Search entire message text in the rule selection.
screenman47
Post by screenman47 » 2020-05-25 16:14
When I want to add a new entry to a rule I have only a few options as to where Hmail looks for the offending text. Is it possible to search the whole .eml source instead of making multiple entries to the rule. I know there is a "custom header field" box but how do I tell it to search everything.
Re: Search entire message text in the rule selection.
Post by mattg » 2020-05-25 17:27
Custom header rule only checks the message headers
You can't search full email text using rules
screenman47
Post by screenman47 » 2020-05-25 17:46
Okay. Thank you.
U-351
Post by U-351 » 2020-06-18 06:26
In this case, can someone explain - what gives the "BODY" tag in the rules?
Post by mattg » 2020-06-18 15:58
'Body' is plain text, and may or may not, include the contents of the email
Some emails are 'HTML text'
But yes, that is a good find.
I missed that
Post by RvdH » 2020-06-19 00:06
2020-06-18 15:58
I missed that
U Sure?
Body - The Body of the email message. This includes both the plain text body and the HTML body.
As listed in docs here
Post by mattg » 2020-06-19 00:20
Well there you go
Post by katip » 2020-06-19 05:10
rules work with body too, for sure.
however i'm not sure if HMS first decodes base64 and then performs a search, like SA or ASSP do it. i think not.
so only text and/or some HTML bodies are good for rules.
depending on traffic volume and average message size it may not be wise to use body rules though.
