Regular Expression for end character not working
milis75
Post by milis75 » 2020-09-17 12:44
Hi All,
I use Regular Expression .+?\.mx to filter email address with last character .mx
in test rule is match
but not working if any message from abcd@efgh.mx
how to forward & delete email from VBscript because Criteria logic cannot combine AND and OR
Thx guys :D
Re: Regular Expression for end character not working
Post by jimimaseye » 2020-09-17 14:07
.+?\.mx
works for me.
Have you actually tried it?
Also read this for tips and explanations: https://www.hmailserver.com/forum/viewt ... 21&t=29179
Post by katip » 2020-09-17 15:11
have you tried custom header field From?
or try custom header X-Envelope-From
Post by SorenR » 2020-09-17 19:32
katip wrote:
2020-09-17 15:11
"From:" syntax is "name <user@domain.tld>"
"From:" can be faked using any mail client
"X-Envelope-From:" an identified user on the sending server sending the email. Need modified MTA to fake.
milis75
Post by milis75 » 2020-09-18 02:36
2020-09-17 14:07
.+?\.mx
works for me.
of course I have tried, Sir ... I told before in the test is match
Thx for Tips Reg Exp 8)
milis75
Post by milis75 » 2020-09-18 02:40
katip wrote:
2020-09-17 15:11
Not yet
I will try to other Criteria ,...
but actually I want Criteria "From"
milis75
Post by milis75 » 2020-09-18 03:21
Mr SorenR & Katip
It Turn out that from "abcd@efgh.MX" it must be written in Regular Expression ".MX>"
not just ".MX" ... So I write less > character become Regular Expression not working
Thank you All :wink:
Post by katip » 2020-09-18 08:12
2020-09-17 19:32
katip wrote:
2020-09-17 15:11
indeed, i intentionally didn't considered brackets (<>) as they may or not appear in From. i'm not sure if they MUST or not as per RFC though, anyway we receive such mails.
OTOH, from one recent spam i received:
From: "Disfruta <info@dis-fruta.mx>" <j.martinez@stanleyadams.com.de>
it's a perfect From, but that regex would fail.
hence, a better regex could be
.+?\.mx(|>)$
Post by palinka » 2020-09-18 20:51
katip wrote:
2020-09-18 08:12
2020-09-17 19:32
katip wrote:
2020-09-17 15:11
.+?\.mx(|>)$
Maybe a small improvement here:
.*\.mx(>|"){0,2}$
Will catch:
From: "Disfruta <info@dis-fruta.mx>" <j.martinez@stanleyadams.com.mx>
And:
I'm just circling back to Soren's statement:
Here the string ends with both > and "
I don't even know if that happens in real life. :D
Post by SorenR » 2020-09-19 00:28
2020-09-18 20:51
Okay... I was quoting a string... Real life examples that I check for (script wise) are:
<taz@acme.inc>
Devil <taz@acme.inc>
"Tasmanian Devil" <taz@acme.inc>
Post by palinka » 2020-09-19 03:11
