Instantiation of Application object
mikedibella
Post by mikedibella » 2021-01-09 22:31
Is there an existing instantiation of the Application object, that is already authenticated, exposed within the event handlers and rule-triggered scripts? What is it's name?
Reason: My rule-triggered script need to access the parent Account for the oMessage message parameter, and access the parent Domain for the Account.
Code examples of same appreciated.
Re: Instantiation of Application object
Post by mattg » 2021-01-10 03:03
To ensure that I meet the Australian laws about logging specific detail, I write custom per-domain logs
Function DomainLogging(oMessage)
	'custom event
	'uses functions: CustomMonthlyLog
	'called from: Rules
	Dim i, j, oDomain, temptext, oApp, Local, tempDomain
	' hMailServer settings.
	tempDomain = Right(oMessage.FromAddress, Len(oMessage.FromAddress) - InStr(oMessage.FromAddress,"@"))
	Local = 0
	For i = 1 to oApp.domains.count
		if (InStr(1, tempDomain, oApp.Domains.item(i-1).name, 1) > 0) Then ' Local sender
			local = local + 1
			oDomain = tempDomain
		For j = 1 to oApp.Domains.item(i-1).DomainAliases.count
			if (InStr(1, tempDomain, oApp.Domains.item(i-1).DomainAliases.item(j-1).AliasName, 1) > 0) Then ' Local user.
				local = local + 1
				oDomain = oApp.Domains.Item(i-1).Name
		Next 'j
	Next 'i
	If Local > 0 Then
		CustomMonthlyLog "", oDomain
		CustomMonthlyLog " New email from " & oMessage.FromAddress, oDomain
		CustomMonthlyLog "   Subject is:-" & oMessage.Subject, oDomain
		CustomMonthlyLog "   	Number of recipients is " & oMessage.Recipients.Count & _
			"  Number of Attachments is " & oMessage.Attachments.Count, oDomain
		For i = 1 To oMessage.Recipients.Count
			temptext = "       Recipient number " & i & " is " & oMessage.Recipients.Item(i-1).Address
			CustomMonthlyLog temptext, oDomain
		For i = 1 To oMessage.Attachments.Count
			temptext = "       Attachment number " & i & " is " & oMessage.Attachments.Item(i-1).filename
			Call CustomMonthlyLog( temptext, oDomain)
		CustomMonthlyLog "      Message size is:-" & oMessage.Size, oDomain
