Hi
I tried checking attachments of oMessage in OnSMTPData event for both send and receive messages. Always the 'oMessage.Attachments.Count' is observed as 0. We have hMailServer version 5.6.7 installed.
Sample script :
If Not message.Attachments Is Nothing Then
If message.Attachments.Count > 0 Then
EntryToLog("Attachments count " + Cstr(message.Attachments.Count))
nTotAttSize = 0
For i = 1 to message.Attachments.Count ' attachment
oAtt = message.Attachments.Item(i-1)
EntryToLog("att Size " + Cstr(message.Attachments.Item(i-1).Size))
nTotAttSize = nTotAttSize + oAtt.Size
Next 'i - attachment
EntryToLog("nTotAttSize " + Cstr(nTotAttSize))
Am I missing something fundamental ?
oMessage.Attachments.Count is always 0
- jimimaseye
- Moderator
Re: oMessage.Attachments.Count is always 0
As designed. The data isn't there at that time. See https://www.hmailserver.com/documentati ... onSMTPdata
The attachments will be there at OnAcceptMessage. Try that.
Did check in 4 event .. OnSMTPData, OnAcceptMessage, OnDeliveryStart and OnDeliverMessage . In all events attachment count is coming 0.
OnSMTPData Attachment Count 0
OnAcceptMessage Attachment Count 0
OnDeliveryStart Attachment Count 0
OnDeliverMessage Attachment Count 0
- jimimaseye
- Moderator
Something wrong with your script then.
Post it and let us look at it (including the SUB placement as it appears in the handlers script).
Script is very simple
EntryToLog("OnSMTPData Attachment Count " + CStr(oMessage.Attachments.Count))
EntryToLog("OnAcceptMessage Attachment Count " + CStr(oMessage.Attachments.Count))
Sub OnDeliveryStart(oMessage)
EntryToLog("OnDeliveryStart Attachment Count " + CStr(oMessage.Attachments.Count))
EntryToLog("OnDeliverMessage Attachment Count " + CStr(oMessage.Attachments.Count))
Function EntryToLog (pLogMsg)
If sLogFile <> "" Then
Dim svbs, f, i
Dim fso
pLogMsg = CStr(Now) + " " + pLogMsg
svbs = Split(pLogMsg, vbCrLf)
Set f = fso.opentextfile(sLogFile, 8, True)
For i = 0 To UBound(svbs)
f.writeline(svbs(i))
f.Close
- jimimaseye
- Moderator
This should write the same detail to the standard Events log. How does it compare?
EventLog.Write("OnSMTPData Attachment Count " & oMessage.Attachments.Count )
EventLog.Write("OnAcceptMessage Attachment Count " & oMessage.Attachments.Count )
EventLog.Write("OnDeliveryStart Attachment Count " & oMessage.Attachments.Count )
EventLog.Write("OnDeliverMessage Attachment Count " & oMessage.Attachments.Count )
The values are same in eventlog.write / custom log (what mentioned in script)
I observed now the count is reflected as you mentioned from 'OnAcceptMessage' event.
But for sent email, the count is not coming in any event.
