Post by adrianmihai83 » 2020-02-07 23:01
@SorenR, still the same, copy pasted your function, thought that maybe there is something spelled wrong in my function, but the same function is working on another server... same Windows 2008 R2, same version of hMailServer... This is odd
@mattg, as I said, I am on the latest RvdH build - 5.6.8, the problem with priority is in 5.7, my autoban priority is 20 and also, since disabling disconnect everything is working great. I cannot disconnect localhost because in the script I exclude the posibility that localhost or local lan to be autobanned.
Post by RvdH » 2020-02-08 12:29
SorenR wrote: You have a problem with the "disconnect.exe"...
Windows smartscreen filter? Tried to see if it's blocked?
the source of disconnect is pasted here, it doesn't take any other parameters as IP1 [IP2 [IP3 [IPn]]]
adrianmihai83
Post by adrianmihai83 » 2020-02-09 15:32
Thanks @RvdH for the suggestion, this was the solution:
Post by RvdH » 2020-02-09 17:11
