want to add text into mail body using script
Hi all,
I am not programming expert, but need to add some disclaimer into incoming mails from other domains, wondering why the script i used could not work.
Below is my script:
' End Sub
' Sub OnSMTPData(oClient, oMessage)
' End Sub
oMessage.Body = oMessage.Body & "CAUTION: This email was sent from a third party outside of OMGWHYCANNOTWORK. Please DO NOT click links or open attachments unless you recognize the sender and know the content is safe. If you believe this email is not safe, please forward the email to phishing@OMG"
' Sub OnDeliveryStart(oMessage)
' End Sub
' Sub OnDeliverMessage(oMessage)
' End Sub
' Sub OnBackupFailed(sReason)
' End Sub
' Sub OnBackupCompleted()
' End Sub
' Sub OnError(iSeverity, iCode, sSource, sDescription)
' End Sub
' Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
' End Sub
' Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
' End Sub
I use this hmail server to act as internal mail server after mails from external mail server imported into this server using pop3. But I could not get the text append to work.
Any expert here can help out?
btw, I am using version 5.6.6
Thanks a bunch!
Below is my script:
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
Thanks a bunch!
- jimimaseye
- Moderator
Re: want to add text into mail body using script
As you are importing via pop3 you will need to add using the onexternaldownload section. (Onacceptmessage is fgor smtp messages).
OK noted.
Only add the codes in that section, right? The 3 elements no need to change?
ok checked into the log
"ERROR" 3004 "2020-04-21 15:45:27.712" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3004 "2020-04-21 15:47:07.540" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3004 "2020-04-21 15:47:11.188" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3136 "2020-04-21 15:47:27.273" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01A8 - Description: Object required: 'oMessage' - Line: 29 Column: 1 - Code: (null)"
"ERROR" 3004 "2020-04-21 15:47:27.740" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
oh no, argument error
I only have 31 lines here, where did the line 33 error came from
- jimimaseye
- Moderator
Post the entire contents of your handlers script please.
' End Sub
' End Sub
'Sub OnAcceptMessage(oClient, oMessage)
'End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
Sub OnExternalAccountDownload(oMessage)
oMessage.Body = oMessage.Body & "CAUTION: This email was sent from a third party outside of OMGGG. Please DO NOT click links or open attachments unless you recognize the sender and know the content is safe. If you believe this email is not safe, please forward the email to spammm"
for the rules, i set the condition as mail from : not contain @domain.com, will run function OnExternalAccountDownload
Pop3 mails coming in no problem
' End Sub
' End Sub
'End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
' End Sub
- jimimaseye
- Moderator
You have changed the OnExternalAccountDownload parameters. Change it back to
Also the sub section is run automatically against every message downloaded automatically - you do not need to call it by rules. So for conditioning you should put your condition in the script itself (instead of using a rule).
this is the log:
"ERROR" 3120 "2020-04-21 16:21:27.659" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3120 "2020-04-21 16:21:27.661" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3120 "2020-04-21 16:21:27.664" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3120 "2020-04-21 16:21:27.666" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3120 "2020-04-21 16:21:27.669" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
"ERROR" 3120 "2020-04-21 16:21:27.671" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A01C2 - Description: Wrong number of arguments or invalid property assignment: 'OnExternalAccountDownload' - Line: 33 Column: 0 - Code: (null)"
- jimimaseye
- Moderator
Have you removed the rule?
Need to remove the rule?
- jimimaseye
- Moderator
jimimaseye wrote: ↑2020-04-21 10:17You have changed the OnExternalAccountDownload parameters. Change it back to
hi thanks for reply. but unfortunately it is still not working.
It only works if i use "server sendout" which, any outside email from gmail does not work
