Hmail server rules failing
chuanDK
Post by chuanDK » 2020-12-08 15:17
Hi Guys
I would like my server only to only accept mail from "no-reply@Mydomain.com" and then forward that mail to "distlist@Mydomain.com" without sending the email to the original receiver of the mail.
But only send the mail to the distlist@Mydomain.com
If the sender of the mail is not "no-reply@Mydomain.com" the server should delete the email.
I have tried to create this rule
to : equals: *
Actions:
Forward email to distlist@Mydomain.com
Delete email
I also tried to split the rules up.
to : not equals: distlist@Mydomain.com
Action Delete Email.
But is does not work.
any suggestions ?
Br
Christian
Re: Hmail server rules failing
Post by SorenR » 2020-12-08 15:25
change "equals" to "contains"
"From" is in the format
"jens vejmand" <vejmand@trafikstyrelsen.dk>
chuanDK
Post by chuanDK » 2020-12-09 11:04
Hi Søren
Thanks for you reply. I really appreciate it :)
I tried tried to change the "equals" to "contains"
The result is that the original recipient of the mail and the distribution list receives the email.
But I would like to avoid that the original recipient receives the mail. So its just the distribution list that receives the email.
Du you have an idea how to solve that ?
Thanks in advance and best regards ¨
Christian
Post by SorenR » 2020-12-09 11:43
This is how we normally do this... Configure it as a "global" rule.
X-hMailServer-LoopCount keep track of how many times an email is forwarded so we can prevent circular references.
If original recipient still receive the email he/she must be on the distlist ...
PS. Yes, I know the rule on the image is not enabled ;-)
chuanDK
Post by chuanDK » 2020-12-09 14:55
Hi Søren
Great that did i !!
Thank you so much :D
Have a nice day
Best regards
Christian
