SMTP Forwarding original IP
Rob887
Post by Rob887 » 2020-11-13 12:31
Hello.
Is there a way to stop the hmail smtp server sending the original IP of the sender
"Received: from [192.168.1.191] (host-80-4****285.net [80.**.*.211]) by mail.renb***kers.co.uk with ESMTPA ; Fri, 13 Nov 2020 11:21:10 +0100"
They are getting marked as spam as the senders IP is normally in a blacklist.
I didn't think it should forward IP of the mail clients computer.
kind regards
Re: SMTP Forwarding original IP
Post by jimimaseye » 2020-11-13 12:41
No - this is how SMTP works. Declaring your IP address allows such checking and ultimately stops spammers bypassing blacklists. If you are on a Blacklist then it's for a reason. You should address the CAUSE of being on a blacklist rather than cheating your way around it.
(The email client ip address in the headers ("[192.168.1.191") is not the cause of being on a blacklist.)
Rob887
Post by Rob887 » 2020-11-13 12:58
Thank you.
Its the "80.**.*.211" thats in the black list from one of our clients with dynamic IP.
Just interesting that Gmail smtp and other ISP doesn't forward this header?
thank you
Post by SorenR » 2020-11-13 12:59
Rob887 wrote:
2020-11-13 12:31
You have a problem...
"[192.168.1.191]" is the HELO/EHLO greeting.
"host-80-4****285.net" is the PTR-record of the sender.
"80.**.*.211" is the IP Address of the sender.
"mail.renb***kers.co.uk" is the DNS name of the receiving server.
As such the HELO/EHLO greeting is perfectly legal EXCEPT for the fact that the IP Address must match the senders IP Address and for that reason alone it is SPAM!
Rob887
Post by Rob887 » 2020-11-13 13:01
on spam test we are getting
-3.558 RCVD_IN_SBL_CSS Received via a relay in Spamhaus SBL-CSS
80.****.211 listed in zen.spamhaus.org
Post by SorenR » 2020-11-13 13:06
Rob887 wrote:
2020-11-13 13:01
Yes, that is how it works.
Rob887
Post by Rob887 » 2020-11-13 13:21
Thank you
I've noticed smtp like gmail,outlook don't seem to send this header with sender IP.
So is it a requirement?
thanks
Post by SorenR » 2020-11-13 16:14
Rob887 wrote:
2020-11-13 13:21
Thank you
thanks
YES! It is as described in the RFC's.
What you fail to understand is: This is a header added by the server mail.renb***kers.co.uk (not a hMailServer ... Exim ??) when receiving mail from the hMailServer on 80.****.211... It is part of the required routing information.
If you send from e.g. Outlook client it will say so in the Received header.
Rob887
Post by Rob887 » 2020-11-13 21:08
2020-11-13 16:14
Rob887 wrote:
2020-11-13 13:21
Thank you
thanks
I'm getting super confused now..
mail.renb***kers.co.uk is my hmailserver.
80.****.211 is the ip of one of our computers in a seperate office running thunderbird client to send emails.
I've managed a work around with some scripting. (doesn't seem to be having any negative effect)
	If Len(oClient.Username) > 0 Then
		Dim oHeaders
		set oHeaders = oMessage.Headers
		Dim i
		For i = oHeaders.Count -1 To 0 Step -1
			dim oHeader
			Set oHeader = oHeaders.Item(i)
			if LCase(oHeader.Name) = "received" Then
				oHeader.Delete
				EventLog.Write("Anonymised: " + oClient.Username + " / " + oMessage.To)
Post by SorenR » 2020-11-13 22:59
Okay... I missed the "A" in "ESMTPA". The "A" means that the SMTP connection is authenticated.
AFAIK hMailServer do not do SPAM testing on authenticated SMTP connections, but I could be wrong.
The complete email headers would have made it easier to decode.
Are you using SpamAssassin on your server?
Because this is SpamAssassin:
Rob887
Post by Rob887 » 2020-11-13 23:12
2020-11-13 22:59
Sorry I should of explained better and included more details.
The Spam Assassin score is from mail-tester. Com website when I was testing the spam level of emails that get sent through our hmailserver. I got confused as I would not class the person sending the email as a relay.
The worst score was from the ip of the sending client being included in a black list.
Also rDNS but that's now sorted
Post by jimimaseye » 2020-11-14 00:05
2020-11-13 22:59
Don't worry, you are not wrong.
Post by mattg » 2020-11-14 00:56
Rob887 wrote:
2020-11-13 12:31
Hello.
You can remove existing 'Received from' headers in mail that you then send OUTBOUND to another server
https://www.hmailserver.com/documentati ... ve_headers
Rob887
Post by Rob887 » 2020-11-15 11:02
2020-11-14 00:56
Rob887 wrote:
2020-11-13 12:31
Hello.
Thank you. That's what I used and its sorted the problem
Post by SorenR » 2020-11-15 12:20
Rob887 wrote:
2020-11-15 11:02
2020-11-14 00:56
Rob887 wrote:
2020-11-13 12:31
Hello.
Removing "Received:" headers is breaking the RFC's.
RFC 1123:
5.2.8 DATA Command: RFC-821 Section 4.1.1
Every receiver-SMTP (not just one that "accepts a message for
relaying or for final delivery" [SMTP:1]) MUST insert a
"Received:" line at the beginning of a message. In this line,
called a "time stamp line" in RFC-821:
  • The FROM field SHOULD contain both (1) the name of the
    source host as presented in the HELO command and (2) a
    domain literal containing the IP address of the source,
    determined from the TCP connection.
  • The ID field MAY contain an "@" as suggested in RFC-822,
    but this is not required.
  • The FOR field MAY contain a list of <path> entries when
    multiple RCPT commands have been given.
An Internet mail program MUST NOT change a Received: line that
was previously added to the message header.
Rob887
Post by Rob887 » 2020-11-16 21:43
2020-11-15 12:20
Rob887 wrote:
2020-11-15 11:02
2020-11-14 00:56
RFC 1123:
Thank you for that.
It looks like many of the bigger smtp use "X-Originating-IP" instead of putting the senders IP as a 'From' headers. (After looking at g-mails headers I still can't see the person writing the emails IP)
Does spamassassin mark down "X-Originating-IP" as much as it does with the 'from' header as it thinks its a 'Smtp relay'
Thank you for your advice.
Post by SorenR » 2020-11-17 00:07
Rob887 wrote:
2020-11-16 21:43
Thank you for that.
Well, if you have to do it you may as well do it right... The GMail way...
Received: by mail.acme.inc with ESMTPSA (version=TLSv1.2 cipher=ECDHE-RSA-AES256-GCM-SHA384 bits=256) ; Mon, 16 Nov 2020 22:55:11 +0100
"Local" senders MUST authenticate for this to work.
"ESMTPA" = Extended SMTP Authenticated
"ESMTPSA" = Extended SMTP Authenticated using SSL or StartTLS
Sub OnDeliveryStart(oMessage)
    If InStr(oMessage.HeaderValue("Received"), "ESMTPSA") or InStr(oMessage.HeaderValue("Received"), "ESMTPA") Then
	    oMessage.HeaderValue("Received") = Mid(oMessage.HeaderValue("Received"), InStr(oMessage.HeaderValue("Received"), "by "))
DISCLAIMER
It works on my server but that is no gurantee it will work on your server.
Rob887
Post by Rob887 » 2020-11-17 21:48
Thank you.
That works
