DimanG
- New user
Post
by DimanG » 2020-07-23 14:29
Hi everybody!
I've got a sub executing Python script over the saved message file. No result. What's wrong? Or where to look for?
There are some excessive code cause I was trying to find solution.
The message file is copied successfully, but the Python script does nothing, while running manually is ok.
Thanks in advance.
Sub save_body_zc(oMessage)
oTxtBody=oMessage.HTMLbody
Dim StrDir, strFileName, FullName, oShell, TempDir
StrDir="\\srv\EXPORT\zc\"
TempDir="\\srv\EXPORT\zc\Temp\"
strFileName = trim(oMessage.subject)
FullName=StrDir & strFileName & ".eml"
TempName=TempDir & strFileName & ".eml"
.CopyFile oMessage.FileName, TempName, True
StrDir="\\\\srv\\EXPORT\\zc\\"
TempDir="\\\\srv\\EXPORT\\zc\\Temp\\"
Set oShell = WScript.CreateObject ("WScript.Shell")
oShell.Exec("d:\Python34\python.exe d:\Python34\Scripts\zcmail.py " & Chr(34) & TempName & Chr(34) & " " & Chr(34) & FullName & Chr(34))
Set oShell = Nothing
- Moderator
Post
by mattg » 2020-07-23 15:00
Probably the user that the hMailserver WINDOWS SERVICE runs under doesn't have the permissions required to run your python
Perhaps change the user that the Windows Service runs under
DimanG
- New user
Post
by DimanG » 2020-07-28 16:29
Added maximal rights (local admin) to the user. Nothing changed. How can I debug the script execution? Logs contain nothing to analyze.
Manually it runs ok.
- Moderator
Post
by mattg » 2020-07-28 16:51
Press Windows start orb >> type 'services.msc'
Open Services, scroll down to hMailserver
Select hMailserver, then right click, and choose properties
Select the 'log on' tab, and screen shot that, and post screenshot here
Also show a screen shot of the properties >> Security, for the folder that has your Python installation
DimanG
- New user
Post
by DimanG » 2020-07-29 17:45
Screenshots are in Russian. I can tell in some words: the domain user the service hMailServer runs under is a local admin. Full rights are given for it on the folder and all subfolders and files where Python is located. The script is executed manually under this user with success. But what's inside hMailServer - I can't find out. Only message file is copied to another location - I did so when the script stopped working (it worked some days, and nothing was changed in the system).
- Moderator
Post
by mattg » 2020-07-30 02:34
Try adding some event logging to your hmailserver script
like
EventLog.Write(TempName)
just before the python script is called to make sure that the variables are set correctly
DimanG
- New user
Post
by DimanG » 2020-08-03 22:22
Tried several logging events in vbs, py and cmd scripts and found out that everything is ok with variables, but the cmd-script doesn't run at all. The hMailserver log is always full of Script Error records with some unknown codes. Is there any way to see what's wrong with of WScript.Shell Exec command?
Thank you for help
DimanG
- New user
Post
by DimanG » 2020-08-04 00:09
Last example:
"ERROR" 7560 "2020-08-04 00:47:02.259" "Script Error: Source:
- Senior user
Post
by SorenR » 2020-08-04 10:52
I don't use Python but how about this?
Dim StrDir, strFileName, FullName, WshShell, oExec, TempDir
FullName=Replace(FullName, "\", "\\")
TempName=Replace(TempName, "\", "\\")
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("d:\Python34\python.exe d:\Python34\Scripts\zcmail.py " & Chr(34) & TempName & Chr(34) & " " & Chr(34) & FullName & Chr(34))
Do While oExec.Status = 0
WshShell.Run "powershell Start-Sleep -Milliseconds 100", 0, True
Loop
EventLog.Write("Return code on d:\Python34\python.exe d:\Python34\Scripts\zcmail.py " & Chr(34) & TempName & Chr(34) & " " & Chr(34) & FullName & Chr(34) & " was " & oExec.Status)
Set oExec = Nothing
Set WshShell = Nothing
DimanG
- New user
Post
by DimanG » 2020-08-15 21:40
After reading some Russian sources I've tried this:
CreateObject("Wscript.Shell").Run "d:\Python34\Scripts\zcmail1.cmd " & Chr(34) & strFileName & ".eml" & Chr(34), 0
and it works!
Thanks to everybody for your attention and participation.
PS: VBS syntaxis - is a dreadful thing...
