Clear the delivery queue using script?
hellem
Post by hellem » 2020-08-16 21:14
We are using the hMailserver for our test environment and we want to administer it as "little" as possible. It should not be possible to send emails from the server, and most of the test cases won't do that, but some does which causes the delivery queue to grow. That means I do not need to worry about checking if they are legit or not, I can safely delete all.
Deleting the content of the data-directory (*.eml-files) was the solution before, but not now https://www.hmailserver.com/documentati ... ery_queue . Ok, the doc does not describe any other option, so it is likely to assume that it cannot be done using scripting.
But, then there is the event onDeliverryfailes - https://www.hmailserver.com/documentati ... veryfailed - it it possible to just clear/delete the message in that event?
Re: Clear the delivery queue using script?
Post by mattg » 2020-08-17 01:00
hellem wrote:
2020-08-16 21:14
https://www.hmailserver.com/documentati ... iveryqueue
You could certainly script it
		dim oApp
		Call oApp.Authenticate("Administrator", "topSecretPassword")
		Call oApp.GlobalObjects.DeliveryQueue.Clear()
hellem wrote:
2020-08-16 21:14
Message has already been removed from delivery queue at this stage
