Script not blocking all domain in the array
kubera86
Post by kubera86 » 2020-02-16 08:19
I found and implemented a script from the forum to block incoming emails from certain domains.
It's able to block all domain in the array except these chinese owned domains 126.com, 163.com and aliyun.com.
Please recommend a solution. Our mailboxes are flooded daily with promotional emails from these domain. T.Y
	Dim arrayAccounts(5), C
      '************  Update the Block List array here  *********
      ' Ensure to change the index value in brackets (x) for EACH entry)
      arrayAccounts(0)= "@126.com"
      arrayAccounts(1)= "@163.com"
      arrayAccounts(2)= "@aliyun.com"
      arrayAccounts(3)= "@googlegroups.com"
      arrayAccounts(4)= "@emailsrvr.com"
                 'Add more as needed, and ensure count does not exceed DIM attributes for arrayAccounts
   '************ End of Block list array  *************
      for C = 0 to uBound(arrayAccounts)
         If arrayAccounts(C) <> "" then
            If (InStr(1, oMessage.FromAddress, arrayAccounts(C), 1) > 0) then
               ' Reject the message
               eventlog.write(now() & "Incoming email blocked from " & ucase(oMessage.FromAddress) & ". Subject: " & oMessage.Subject )
               Result.Value = 1    ' 1 gives rejection 554 without tailored message
               Exit For
      Next 'C
Re: Script not blocking all domain in the array
Post by katip » 2020-02-16 11:22
lookup "From" instead of "FromAddress" or better join both with "OR"
HMS 5.7.0, MariaDB 10.4.10, SA 3.4.2, ClamAV 0.103.2
kubera86
Post by kubera86 » 2020-02-16 12:17
katip wrote:
2020-02-16 11:22
I used the second, will observer for a day. :D :D :D
Post by SorenR » 2020-02-16 14:08
    Dim strRegEx
    strRegEx = "(\@126\.com)|" &_
               "(\@163\.com)|" &_
               "(\@aliyun\.com)|" &_
               "(\@googlegroups\.com|)" &_
               "(\@emailsrvr\.com)"
        .Pattern = strRegEx
        .Global = False
        .MultiLine = True
        .IgnoreCase = True
        If .Test(oMessage.FromAddress) Or .Test(oMessage.From) Then
            Result.Value = 2
            Result.Message = "5.3.0 [Origin Banned] The SMTP service (" & Client.HELO & ") originating on IP address (" & Client.IPAddress & ") is not welcome here."
            Eventlog.Write( Now() & "Incoming email blocked from " & UCase(oMessage.FromAddress) & ". Subject: " & oMessage.Subject )
            Exit Sub
kubera86
Post by kubera86 » 2020-02-17 06:31
Hi guys! The scripts didn't work. I guess this has something to do with FROM or SENDER?
Here's a thunderbird view source from one of the emails.
Return-Path: dpjhew@jumg.com
Received: from jumg.com (193.180.237.114.broad.lyg.js.dynamic.163data.com.cn [114.237.180.193])
by mail.******.com with ESMTP ; Sun, 16 Feb 2020 11:56:36 -0600
Message-ID: <9630948A-76D3-45EA-9D3E-1A635264BDD5@mail.******.com>
Received: from vps12549 ([127.0.0.1]) by localhost via TCP with ESMTPA; Mon, 17 Feb
2020 01:56:09 +0800
MIME-Version: 1.0
Sender: Susan <dpjhew@jumg.com>
To: zambia@******.com
Reply-To: Susan <gaikan5935669469@126.com>
Date: 17 Feb 2020 01:56:09 +0800
Subject: [SPAM] Re: Superfinishing Machines For Bearings
Content-Type: text/html; charset=utf-8
Content-Transfer-Encoding: base64
X-hMailServer-Spam: YES
X-hMailServer-Reason-1: The host name specified in HELO does not match IP address. - (Score: 2)
X-hMailServer-Reason-2: Rejected by UCE Protect - (Score: 2)
X-hMailServer-Reason-3: Rejected by Spamhaus. - (Score: 4)
X-hMailServer-Reason-Score: 8
X-hMailServer-LoopCount: 1
and Below is from the Logs
"DEBUG" 4980 "2020-02-16 11:56:33.190" "TCP connection started for session 4871"
"SMTPD" 4980 4871 "2020-02-16 11:56:33.190" "114.237.180.193" "SENT: 220 mail.******.com ESMTP"
"SMTPD" 4936 4871 "2020-02-16 11:56:33.424" "114.237.180.193" "RECEIVED: EHLO jumg.com"
"SMTPD" 4936 4871 "2020-02-16 11:56:33.424" "114.237.180.193" "SENT: 250-mail.******.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 4940 4871 "2020-02-16 11:56:33.690" "114.237.180.193" "RECEIVED: MAIL FROM:<dpjhew@jumg.com> SIZE=912"
"DEBUG" 4940 "2020-02-16 11:56:34.128" "Spam test: SpamTestDNSBlackLists, Score: 6"
"DEBUG" 4940 "2020-02-16 11:56:34.206" "Spam test: SpamTestHeloHost, Score: 2"
"DEBUG" 4940 "2020-02-16 11:56:34.299" "Spam test: SpamTestMXRecords, Score: 0"
"DEBUG" 4940 "2020-02-16 11:56:34.440" "Spam test: SpamTestSPF, Score: 0"
"DEBUG" 4940 "2020-02-16 11:56:34.440" "Total spam score: 8"
"SMTPD" 4940 4871 "2020-02-16 11:56:34.440" "114.237.180.193" "SENT: 250 OK"
"SMTPD" 4980 4871 "2020-02-16 11:56:35.175" "114.237.180.193" "RECEIVED: RCPT TO:<zambia@******.com>"
"SMTPD" 4980 4871 "2020-02-16 11:56:35.175" "114.237.180.193" "SENT: 250 OK"
"SMTPD" 4940 4871 "2020-02-16 11:56:35.425" "114.237.180.193" "RECEIVED: DATA"
"DEBUG" 4940 "2020-02-16 11:56:35.440" "Executing event OnSMTPData"
"DEBUG" 4940 "2020-02-16 11:56:35.440" "Event completed"
"SMTPD" 4940 4871 "2020-02-16 11:56:35.440" "114.237.180.193" "SENT: 354 OK, send."
"DEBUG" 4940 "2020-02-16 11:56:36.284" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "SURBL: Execute"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "SURBL: Match not found"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Spam test: SpamTestSURBL, Score: 0"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Spam test: SpamTestDKIM, Score: 0"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Total spam score: 0"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Saving message: {AA317101-3168-4513-A410-C8A0D7C5287F}.eml"
"DEBUG" 4732 "2020-02-16 11:56:36.284" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 4732 4871 "2020-02-16 11:56:36.284" "114.237.180.193" "SENT: 250 Queued (0.844 seconds)"
"DEBUG" 4792 "2020-02-16 11:56:36.284" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 4836 "2020-02-16 11:56:36.284" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 4836 "2020-02-16 11:56:36.284" "Delivering message..."
"APPLICATION" 4836 "2020-02-16 11:56:36.284" "SMTPDeliverer - Message 157433: Delivering message from dpjhew@jumg.com to zambia@******.com. File: E:\hMailServer\hMailServer\Data\{AA317101-3168-4513-A410-C8A0D7C5287F}.eml"
"DEBUG" 4836 "2020-02-16 11:56:36.300" "Running custom virus scanner..."
"SMTPD" 4940 4871 "2020-02-16 11:56:36.534" "114.237.180.193" "RECEIVED: QUIT"
"SMTPD" 4940 4871 "2020-02-16 11:56:36.534" "114.237.180.193" "SENT: 221 goodbye"
"DEBUG" 4936 "2020-02-16 11:56:36.534" "Ending session 4871"
"DEBUG" 4836 "2020-02-16 11:56:36.644" "Scanner: "C:\Program Files\ESET\ESET Security\ecls.exe" /log-file="E:\hMailServer\hMailServer\Logs\nod32.log" /mailbox /unsafe /unwanted /preserve-time /clean-mode=strict "E:\hMailServer\hMailServer\Data\{AA317101-3168-4513-A410-C8A0D7C5287F}.eml". Return code: 0"
"DEBUG" 4836 "2020-02-16 11:56:36.644" "Applying rules"
"DEBUG" 4836 "2020-02-16 11:56:36.644" "Applying rule SENDER is 163 126 aliyun"
"DEBUG" 4836 "2020-02-16 11:56:36.644" "Performing local delivery"
"DEBUG" 4836 "2020-02-16 11:56:36.675" "Applying rules"
"DEBUG" 4836 "2020-02-16 11:56:36.675" "Forwarding message"
"DEBUG" 4836 "2020-02-16 11:56:36.675" "Copying mail contents"
"DEBUG" 4836 "2020-02-16 11:56:36.675" "Saving message: {3705505C-CC1F-40A6-8C1D-E189074B6019}.eml"
"DEBUG" 4836 "2020-02-16 11:56:36.690" "Local delivery completed"
Post by mattg » 2020-02-17 07:26
OnAcceptMessage should fire between antivirus and rules
Do you have scripts enabled in hMailserver?
Did you include the above sub in your eventhandlers.vbs?
Is there ONLY one OnAcceptMessage sub in the eventhandlers.vbs
kubera86
Post by kubera86 » 2020-02-17 07:57
2020-02-17 07:26
YES
YES inside OnSMTPData
YES and commented empty.
The script above works on other domains except the mentioned 3.
The DELETE Rule also doesn't work on theses domains.
Post by jimimaseye » 2020-02-17 09:50
You dont list jumg.com in your block list.
Post by mattg » 2020-02-17 10:21
kubera86 wrote:
2020-02-17 07:57
2020-02-17 07:26
That's likely your issue
On SMTP data is pretty early, and not all of the info is present then
https://www.hmailserver.com/documentati ... onSMTPdata
Post by katip » 2020-02-17 14:46
2020-02-17 09:50
OP's problem is From header, i.e. oMessage.From, not FromAddress.
we see lots of Chinese spam which have absurd addresses in FromAddress (Return-Path) such as jrhfhgd@svdfhtx.com but ...@163.com and ...@126.com in From header and often in Reply-To too.
Post by jimimaseye » 2020-02-17 15:13
katip wrote:
2020-02-17 14:46
2020-02-17 09:50
Yes. His script is checking .fromaddress which is jumg.com (and not checking .from which is 126.com)
Therefore...
katip wrote:
2020-02-16 11:22
kubera86
Post by kubera86 » 2020-02-17 15:37
2020-02-17 15:13
katip wrote:
2020-02-17 14:46
2020-02-17 09:50
Therefore...
katip wrote:
2020-02-16 11:22
Exactly!
Moved the code from OnSMTPData to OnAcceptMessage Sub and joined the conditions. Will observe again for 24 hours... All of our 85 email accounts are receiving min 300 junks a day in total from those domain. I only learned QBasic and Pascal during my time, hope the code below is correct.
            If (InStr(1, oMessage.FromAddress, arrayAccounts(C), 1) > 0 OR InStr(1, oMessage.From, arrayAccounts(C), 1) > 0) then
               Exit For
      Next 'C
Post by jimimaseye » 2020-02-17 15:59
Looks ok.
Post by SorenR » 2020-02-17 16:55
2020-02-17 07:26
You may want to revisit this...
' hMailServer Triggers
Sub OnClientConnect(oClient)
Sub OnClientLogon(oClient) '<< A bit special, for POP/IMAP it comes after OnClientConnect(). For SMTP it comes after OnHELO()
Sub OnHELO(oClient)
'*  SPAM test: DNSBlackLists, HeloHost, MXRecords, SPF
'*  SPAM test: URIBL, DKIM, SpamAssassin, Saving EML to DATA
Sub OnDeliveryStart(oMessage)
'*  Antivirus check, Global rules
'*  Local rules, Message delivered to recipient(s)
Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
Sub OnError(iSeverity, iCode, sSource, sDescription)
Sub OnBackupCompleted()
Sub OnBackupFailed(sReason)
Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
' END
