In case of multiple mails the events are ignored
BeeTee
Post by BeeTee » 2020-08-17 09:40
In my OnAcceptMessage event in my vbs script file I do some spam filtering, i.e. setting Result.Value = 1 in case of spam.
But if the sender makes two simultaneous connections, only the first connection/mail will be blocked, the second will not be handled by the event.
Example from the log, getting SPAM connections from 74.6.133.125
"TCPIP"	5528	"2020-08-17 09:17:30.224"	"TCP - 74.6.133.125 connected to 10.x.x.x:25."
"SMTPD"	5528	20653	"2020-08-17 09:17:30.224"	"74.6.133.125"	"SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"TCPIP"	4392	"2020-08-17 09:17:30.224"	"TCP - 74.6.133.125 connected to 10.x.x.x:25."
"SMTPD"	4392	20655	"2020-08-17 09:17:30.224"	"74.6.133.125"	"SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.318"	"74.6.133.125"	"RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.318"	"74.6.133.125"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4756	20655	"2020-08-17 09:17:30.334"	"74.6.133.125"	"RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD"	4756	20655	"2020-08-17 09:17:30.334"	"74.6.133.125"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.427"	"74.6.133.125"	"RECEIVED: STARTTLS"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.427"	"74.6.133.125"	"SENT: 220 Ready to start TLS"
"SMTPD"	4756	20655	"2020-08-17 09:17:30.427"	"74.6.133.125"	"RECEIVED: STARTTLS"
"SMTPD"	4756	20655	"2020-08-17 09:17:30.427"	"74.6.133.125"	"SENT: 220 Ready to start TLS"
"TCPIP"	4392	"2020-08-17 09:17:30.662"	"TCPConnection - TLS/SSL handshake completed. Session Id: 20653, Remote IP: 74.6.133.125, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"TCPIP"	4392	"2020-08-17 09:17:30.677"	"TCPConnection - TLS/SSL handshake completed. Session Id: 20655, Remote IP: 74.6.133.125, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.756"	"74.6.133.125"	"RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.756"	"74.6.133.125"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5528	20655	"2020-08-17 09:17:30.787"	"74.6.133.125"	"RECEIVED: EHLO sonic313-15.consmr.mail.bf2.yahoo.com"
"SMTPD"	5528	20655	"2020-08-17 09:17:30.787"	"74.6.133.125"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4392	20653	"2020-08-17 09:17:30.865"	"74.6.133.125"	"RECEIVED: MAIL FROM:<ovie_mike2001@yahoo.com>"
"SMTPD"	4756	20655	"2020-08-17 09:17:30.881"	"74.6.133.125"	"RECEIVED: MAIL FROM:<ovie_mike2001@yahoo.com>"
"TCPIP"	4392	"2020-08-17 09:17:30.896"	"DNS lookup: 125.133.6.74.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	4756	"2020-08-17 09:17:30.896"	"DNS lookup: 125.133.6.74.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	4392	"2020-08-17 09:17:30.927"	"DNS lookup: 125.133.6.74.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP"	4756	"2020-08-17 09:17:30.927"	"DNS lookup: 125.133.6.74.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP"	4392	"2020-08-17 09:17:31.068"	"DNS lookup: 125.133.6.74.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP"	4756	"2020-08-17 09:17:31.068"	"DNS lookup: 125.133.6.74.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP"	4392	"2020-08-17 09:17:31.193"	"DNS lookup: 125.133.6.74.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP"	4756	"2020-08-17 09:17:31.193"	"DNS lookup: 125.133.6.74.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP"	4392	"2020-08-17 09:17:31.256"	"DNS lookup: 125.133.6.74.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"TCPIP"	4756	"2020-08-17 09:17:31.256"	"DNS lookup: 125.133.6.74.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"SMTPD"	4392	20653	"2020-08-17 09:17:31.412"	"74.6.133.125"	"SENT: 250 OK"
"SMTPD"	4756	20655	"2020-08-17 09:17:31.412"	"74.6.133.125"	"SENT: 250 OK"
"SMTPD"	5528	20653	"2020-08-17 09:17:31.506"	"74.6.133.125"	"RECEIVED: RCPT TO:<xx@xx.com>"
"SMTPD"	4756	20655	"2020-08-17 09:17:31.506"	"74.6.133.125"	"RECEIVED: RCPT TO:<xx@xx.dk>"
"SMTPD"	5528	20653	"2020-08-17 09:17:31.537"	"74.6.133.125"	"SENT: 250 OK"
"SMTPD"	4756	20655	"2020-08-17 09:17:31.537"	"74.6.133.125"	"SENT: 250 OK"
"SMTPD"	4392	20653	"2020-08-17 09:17:31.631"	"74.6.133.125"	"RECEIVED: DATA"
"SMTPD"	4392	20653	"2020-08-17 09:17:31.631"	"74.6.133.125"	"SENT: 354 OK, send."
"SMTPD"	4756	20655	"2020-08-17 09:17:31.646"	"74.6.133.125"	"RECEIVED: DATA"
"SMTPD"	4756	20655	"2020-08-17 09:17:31.646"	"74.6.133.125"	"SENT: 354 OK, send."
"SMTPD"	2888	20653	"2020-08-17 09:17:31.880"	"74.6.133.125"	"SENT: 554 Rejected"
"SMTPD"	4640	20655	"2020-08-17 09:17:31.880"	"74.6.133.125"	"SENT: 250 Queued (0.192 seconds)"
"APPLICATION"	6040	"2020-08-17 09:17:31.880"	"SMTPDeliverer - Message 180667: Delivering message from ovie_mike2001@yahoo.com to xx@xx.dk. File: D:\HMailserver\Mail_Data\{16BAFFE0-1F18-42E0-A03B-63B6DC9C38AD}.eml"
"APPLICATION"	6040	"2020-08-17 09:17:31.896"	"SMTPDeliverer - Message 180667: Message delivery thread completed."
"SMTPD"	4756	20653	"2020-08-17 09:17:31.974"	"74.6.133.125"	"RECEIVED: QUIT"
"SMTPD"	4756	20653	"2020-08-17 09:17:31.974"	"74.6.133.125"	"SENT: 221 goodbye"
"SMTPD"	5528	20655	"2020-08-17 09:17:31.974"	"74.6.133.125"	"RECEIVED: QUIT"
"SMTPD"	5528	20655	"2020-08-17 09:17:31.974"	"74.6.133.125"	"SENT: 221 goodbye"
I admittedly don't run the newest version, running 5.6.7-B2425
Is it a missconfiguration or a bug?
It it fixed in the lastest version?
Re: In case of multiple mails the events are ignored
Post by mattg » 2020-08-17 10:55
You have a custom script that rejected the mail message addressed to xx@xx.com that didn't trigger for the mail addressed to xx@xx.de
The '554 rejected' is a custom rejection code
Post by SorenR » 2020-08-17 13:19
BeeTee wrote:
2020-08-17 09:40
No bug... Show us your script
The example have two connections to two different recipients and only one is rejected. In my world that means only one rule was satisfied.
I do extensive SPAM handling in my Eventhandlers.vbs and I have never experienced your problem... Developed primarely on 5.4.2 and now running on 5.6.8-custom.
https://www.hmailserver.com/forum/viewt ... 20&t=33602
Post by palinka » 2020-08-17 18:41
2020-08-17 13:19
BeeTee wrote:
2020-08-17 09:40
Can confirm, this happened to me once. I even posted about it somewhere here. Two simultaneous connections: one was rejected, the other processed. IIRC, it was an OnHELO event that triggered it, so it had to be IP or HELO based. I'll look for that thread.
Edit- found it: https://www.hmailserver.com/forum/viewt ... 84#p213084
1) disconnect with RvdH's disconnect.exe
2) autoban for 1 hour
I think that will prevent rate limiting under the same circumstances (single ip connecting again and again within a single minute).
This is not perfect. Since putting it place i went several days without a single duplicate hit. Then today i had two IPs make duplicate hits. In both cases the duplicate connections arrived at the same time down to the same millisecond according to hmailserver log. One of those simultaneous connections got killed immediately and the other died several seconds later. However, all subsequent connections from those IPs were blocked by autoban so at least the damage was limited.
I don't remember specifically the circumstances behind "and the other died several seconds later", but I'm guessing it hit another spam filter along the line. Anyway, the point is that autoban did not work because both connections were literally simultaneous - the log file showed the same time to the millisecond. One of them was picked up by autoban, the other made it through. I'm pretty sure I had result value = 2 with a message, since I've been doing that since forever...
Post by SorenR » 2020-08-17 20:46
@Palinka ... AutoBan eh?
Why do you think I designed the session locking in AutoBan?
It's not a bug, it's by design. You could argue that the design is flawed but ... I had good look through the code and from what I can see the actual SQL "INSERT INTO..." seems to be handled by BOOST so it's not an easy task to add "ON DUPLICATE KEY UPDATE bla bla" to the "INSERT INTO..." statement to eliminate the SQL error that breaks the script.
I'll try to dissect the code over the next couple of days.
Post by SorenR » 2020-08-18 00:17
OK... Playing with this ;-)
    Call oApp.Authenticate(ADMIN, PASSWD)
    Dim strSQL, strDate, SQLDate, oDB : Set oDB = oApp.Database
    strDate = DateAdd(sType, iDuration, Now())
    SQLDate =             Year(strDate)       & "-" & _
              Right("0" & Month(strDate), 2)  & "-" & _
              Right("0" & Day(strDate), 2)    & " " & _
              Right("0" & Hour(strDate), 2)   & ":" & _
              Right("0" & Minute(strDate), 2) & ":" & _
              Right("0" & Second(strDate), 2)
    strSQL = "INSERT INTO hm_securityranges (rangepriorityid, rangelowerip1, rangeupperip1, rangeoptions, rangename, rangeexpires, rangeexpirestime) " &_
             "VALUES (20, " & INET_NTOA(sIPAddress) & ", " & INET_NTOA(sIPAddress) & ", 0, '" & sReason & "', 1, '" & SQLDate & "') " &_
             "ON DUPLICATE KEY UPDATE rangeexpirestime = '" & SQLDate & "';"
    Call oDB.ExecuteSQL(strSQL)
    AutoBan = True
    Set oApp = Nothing
Post by palinka » 2020-08-18 02:41
Seems like simultaneous (within the same millisecond) connections from the same IP are pretty rare, no?
Post by SorenR » 2020-08-18 12:39
2020-08-18 02:41
Yes and no. It's an attack strategy since other mailservers could also be prone to the same "problem".
I had a period of frequent occurencies, that's why I initially did the session locking on AutoBan.
As a side note I made some changes to my script about 3 months back where I for some reason :roll: pasted a version of AutoBan WITHOUT the sesion locking and I noticed 2 incidents of SQL errors in that period until I realised why.
The version of AutoBan using raw SQL INSERT I posted yesterday is for MySQL/MariaDB. Miscosoft SQL do not support "ON DUPLICATE KEY" however the same functionality can be made using "MERGE"...
This example should illustrate usage:
CREATE TABLE #mytable(COL_A VARCHAR(10), COL_B VARCHAR(10), COL_C VARCHAR(10), COL_D VARCHAR(10))
INSERT INTO #mytable VALUES('1','0.1', '0.2', '0.3'); --<These are the values we'll be updating
SELECT * FROM #mytable --< Starting values (1 row)
    MERGE #mytable AS target --< This is the target we want to merge into
    USING ( --< This is the source of your merge. Can me any select statement
        SELECT '1' AS VAL_A,'1.1' AS VAL_B, '1.2' AS VAL_C, '1.3' AS VAL_D --<These are the values we'll use for the update. (Assuming column COL_A = '1' = Primary Key)
        UNION
        SELECT '2' AS VAL_A,'2.1' AS VAL_B, '2.2' AS VAL_C, '2.3' AS VAL_D) --<These values will be inserted (cause no COL_A = '2' exists)
        AS source (VAL_A, VAL_B, VAL_C, VAL_D) --< Column Names of our virtual "Source" table
    ON (target.COL_A = source.VAL_A) --< This is what we'll use to find a match "JOIN source on Target" using the Primary Key
    WHEN MATCHED THEN --< This is what we'll do WHEN we find a match, in your example, UPDATE COL_D = VALUES(COL_D);
        UPDATE SET
            target.COL_B = source.VAL_B,
            target.COL_C = source.VAL_C,
            target.COL_D = source.VAL_D
    WHEN NOT MATCHED THEN --< This is what we'll do when we didn't find a match
    INSERT (COL_A, COL_B, COL_C, COL_D)
    VALUES (source.VAL_A, source.VAL_B, source.VAL_C, source.VAL_D)
    --OUTPUT deleted.*, $action, inserted.* --< Uncomment this if you want a summary of what was inserted on updated.
    --INTO #Output  --< Uncomment this if you want the results to be stored in another table. NOTE* The table must exists
SELECT * FROM #mytable --< Ending values (2 row, 1 new, 1 updated)
BeeTee
Post by BeeTee » 2020-08-19 06:18
This is my script:
This is my script:
On Error Resume Next
	If InStr(oMessage.From,"[b]Health Tips[/b]") then
		Str = oMessage.Date & " Header From include ""Health Tips"": " & oMessage.From & vbcrlf
		call PrintToLog("c:\temp\SpamMails.txt",Str)
		Result.Value = 1
		exit sub
	'Get all headers, using the function GetAllHeaders:
	HeadersStr = "-----------------------------------------------" & vbcrlf & GetAllHeaders(oMessage)
Sub PrintToLog(Path, Str)
	Dim FSO
	'Set WshShell = createObject("WScript.Shell")
	Set FSO = createObject("Scripting.FileSystemObject")
	Set TXTFile = FSO.OpenTextFile(Path,8,True)
	TXTFile.Write Str
	TXTFile.Close
'Return a string with all headers:
Function GetAllHeaders(byref oMessage)
	Dim Header
	Dim Str
	Str = ""
	for i = 0 to oMessage.Headers.count -1
		Set Header = oMessage.Headers.Item(i)
		Str = Str & Header.Name & ": " & Header.Value & vbcrlf
	GetAllHeaders = Str
end Function
If I get two connection, both having "Health Tips" in the From header, one will slip through. And it's not rare, I have at least two spammers doing this on purpose as they apparently know about this "hole"
From the HMailserver log:
"TCPIP"	4756	"2020-08-19 03:33:05.000"	"TCP - 216.24.225.13 connected to 10.0.X.X:25."
"SMTPD"	4756	35591	"2020-08-19 03:33:05.000"	"216.24.225.13"	"SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"TCPIP"	4756	"2020-08-19 03:33:05.016"	"TCP - 216.24.225.14 connected to 10.0.X.X:25."
"SMTPD"	4756	35592	"2020-08-19 03:33:05.032"	"216.24.225.14"	"SENT: 220 Welcome to 84-238-109-18.ptr.bnaa.dk"
"SMTPD"	5528	35591	"2020-08-19 03:33:05.110"	"216.24.225.13"	"RECEIVED: EHLO mta13.cp20.com"
"SMTPD"	5528	35591	"2020-08-19 03:33:05.110"	"216.24.225.13"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5200	35592	"2020-08-19 03:33:05.125"	"216.24.225.14"	"RECEIVED: EHLO mta14.cp20.com"
"SMTPD"	5200	35592	"2020-08-19 03:33:05.125"	"216.24.225.14"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5528	35591	"2020-08-19 03:33:05.219"	"216.24.225.13"	"RECEIVED: STARTTLS"
"SMTPD"	5528	35591	"2020-08-19 03:33:05.219"	"216.24.225.13"	"SENT: 220 Ready to start TLS"
"SMTPD"	4756	35592	"2020-08-19 03:33:05.235"	"216.24.225.14"	"RECEIVED: STARTTLS"
"SMTPD"	4756	35592	"2020-08-19 03:33:05.235"	"216.24.225.14"	"SENT: 220 Ready to start TLS"
"TCPIP"	4756	"2020-08-19 03:33:05.485"	"TCPConnection - TLS/SSL handshake completed. Session Id: 35591, Remote IP: 216.24.225.13, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"TCPIP"	5200	"2020-08-19 03:33:05.500"	"TCPConnection - TLS/SSL handshake completed. Session Id: 35592, Remote IP: 216.24.225.14, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
"SMTPD"	5200	35591	"2020-08-19 03:33:05.594"	"216.24.225.13"	"RECEIVED: EHLO mta13.cp20.com"
"SMTPD"	5200	35591	"2020-08-19 03:33:05.594"	"216.24.225.13"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4756	35592	"2020-08-19 03:33:05.594"	"216.24.225.14"	"RECEIVED: EHLO mta14.cp20.com"
"SMTPD"	4756	35592	"2020-08-19 03:33:05.594"	"216.24.225.14"	"SENT: 250-84-238-109-18.ptr.bnaa.dk[nl]250-SIZE 40960000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5528	35591	"2020-08-19 03:33:05.688"	"216.24.225.13"	"RECEIVED: MAIL FROM:<bounce_hokcell_o-[MyEmail]@cp20.com>"
"SMTPD"	5200	35592	"2020-08-19 03:33:05.703"	"216.24.225.14"	"RECEIVED: MAIL FROM:<bounce_hokcell_o-[MyEmail]@cp20.com>"
"TCPIP"	5528	"2020-08-19 03:33:05.719"	"DNS lookup: 13.225.24.216.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	5200	"2020-08-19 03:33:05.735"	"DNS lookup: 14.225.24.216.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	5200	"2020-08-19 03:33:05.766"	"DNS lookup: 14.225.24.216.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP"	5528	"2020-08-19 03:33:05.829"	"DNS lookup: 13.225.24.216.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP"	5200	"2020-08-19 03:33:05.907"	"DNS lookup: 14.225.24.216.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP"	5528	"2020-08-19 03:33:05.953"	"DNS lookup: 13.225.24.216.bb.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP"	5200	"2020-08-19 03:33:06.016"	"DNS lookup: 14.225.24.216.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP"	5528	"2020-08-19 03:33:06.063"	"DNS lookup: 13.225.24.216.psbl.surriel.com, 0 addresses found: (none), Match: False"
"TCPIP"	5200	"2020-08-19 03:33:06.094"	"DNS lookup: 14.225.24.216.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"TCPIP"	5528	"2020-08-19 03:33:06.110"	"DNS lookup: 13.225.24.216.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"SMTPD"	5200	35592	"2020-08-19 03:33:06.141"	"216.24.225.14"	"SENT: 250 OK"
"SMTPD"	5528	35591	"2020-08-19 03:33:06.157"	"216.24.225.13"	"SENT: 250 OK"
"SMTPD"	4756	35592	"2020-08-19 03:33:06.235"	"216.24.225.14"	"RECEIVED: RCPT TO:<[MyEmail]>"
"SMTPD"	4756	35592	"2020-08-19 03:33:06.250"	"216.24.225.14"	"SENT: 250 OK"
"SMTPD"	5528	35591	"2020-08-19 03:33:06.266"	"216.24.225.13"	"RECEIVED: RCPT TO:<[MyEmail]>"
"SMTPD"	5528	35591	"2020-08-19 03:33:06.282"	"216.24.225.13"	"SENT: 250 OK"
"SMTPD"	4392	35592	"2020-08-19 03:33:06.344"	"216.24.225.14"	"RECEIVED: DATA"
"SMTPD"	4392	35592	"2020-08-19 03:33:06.344"	"216.24.225.14"	"SENT: 354 OK, send."
"SMTPD"	5528	35591	"2020-08-19 03:33:06.375"	"216.24.225.13"	"RECEIVED: DATA"
"SMTPD"	5528	35591	"2020-08-19 03:33:06.391"	"216.24.225.13"	"SENT: 354 OK, send."
"SMTPD"	2888	35591	"2020-08-19 03:33:06.875"	"216.24.225.13"	"SENT: 554 Rejected"
"SMTPD"	4640	35592	"2020-08-19 03:33:06.891"	"216.24.225.14"	"SENT: 250 Queued (0.512 seconds)"
The one mail which got through doesn't seem to be "seen" by the event at all.
This is the header from the spam-mail which came through:
Return-Path: bounce_hokcell_o-[MyEmail]@cp20.com
Received: from mta14.cp20.com (mta14.cp20.com [216.24.225.14]) by xx.xx.xx.xx.ptr.bnaa.dk
 with ESMTPS (version=TLSv1.2 cipher=ECDHE-RSA-AES256-GCM-SHA384 bits=256) ;
 Wed, 19 Aug 2020 03:33:06 +0200
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; s=key1; d=cp20.com; h=List-Unsubscribe:Message-ID:Date:Subject:To:From:Reply-To:MIME-Version:
 Content-Type; bh=0yJIXw9wLAQuaJ5BnSftycn6nTXuHDBMjWGryHaGhB4=; b=iYKtFzheddeYgnqheUXx7/TNGNEj+seI3sU5caIj22J8ieAbrF9XleENnQaV0D877k3uWrmfPP3M
 3yS/jXO+EbYQHrpeIlHWm6F24veAMNVILWIYcafM7N7ToHLzOk2oWk2tRmibtSGPquXAwPLMSSE0
 s5OvWRO0EuG4SH5wveY=
Received: by mta14.cp20.com id h7i0jk2kcoop for <[MyEmail]>; Tue, 18 Aug 2020 21:32:36
 -0400 (envelope-from <bounce_hokcell_o-[MyEmail]@cp20.com>)
List-Unsubscribe: <mailto:unsub_savjwn_gqgjtsod_o@cp20.com?subject=unsubscribe>
X-Campaign-Shard: 1
Bounces-To: bounce_savjwn_gqgjtsod_o@cp20.com
Message-ID: <1597800727537.45643175.135646788.30436393851@backend.cp20.com>
X-Campaign: 45643175/135646788/30436393851
Errors-To: bounce_savjwn_gqgjtsod_o@cp20.com
Date: Tue, 18 Aug 2020 21:32:36 -0400
Subject: The Power of Healing
To: <[MyEmail]>
From: "Health Tips" <contact@premierehealthtips.com>
Reply-To: "Health Tips" <reply_savjwn_gqgjtsod_o@cp20.com>
MIME-Version: 1.0
Content-Type: text/html;charset=UTF-8
X-hMailServer-LoopCount: 1
Post by SorenR » 2020-08-19 09:07
You may want to change
to
If InStr(oMessage.From,"Health Tips") then
if you want to catch this
Also...
Using "On Error Resume Next" in the root of the script is asking for trouble. Why do you even have it there?
Remove it and change this code ...
	Dim FSO
	TXTFile.Write Str
	TXTFile.Close
to
	Dim FSO
	If (Err.Number <> 0) Then
		EventLog.Write( "ERROR: EventHandlers.vbs : Sub PrintToLog" )
		Err.Clear
	TXTFile.Write Str
	TXTFile.Close
	On Error GoTo 0
BeeTee
Post by BeeTee » 2020-08-22 14:32
Thanks for your improvements :-)
(The bold tags "[ b ]" are not in my real script, can not explain how they ended up in the copy here)
So, I'll still claim the issue exist, that one or more of multiple/simultaneous connections are not being handled by the Event, right.
(I awaits the next slip-through if any)
Post by SorenR » 2020-08-22 17:12
BeeTee wrote:
2020-08-22 14:32
No problem, du skriver bare igen hvis det sker igen.
