Simple Auto Whitelist
Post by palinka » 2020-12-30 01:51
I've been giving auto whitelisting some thought. I looked at one in the scripting forum and thought, dang, that's complicated. It doesn't need to be.
The concept behind auto whitelisting is if a sender was a recipient in the past (of the current recipient), then the sender must be valid. This information is available in the hmailserver database. Why create new tables or text files to hold this info?
Here's my go at it. I recycled Soren's whitelisting function to make it work. The function deletes any reference to spam score, therefore bringing the spam score to 0 if there was a score.
All my function does is check hm_message_metadata to see if current recipient has sent N messages to the current sender in the past X days. If true, it calls Soren's whitelist function.
It does NOT modify hMailServer whitelist. Relies on MySQL database, so other databases would need a different query and connection.
Sub WhiteList(oMessage, strMatch)
    Dim i
    If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
        oMessage.HeaderValue("X-hMailServer-WhiteList") = strMatch
        oMessage.Headers.ItemByName("X-hMailServer-Spam").Delete
        For i = 0 To 10
            If (oMessage.HeaderValue("X-hMailServer-Reason-" & i) <> "") Then oMessage.Headers.ItemByName("X-hMailServer-Reason-" & i).Delete
        oMessage.Headers.ItemByName("X-hMailServer-Reason-Score").Delete
Function IsSenderAutoWhitelisted(m_Sender, m_Recipient) : IsSenderAutoWhitelisted = False
	Dim LookBackDays : LookBackDays = 90  '<--- Number of days to look back to see if sender was recipient
	Dim MinSent : MinSent = 3             '<--- Min number of messages previously sent to sender in order to whitelist sender
	Dim CountSent : CountSent = 0
	oConn.Open "Driver={MariaDB ODBC 3.1 Driver}; Server=localhost; Database=hmailserver; User=hmailserver; Password=supersecretpassword;"
	If oConn.State <> 1 Then
		EventLog.Write( "Sub WhitelistSender - ERROR: Could not connect to database" )
		CountSent = 0
		Exit Function
	Set oRecord = oConn.Execute("SELECT COUNT(*) AS count FROM hm_message_metadata WHERE metadata_dateutc > NOW() - INTERVAL " & LookBackDays & " DAY AND metadata_from REGEXP '" & m_Recipient & "' AND metadata_to REGEXP '" & m_Sender & "';")
	Do Until oRecord.EOF
		CountSent = oRecord("count")
		oRecord.MoveNext
	Loop
	oConn.Close
	Set oRecord = Nothing
	If CInt(CountSent) > MinSent Then IsSenderAutoWhitelisted = True
	REM - Auto Whitelisting
	If oClient.Username = "" Then
		If IsSenderAutoWhitelisted(oMessage.FromAddress, oMessage.Recipients(0).OriginalAddress) Then
			Call WhiteList(oMessage, "AutoWhitelist From = '" & oMessage.FromAddress & "'")
			Exit Sub
Re: Simple Auto Whitelist
Post by jimimaseye » 2020-12-30 02:01
There is a script around here somewhere that does as you describe. I think it was written by soren.
Maybe worth comparing.
Post by palinka » 2020-12-30 02:09
2020-12-30 02:01
I looked. Didn't see it. My google-fu is poor. :oops:
Post by SorenR » 2020-12-30 03:01
2020-12-30 02:01
IIRC it was a dynamic Greylist Whitelisting ... https://www.hmailserver.com/forum/viewt ... 49#p205049
Post by palinka » 2020-12-30 04:15
2020-12-30 03:01
2020-12-30 02:01
So it is kinda sorta original! :mrgreen:
Post by katip » 2020-12-30 05:03
2020-12-30 02:01
probably this by Percepts here : https://www.hmailserver.com/forum/viewt ... ts#p184106
Post by mattg » 2020-12-30 05:19
2020-12-30 01:51
I like the simplicity of this concept
Post by katip » 2020-12-30 05:57
2020-12-30 05:19
concept is useful and serves me fine since many years.
however in case of BATV (fortunately not so common yet) it's useless. i add such Froms to SA whitelist - just as a workaround, not wise.
Post by jimimaseye » 2020-12-30 10:15
2020-12-30 02:01
Perhaps I was thinking of this but you will already be aware of it : https://www.hmailserver.com/forum/viewt ... 20&t=33602
Post by palinka » 2020-12-30 16:17
2020-12-30 10:15
2020-12-30 02:01
This one is manual white list (and blacklist, and others, etc). Not automatic.
Post by palinka » 2020-12-30 16:18
katip wrote:
2020-12-30 05:57
2020-12-30 05:19
What is BATV?
Post by palinka » 2020-12-30 16:29
katip wrote:
2020-12-30 05:03
2020-12-30 02:01
This is a good one, but it adds every single recipient to the whitelist. I figured more than one message sent should be required before adding to the whitelist.
Adding my multiple sent check to percept's script would be a snap. But i didn't want to even touch the whitelist, with the idea that a) it should be reserved for "real" or problematic entries, and b) hey, it's not as simple and this is the ez-bake version. :D
Post by SorenR » 2020-12-30 17:04
2020-12-30 16:18
katip wrote:
2020-12-30 05:57
2020-12-30 05:19
What is BATV?
https://en.wikipedia.org/wiki/Bounce_Ad ... Validation
Post by palinka » 2020-12-30 20:34
2020-12-30 17:04
2020-12-30 16:18
katip wrote:
2020-12-30 05:57
What is BATV?
Ahhh... yeah, no bounce addresses would work with this, so marketing email would be out. But who replies to that anyway?
Post by katip » 2020-12-31 05:36
2020-12-30 20:34
not only marketing crap. some of our customers (particularly biggers such as P&G, Skoda, Electrolux...) use it too.
recently i noticed one message from an agent with whom we exchange mail since 10 years (so in W/L of course), suddenly blocked by SA due to an attachment. it came out they changed their ISP who stamps mails with BATV.
i maintain a small section of 10-15 "whitelist_from_received" in SA W/L for such cases. other than that i'm very satisfied with auto-whitelist concept. it saves lots of CPU.
