Return-Path index of oMessage.Headers(index).Name Not found
milis75
Post by milis75 » 2020-09-18 07:13
Hi All,
My Question is
1. Why Header Return-path not found in index
2. and how I get Headers("Return-Path")
I just looping of index header and the result like this
:arrow:
Received index of : 0
From index of : 1
To index of : 2
References index of : 3
In-Reply-To index of : 4
Subject index of : 5
Date index of : 6
Message-ID index of : 7
MIME-Version index of : 8
Content-Type index of : 9
Content-Transfer-Encoding index of : 10
X-Mailer index of : 11
Thread-Index index of : 12
Content-Language index of : 13
Thank You
Re: Return-Path index of oMessage.Headers(index).Name Not found
Post by mattg » 2020-09-18 13:27
But what if there is no 'return-path'??
Post by SorenR » 2020-09-18 13:54
Unless the email is spoofed, the general rule is that "Return-Path" = "oMessage.FromAddress" (AKA X-Envelope-From).
The header "Return-Path" is the very last thing added to the email before it is dropped into the INBOX. That is why it is the first line in the .eml file when you open it with a text editor.
"oMessage.FromAddress" is available in:
Sub OnDeliveryStart(oMessage)
Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
and
Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
milis75
Post by milis75 » 2020-09-21 06:02
I want to alert the user whether the email is fake or not based on the return-path, not oMessage.FromAddress or oMessage.From
I use criteria of rule failed
I use VBscript failed too
vbscript for generate index header like it
Dim oHeader
For oHeader = 0 to oMessage.Headers.Count-1
oMessage.Body = oMessage.Body & _
vbCrLf & oMessage.Headers(oHeader).Name & " index of : " & oHeader
oMessage.Save()
thx u :)
Post by SorenR » 2020-09-21 11:41
Good luck!
