mekola
- New user
Post
by mekola » 2020-05-05 13:52
Hi, i am developing c# web api for reading all mails and read mail according to id.
I'm following COM API documentary but i can't figure out one thing.
In Messages sections, there is ItemByDBID but i can't use it properly.
this is my simple code:
public IEnumerable<MailModel> Get(int id)
hMailServer.ApplicationClass application = new hMailServer.ApplicationClass();
application.Authenticate("Administrator", "password");
hMailServer.Domain domain = application.Domains.ItemByName["domain.com"];
hMailServer.Accounts accounts = domain.Accounts;
hMailServer.Account mailbox = accounts.ItemByAddress["some@domain.com"];
hMailServer.IMAPFolders imapFolders = mailbox.IMAPFolders;
hMailServer.IMAPFolder imapfolder = imapFolders.ItemByName["INBOX"];
hMailServer.Messages messages = imapfolder.Messages;
List<MailModel> mailmodels = new List<MailModel>();
for (int i = 0; i< messages.Count; i++)
hMailServer.Message message = messages.ItemByDBID[i]; // EXCEPTION
mailmodels.Add(new MailModel() { numberId = message.ID, Subject = message.Subject,BodyText=message.Body,From=message.From });
return mailmodels;
Gives me: System.Runtime.InteropServices.COMException: 'Invalid directory. (HRESULT returned an exception: 0x8002000B (DISP_E_BADINDEX))
For example, i can get number of mails properly with messages.Count but i can not figure out ItemByDBID
I want to just, it gives me all mail in JSON type.
Sorry my bad english.
Please, thank you su much
- Senior user
Post
by SorenR » 2020-05-05 15:53
DBID is the not per account - it is the entire database table...
hMailServer.Message message = messages.Item[i];
is probably the one you want.
You can learn a lot from this script
https://www.hmailserver.com/forum/viewt ... 52#p175052
mekola
- New user
Post
by mekola » 2020-05-05 16:30
Thanks your reply so much.
I search retry and i find this,
in C# COM API hmail References => There is no " Item", just there is "ItemDBID" ( i also search object browser)
in VB COM API hmail References = Yes there is an Item as documantation
i think there is no same Item issue in C# than
i will try same thing in VB, and i will reply again.
Thank you
- Senior user
Post
by SorenR » 2020-05-05 17:12
mekola wrote: ↑2020-05-05 16:30
Thank you
U r joking... no?
mekola
- New user
Post
by mekola » 2020-05-05 17:14
I tried in VB and it works fine
Thank you
Now i have to convert all of C# codes to VB, i think
i guess there is no another way because C# has not Item object in messages.
thanks your advices again, god bless you.
you answered when writing these articles.
Really in C# Hmailserver References, there is no Item object
- Senior user
Post
by SorenR » 2020-05-05 18:17
Weird... I'm going to dig in the hMailAdmin code (C#) to see how lists are made... It'll be the same with Rules, Domains, Accounts etc...
- Senior user
Post
by SorenR » 2020-05-05 18:43
mekola
- New user
Post
by mekola » 2020-05-17 01:51
I don't know how to thank you,
I have been trying for this for days.
Thank you so much.
Last bumped by mekola on 2020-05-17 01:51.
