User Import
User Import
Post by 20721 » 2020-06-19 14:35
Hello dear community,
i'm pretty new to hmailserver and have already searched this but didn't really find what i'm looking for.
I use the program to get status messages from network devices via SMNP and forward them to external email addresses.
This works perfectly, but now we get MFP devices where scan-to-mail is used. So I have to create an account on the server for each user which forwards them to an external account.
Creating all users by hand would be a bit time consuming and I wanted to do this with a VBS script I found on the internet.
The script itself also works great when creating the accounts, but here the external email address and the forwarding is active.
I start the script myself with an Autoit script which passes the parameters to the VBS script until the list is processed accordingly, where the users are listed.
start hmail-create-accounts.vbs Username UserPW domain
Is there the possibility to extend this script so that I can use the parameters
for the external e-mail address and that it is active.
Enclosed the VBS Script
Dim hmail, domain, account, email, noOfDomains, userName, userPassword, domainName, hMailAdminAccount, hMailAdminPassword
' These are the hMail admin account defaults after a silent install
hMailAdminAccount = "Administrator"
hMailAdminPassword = "Password"
' No changes below this line
' Check for account details from command line
If Wscript.Arguments.Count <> 3 Then
    WScript.Quit 1
userName = Wscript.Arguments(0)
userPassword = Wscript.Arguments(1)
domainName = Wscript.Arguments(2)
'msgbox userName & " / " & userPassword & " @ " & domainName,0,"Input params"
email = userName & "@" & domainName
' Get connection to hMailServer
Set hmail = CreateObject("hMailServer.Application")
hmail.Authenticate hMailAdminAccount,hMailAdminPassword
' Check whether domain already exists
noOfDomains = hmail.Domains.Count
domainExists = false
if noOfDomains > 0 then
	for i = 0 to noOfDomains-1
		set domain = hmail.Domains.Item(i)
		if domain.Name = domainName then
			domainExists = true
			exit for
		end if
	next
end if
' Create domain if it does not yet exist
if domainExists = false then
	set domain = hmail.Domains.Add()
	domain.Name=domainName
	domain.Active=true
	domain.save()
end if
' Check whether account already exists
set accountList=domain.Accounts
noOfAccount = accountList.Count
accountExists = false
if noOfAccount > 0 then
	for i = 0 to noOfAccounts
		set account = accountList.Item(i)
		if account.Address = email then
			accountExists = true
			exit for
		end if
	next
end if
' Create account if it does not yet exist
if accountExists = false then
	set account=accountList.Add()
	account.Address=email
	account.Password=userPassword
	account.Active=true
	account.Forward=True
	account.Save()
end if
I would be happy about a positive answer or alternatives to the VBS file.
Translated with www.DeepL.com/Translator (free version)
Re: User Import
Post by mattg » 2020-06-20 01:28
like this - not tested
*** AND I REALLY HOPE THAT YOU DON'T USE THAT PASSWORD
Dim hmail, domain, account, email, noOfDomains, userName, userPassword, domainName, hMailAdminAccount, hMailAdminPassword , ForwardToAddress
If Wscript.Arguments.Count <> 4 Then
    WScript.Quit 1
ForwardToAddress = WScript.Arguments(3)
			domainExists = true
			exit for
		end if
	next
end if
	domain.Active=true
	domain.save()
end if
			exit for
		end if
	next
end if
	account.Active=true
	account.ForwardAddress=ForwardToAddress
	account.ForwardKeepOriginal=False
	account.Save()
end if
20721
Re: User Import
Post by 20721 » 2020-06-21 14:21
Hello mattg,
of course it's not the password, but I didn't want to leave it blank either.
So I tested it today and also read through it.
If I start the script accordingly I get the feedback.
The object does not support this property or method: "Forward".
That you have to set DIm and the parameters should have been in my mind.
Code 800A0186
Source: Runtime error in Microsoft VBScript
Re: User Import
Post by mattg » 2020-06-21 15:06
It's meant to be ForwardEnabled not Forward sorry
Try this
    WScript.Quit 1
			domainExists = true
			exit for
		end if
	next
end if
	domain.Active=true
	domain.save()
end if
			exit for
		end if
	next
end if
	account.Active=true
	account.ForwardEnabled=True
	account.Save()
end if
20721
Re: User Import
Post by 20721 » 2020-06-21 18:03
Hello megg,
it's going perfectly now.
I have modified it a little bit concerning the recipient address, because it didn't work out.
Now it works perfectly and I can write a script with AutoIT for about 200 users.
Dim Forwarddomain, hmail, domain, account, email, noOfDomains, userName, userPassword, domainName, hMailAdminAccount, hMailAdminPassword , ForwardToAddress
hMailAdminPassword = "password"
If Wscript.Arguments.Count <> 5 Then
    WScript.Quit 1
Forwarddomain = WScript.Arguments(4)
extemail = ForwardToAddress & "@" & Forwarddomain
			domainExists = true
			exit for
		end if
	next
end if
	domain.Active=true
	domain.save()
end if
			exit for
		end if
	next
end if
	account.Active=true
	account.ForwardAddress=email2
	account.ForwardKeepOriginal=True
	account.Save()
end if
Thanks for your Help
