U-351
- New user
Post
by U-351 » 2020-11-19 09:16
Hi
I trying make a message forwardng by condition
If (InStr(oMessage.Subject,rutflag)>0) Then
oMessage.AddRecipient "Server_Forward","xxx@yyy.zzz"
oMessage.RefreshContent()
If rutflag is latin - strinig routine work normal.
If rutflag is non-latin/cyrylic - routine no work.
In message i seen
Subject: =?UTF-8?B?0KDRg9GC0LXQutGB?=
Is it possible to search for a substring in UTF-8?
- Senior user
Post
by SorenR » 2020-11-19 14:19
Dim ECFlag, SFlag : SFlag = False
ECFlag = oMessage.EncodeFields
' Use RAW data
oMessage.EncodeFields = False
If InStr(1, oMessage.Subject, "?koi8-r", 1) > 0 Then
' Do STUFF ... Set SFlag if content is changed.
SFlag = True
If SFlag Then oMessage.Save
' Restore MIME decoding
oMessage.EncodeFields = ECFlag
U-351
- New user
Post
by U-351 » 2020-11-20 14:04
Thank You!
Solved problem another way.
Add regexp rule and add Simple routine on it. Thus, the string conversion is done by the server engine.
