But if the sender makes two simultaneous connections, only the first connection/mail will be blocked, the second will not be handled by the event.
Example from the log, getting SPAM connections from 74.6.133.125
"TCPIP" 5528 "2020-08-17 09:17:30.224" "TCP - 74.6.133.125 connected to 10.x.x.x:25."
"SMTPD" 5528 20653 "2020-08-17 09:17:30.224" "74.6.133.125" "SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"TCPIP" 4392 "2020-08-17 09:17:30.224" "TCP - 74.6.133.125 connected to 10.x.x.x:25."
"SMTPD" 4392 20655 "2020-08-17 09:17:30.224" "74.6.133.125" "SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.318" "74.6.133.125" "RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.318" "74.6.133.125" "SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 4756 20655 "2020-08-17 09:17:30.334" "74.6.133.125" "RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD" 4756 20655 "2020-08-17 09:17:30.334" "74.6.133.125" "SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.427" "74.6.133.125" "RECEIVED: STARTTLS"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.427" "74.6.133.125" "SENT: 220 Ready to start TLS"
"SMTPD" 4756 20655 "2020-08-17 09:17:30.427" "74.6.133.125" "RECEIVED: STARTTLS"
"SMTPD" 4756 20655 "2020-08-17 09:17:30.427" "74.6.133.125" "SENT: 220 Ready to start TLS"
"TCPIP" 4392 "2020-08-17 09:17:30.662" "TCPConnection - TLS/SSL handshake completed. Session Id: 20653, Remote IP: 74.6.133.125, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"TCPIP" 4392 "2020-08-17 09:17:30.677" "TCPConnection - TLS/SSL handshake completed. Session Id: 20655, Remote IP: 74.6.133.125, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.756" "74.6.133.125" "RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.756" "74.6.133.125" "SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 5528 20655 "2020-08-17 09:17:30.787" "74.6.133.125" "RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD" 5528 20655 "2020-08-17 09:17:30.787" "74.6.133.125" "SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 4392 20653 "2020-08-17 09:17:30.865" "74.6.133.125" "RECEIVED: MAIL FROM:<ovie_mike2001@yahoo.com>"
"SMTPD" 4756 20655 "2020-08-17 09:17:30.881" "74.6.133.125" "RECEIVED: MAIL FROM:<ovie_mike2001@yahoo.com>"
"TCPIP" 4392 "2020-08-17 09:17:30.896" "DNS lookup: 125.133.6.74.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 4756 "2020-08-17 09:17:30.896" "DNS lookup: 125.133.6.74.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP" 4392 "2020-08-17 09:17:30.927" "DNS lookup: 125.133.6.74.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP" 4756 "2020-08-17 09:17:30.927" "DNS lookup: 125.133.6.74.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP" 4392 "2020-08-17 09:17:31.068" "DNS lookup: 125.133.6.74.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP" 4756 "2020-08-17 09:17:31.068" "DNS lookup: 125.133.6.74.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP" 4392 "2020-08-17 09:17:31.193" "DNS lookup: 125.133.6.74.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP" 4756 "2020-08-17 09:17:31.193" "DNS lookup: 125.133.6.74.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP" 4392 "2020-08-17 09:17:31.256" "DNS lookup: 125.133.6.74.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"TCPIP" 4756 "2020-08-17 09:17:31.256" "DNS lookup: 125.133.6.74.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"SMTPD" 4392 20653 "2020-08-17 09:17:31.412" "74.6.133.125" "SENT: 250 OK"
"SMTPD" 4756 20655 "2020-08-17 09:17:31.412" "74.6.133.125" "SENT: 250 OK"
"SMTPD" 5528 20653 "2020-08-17 09:17:31.506" "74.6.133.125" "RECEIVED: RCPT TO:<xx@xx.com>"
"SMTPD" 4756 20655 "2020-08-17 09:17:31.506" "74.6.133.125" "RECEIVED: RCPT TO:<xx@xx.dk>"
"SMTPD" 5528 20653 "2020-08-17 09:17:31.537" "74.6.133.125" "SENT: 250 OK"
"SMTPD" 4756 20655 "2020-08-17 09:17:31.537" "74.6.133.125" "SENT: 250 OK"
"SMTPD" 4392 20653 "2020-08-17 09:17:31.631" "74.6.133.125" "RECEIVED: DATA"
"SMTPD" 4392 20653 "2020-08-17 09:17:31.631" "74.6.133.125" "SENT: 354 OK, send."
"SMTPD" 4756 20655 "2020-08-17 09:17:31.646" "74.6.133.125" "RECEIVED: DATA"
"SMTPD" 4756 20655 "2020-08-17 09:17:31.646" "74.6.133.125" "SENT: 354 OK, send."
"SMTPD" 2888 20653 "2020-08-17 09:17:31.880" "74.6.133.125" "SENT: 554 Rejected"
"SMTPD" 4640 20655 "2020-08-17 09:17:31.880" "74.6.133.125" "SENT: 250 Queued (0.192 seconds)"
"APPLICATION" 6040 "2020-08-17 09:17:31.880" "SMTPDeliverer - Message 180667: Delivering message from ovie_mike2001@yahoo.com to xx@xx.dk. File: D:\HMailserver\Mail_Data\{16BAFFE0-1F18-42E0-A03B-63B6DC9C38AD}.eml"
"APPLICATION" 6040 "2020-08-17 09:17:31.896" "SMTPDeliverer - Message 180667: Message delivery thread completed."
"SMTPD" 4756 20653 "2020-08-17 09:17:31.974" "74.6.133.125" "RECEIVED: QUIT"
"SMTPD" 4756 20653 "2020-08-17 09:17:31.974" "74.6.133.125" "SENT: 221 goodbye"
"SMTPD" 5528 20655 "2020-08-17 09:17:31.974" "74.6.133.125" "RECEIVED: QUIT"
"SMTPD" 5528 20655 "2020-08-17 09:17:31.974" "74.6.133.125" "SENT: 221 goodbye"
Is it a missconfiguration or a bug?
It it fixed in the lastest version?
