(PoC) Batch sending with delay (PoC)
Post by SorenR » 2020-08-14 18:05
1: Create account "mailman@mydomain.tld"
2: Create account rule for above; If Message size > 0 Run function mailman
3: Create folder on server (hMailServer) to hold XML files
4: Modify parameters:
    Const XMLDIR      = "C:\hMailServer\Events"
    Const From        = "Carrot top"
    Const FromAddress = "agent.orange@acme.inc"
5: Copy sample XML file to "C:\hMailServer\Events\mailman.xml"
6: Compose message and send to "mailman@mydomain.tld" with subject: "mailman|10|30|Have a nice day with Looney Tunes"
mailman = mailman.xml
10 = 10 recipients in a batch
30 = 30 seconds delay between batches
"Have a nice day with Looney Tunes" is the new email subject
Recipients are added as BCC thus not visiable. The "official" recipient of the email is the "mailman@mydomain.tld" account.
NOTE: THERE IS NO ERRORHANDLING
This is Proof of Concept code, it works but can probably not be used in production until further errorhandling has been added.
This code comes as is and is intended as a framework to be built on!
Sample XML file with recipients
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<Root>
  <Address>Barnyard Dawg, barnyard.dawg@acme.inc</Address>
  <Address>Bosko, bosko@acme.inc</Address>
  <Address>Bugs Bunny, bugs.bunny@acme.inc</Address>
  <Address>Daffy Duck, daffy.duck@acme.inc</Address>
  <Address>Elmer Fudd, elmer.fudd@acme.inc</Address>
  <Address>Foghorn Leghorn, foghorn.leghorn@acme.inc</Address>
  <Address>Granny, granny@acme.inc</Address>
  <Address>Hector the Bulldog, hector.the.bulldog@acme.inc</Address>
  <Address>Honey Bunny, honey.bunny@acme.inc</Address>
  <Address>Lola Bunny, lola.bunny@acme.inc</Address>
  <Address>Marvin The Martian, marvin.the.martian@acme.inc</Address>
  <Address>Penelope Pussycat, penelope.pussycat@acme.inc</Address>
  <Address>Pepe Le Pew, pepe.le.pew@acme.inc</Address>
  <Address>Porky Pig, porky.pig@acme.inc</Address>
  <Address>Road Runner, road.runner@acme.inc</Address>
  <Address>Speedy Gonzales, speedy.gonzales@acme.inc</Address>
  <Address>Sylvester, sylvester@acme.inc</Address>
  <Address>The Tasmanian Devil, taz@acme.inc</Address>
  <Address>Tweety Bird, tweety@acme.inc</Address>
  <Address>Wile E. Coyote, wile.e.coyote@acme.inc</Address>
  <Address>Witch Hazel, witch.hazel@acme.inc</Address>
  <Address>Yosemite Sam, yosemite.sam@acme.inc</Address>
</Root>
Code that goes into eventhandlers.vbs
Sub MailMan(oMessage)
    '   Email subject: "<list>|<batch>|<delay>|<subject>"
    Const MyNode      = "//Address"
    Dim a, b, i, j, XMLFile, strFilename, strSubject, iBatch, iDelay, oMatch, oMatches, oClone
    a = Split(oMessage.Subject, "|")
    XMLFile  = a(0) & ".xml"
    iBatch = CInt(a(1))
    iDelay = CInt(a(2))
    strSubject = Trim(CStr(a(3)))
    Dim oXML : Set oXML = CreateObject("MSXML2.DOMDocument")
    If oXML.Load(XMLDIR & "\" & XMLFile) Then
        Set oMatches = oXML.selectNodes(MyNode)
        j = 0
        For Each oMatch In oMatches
            If (j Mod iBatch) = 0 Or j = 0 Then
                Set oClone = CreateObject("hMailServer.Message")
                strFilename = oClone.Filename
                    .CopyFile oMessage.Filename, strFilename, True
                oClone.RefreshContent
            j = j + 1
            b = Split(oMatch.text,",")
            oClone.AddRecipient Chr(34) & Trim(b(0)) & Chr(34), Trim(b(1))
            If (j Mod iBatch) = 0 Or j = oMatches.length Then
                oClone.From = From
                oClone.FromAddress = FromAddress
                oClone.HeaderValue("To") = oMessage.HeaderValue("To")
                oClone.HeaderValue("Subject") = strSubject
                oClone.Save
                    .Run "powershell Start-Sleep -Milliseconds " & Int(iDelay * 1000), 0, True
        Set oClone = Nothing
        Set oMatch = Nothing
        Set oMatches = Nothing
        EventLog.Write( "Your XML Document " & XMLFile & " failed to load due the following error." & vbCrLf & _
        "Error #: " & oXML.ParseError.errorCode & ": " & oXML.ParseError.reason & _
        "Line #: " & oXML.ParseError.line & vbCrLf & _
        "Line Position: " & oXML.ParseError.linePos & vbCrLf & _
        "Position In File: " & oXML.ParseError.filePos & vbCrLf & _
        "Source Text: " & oXML.ParseError.srcText & vbCrLf & _
        "Document URL: " & oXML.ParseError.url )
    Set oXML = Nothing
