how to reject for a given recipient when there are multiple recipients
Babita
Post by Babita » 2020-08-07 07:03
Hi
Trying to write a script to reject message for particular user based on their number of emails received for day/month. I observed the events are called once for all the recipients.
So when the reject is sent on that event [ result.value = 1 ] , the message is getting rejected for all recipients. Is there a way to reject message for particular recipient.
Re: how to reject for a given recipient when there are multiple recipients
Post by mattg » 2020-08-07 09:39
Is this a local account or an external account
If local, easiest to create an account rule
If external, I'd copy the message to a new message, grab all recipients and remove the one you don't want to get the message, before adding them to the copied message
read this thread >> https://www.hmailserver.com/forum/viewt ... =9&t=17190
