Expand Shortened URLs
Post by palinka » 2024-04-04 22:21
I've been thinking about this for a while and finally set out to do it. Expand shortened URLs in messages and test the domain against SURBL and Spamhaus DBL. I have a working framework. I still need to compile a list of common URL shorteners to use to capture these short links within messages. But I'll get to that later. Below is my working test script.
Option Explicit
Private Const SpamhausDQSKey = "supersecretkey"
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
'Requires RvdH DNSResolver
Function IsInSurbl(strDomain) : IsInSurbl = False
	Dim strLookup
		strLookup = .DNSLookup(strDomain & ".multi.surbl.org")
	Dim strRegEx : strRegEx = "(127\.0\.1\.[0-9]{1,3})"
	IsInSurbl = Lookup(strRegEx, strLookup)
'Requires Spamhaus DQS Key
Function IsInSpamHausDBL(strDomain) : IsInSpamHausDBL = False
	Dim strLookup
		strLookup = .DNSLookup(strDomain & "." & SpamhausDQSKey & ".dbl.dq.spamhaus.net")
	Dim strRegEx : strRegEx = "(127\.0\.1\.(2|4|5|6))"
	IsInSpamHausDBL = Lookup(strRegEx, strLookup)
Function ExpandURL(ShortURL)
	Dim Request : Set Request = CreateObject("MSXML2.ServerXMLHTTP")
	Request.Open "HEAD", ShortURL, False
	Request.Send
	ExpandURL = Request.GetOption(-1)
Dim ShortURL, LongURL, Domain, Match, Matches
ShortURL = "https://tinyurl.com/y9b46am6"
LongURL = ExpandURL(ShortURL)
Set Matches = oLookup("(?:\bhttps?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+\b)", LongURL, False)
If Matches.Count > 0 Then
	For Each Match In Matches
		Domain = Match.SubMatches.Item(0)
WScript.Echo Domain & " is the domain of the long URL"
If IsInSurbl(Domain) Then WScript.Echo Domain & " LISTED IN SURBL!!!"
If IsInSpamHausDBL(Domain) Then WScript.Echo Domain & " LISTED IN SPAMHAUS DBL!!!"
Re: Expand Shortened URLs
Post by palinka » 2024-04-04 22:25
Well, the list of URL shorteners was easy to find.
https://raw.githubusercontent.com/Peter ... aster/list
I'll make a function to find short links within message body using that list later.
Post by katip » 2024-04-05 04:20
Good idea.
IIRC SA has a plugin for this.
HMS 5.7, MariaDB 10.4.10, SA 4.0.0, ClamAV 0.103.8
Post by RvdH » 2024-04-05 08:58
katip wrote:
2024-04-05 04:20
Good idea.
Exactly, I use it with MySQL/MariaDB as a database backend to cache decoded entries (url_shortener entries are included in default rules and also via KAM_urlshorteners.cf)
https://spamassassin.apache.org/full/4. ... tURLs.html
Post by palinka » 2024-04-05 15:12
Powershell to download list and format to vbs regex. Run once a day, once a year... I doubt the list changes often, but the last update to the github file was last week.
<#  Set script variables  #>
# https://github.com/PeterDaveHello/url-shorteners
$URL = "https://raw.githubusercontent.com/PeterDaveHello/url-shorteners/master/list"
$ShortLinkFile = "$PSScriptRoot\ShortLinkProviders.txt"
$ShortLinkRegexFile = "C:\hMailServer\Events\short_link_provider_regex.vbs"
<#  Download Shortlink Provider List  #>
Try {
	Start-BitsTransfer -Source $URL -Destination $ShortLinkFile -ErrorAction Stop
Catch {
	$Err = $Error[0]
	Write-Output "$((Get-Date).ToString('yyyy-MM-dd HH:mm:ss')) : Error downloading Public Suffix List : `n$Err" | Out-File "$PSScriptRoot\PubSufError.log" -Append
	Exit
<#  Read data file and output list formatted for RegEx (surround each with ^ and $)  #>
Get-Content $ShortLinkFile | Where {((-not([string]::IsNullOrEmpty($_))) -and ($_ -notmatch "^#"))} | ForEach {
	Write-Output "^$_$"
} | Out-File $ShortLinkRegexFile
<#  Convert list to RegEx pattern  #>
(Get-Content -Path $ShortLinkRegexFile) -Replace '$','|' | Set-Content -NoNewline -Path $ShortLinkRegexFile
(Get-Content -Path $ShortLinkRegexFile) -Replace '\.','\.' | Set-Content -NoNewline -Path $ShortLinkRegexFile
(Get-Content -Path $ShortLinkRegexFile) -Replace '^','Dim ShortLinkProviderRegEx : ShortLinkProviderRegEx = "' | Set-Content -NoNewline -Path $ShortLinkRegexFile
(Get-Content -Path $ShortLinkRegexFile) -Replace '\|$','' | Set-Content -NoNewline -Path $ShortLinkRegexFile
(Get-Content -Path $ShortLinkRegexFile) -Replace '$','"' | Set-Content -NoNewline -Path $ShortLinkRegexFile
Working vbs test script.
Option Explicit
Private Const ShortLinkRegExPath = "C:\hMailServer\Events\short_link_provider_regex.vbs"
Function Include(sInstFile)
	Dim f, s, oFSO
	On Error Resume Next
	If oFSO.FileExists(sInstFile) Then
		Set f = oFSO.OpenTextFile(sInstFile)
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	Dim strLookup
	Dim strLookup
	Request.Send
Include(ShortLinkRegExPath)
Dim ShortURL, LongURL, Domain, Match, Matches, SLMatch, SLMatches, UMatch, UMatches, MessageBody, strRegEx, URLToInspect, ShortLinkDomainToInspect
MessageBody = 	"Howdy, y'all! Right here's a message with some URLs." & _
				"Here's a bony fide short link https://tinyurl.com/y4aa47p4 right in the middle of the message." & _
				"And here's a long link https://hmailserver.com/forum/viewtopic.php?f=9&t=41891 to use as a control." & _
				"And here's a short link embedded in html <a href=""https://shorturl.at/AHRX5"">Come 'n' git some spam!</a>" & _
				"And here's a long link embedded in html <a href=""https://hmailserver.com/forum/viewtopic.php?f=9&t=41891"">Expand Shortened URLs - hMailServer Forum</a>" & _
				"And lastly, just an extra line for fun."
strRegEx = "(\b((https?(:\/\/|%3A%2F%2F))((([a-zA-Z0-9-]+)\.)+[a-zA-Z0-9-]+)(:\d+)?((?:\/[\+~%\/\.\w\-_]*)?\??(?:[\-\+=&;%@\.\w_]*)#?(?:[\.\!\/\\\w]*))?)\b)"
Set Matches = oLookup(strRegEx, MessageBody, True)
WScript.Echo Matches.Count & " URL matches found in message body"
	For Each Match in Matches
		URLToInspect = Match.SubMatches.Item(0)
		WScript.Echo " "
		WScript.Echo "URL found in message body: " & URLToInspect
		Set UMatches = oLookup("(?:\bhttps?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+\b)", URLToInspect, False)
		If UMatches.Count > 0 Then
			For Each UMatch in UMatches
				ShortLinkDomainToInspect = UMatch.SubMatches.Item(0)
		If Lookup(ShortLinkProviderRegEx, ShortLinkDomainToInspect) Then
			WScript.Echo "Shortlink found in message body: " & URLToInspect
			LongURL = ExpandURL(URLToInspect)
			WScript.Echo "Expanded URL: " & LongURL
			Set SLMatches = oLookup("(?:\bhttps?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+\b)", LongURL, False)
			If SLMatches.Count > 0 Then
				WScript.Echo "Domain for expanded URL found"
				For Each SLMatch In SLMatches
					Domain = SLMatch.SubMatches.Item(0)
					WScript.Echo "Domain for expanded URL: " & Domain
					REM -
					REM - Here is where you operate
					REM -
					If IsInSurbl(Domain) Then WScript.Echo Domain & " LISTED IN SURBL!!!" Else WScript.Echo "not listed in SURBL"
					If IsInSpamHausDBL(Domain) Then WScript.Echo Domain & " LISTED IN SPAMHAUS DBL!!!" Else WScript.Echo "not listed in Spamhaus DBL"
					REM -
					REM -
Tonight I'll integrate it into eventhandlers.vbs.
Post by palinka » 2024-04-06 17:46
Looks like this is a nothing burger. I made a script that looks for shortlinks in my mysql message log. There are about 5,300 messages in the log including all spam received and deleted by spam rules.
1. Looks for every URL.
2. If URL domain matches the shortlink provider list, it expands the shortlink through a recursive expansion function in order to actually get the final destination - i noticed that there are often many hops and I think that's intentional.
3. If the final destination URL contains a referrer, the referrer URL is used instead of the destination URL.
4. The domain is parsed from the destination URL or referred URL and gets tested against SURBL and Spamhaus DBL.
Result: 0 hits from 5,300 messages containing a lot of spam.
I would guess (purely a guess based on observation, but not actually counting anything) that about half of the shortlinks were malicious spam links.
Maybe I'll run it again to check both destination URLs and referred URLs. I had a preference for referred URLs thinking that why go though all the trouble of making them if the referrer was the malicious link? But I'm not expecting anything different.
Post by palinka » 2024-04-06 20:08
Whoops - had a stupid issue with my script. 35 links were listed: 32 in SURBL, 3 in Spamhaus DBL.
5 expanded shortlinks had redirects in the URL that were listed in SURBL (none in Spamhaus DBL).
Post by palinka » 2024-04-07 09:11
I ran it again also inspecting the shortlink domain. Now there are 3 items being inspected: the domain of the shortlink, the domain of the expanded shortlink and the domain of redirects found in expanded shortlinks.
34 shortlink domain hits on SURBL (all for clck.ru)
0 shortlink domain hits on Spamhaus DBL
56 expanded shortlink domain hits on SURBL (some overlap with the shorlink domains - most of the clck.ru shortlinks expanded to clck.ru long links)
3 expanded shortlink domain hits on Spamhaus DBL
5 expanded shortlink redirect domain hits on SURBL
0 expanded shortlink redirect domain hits on Spamhaus DBL
That's 98 hits out of 5300 messages.
I'm not sure why there's a big jump from yesterday. Maybe SURBL added some domains overnight.
I also noticed something strange. Some bitly shortlinks were "long", like this:
https://bitly.ws/xxxxx#cl/4910_md/2001/3662/436/31/1268829
- I don't know what that's all about. I tried goolaging it but since goolag is broken now thanks to DIE and TDS, nothing relevant came up.
But anyway, this looks like a worthwhile endeavor, so I think I'll continue building it for eventhandlers.vbs.
Post by palinka » 2024-04-07 09:33
Improved redirect capture regex added 3 more SURBL hits.
https://regex101.com/r/dF4olP/2
/(?:\bhttps?:\/\/.+\?.+=https?(:\/\/|\%3A\%2F\%2F))([a-zA-Z0-9-.]+)(?:(\/|\%2F)[^\s\"]+\b)?/gm
Post by palinka » 2024-04-07 19:08
Working test script to evaluate all URL domains, shortlink domains, expanded shortlink domains and redirects within expanded shortlink domains. Includes recursive shortlink URL expansion function that stops when the final redirect is found.
WARNING - 2 links below are actual spam. They could be malicious. Use caution.
Option Explicit
	Dim f, s, oFSO
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	Dim strLookup
	Dim strLookup
	Request.Send
Function GetToRootURL(URL)
	Dim Link, Match, Matches, LinkDomain
	Link = ExpandURL(URL)
	WScript.Echo "URL: " & URL
	WScript.Echo "Link: " & Link
	If Link = URL Then
		GetToRootURL = URL
		Set Matches = oLookup("(?:https?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+)?", Link, False)
				LinkDomain = Match.SubMatches.Item(0)
		If Lookup(ShortLinkProviderRegEx, LinkDomain) Then
			GetToRootURL = GetToRootURL(Link)
			GetToRootURL = Link
Dim ShortURL, LongURL, Domain, URL, URLsFound, SLMatch, SLMatches, UMatch, UMatches, MessageBody, URLFinderRegEx, ExtractDomainFromURLRegEx, RedirectURLFinderRegEx, MsgURL, MsgURLDomain
URLFinderRegEx = "(\b((https?(:\/\/|%3A%2F%2F))((([a-zA-Z0-9-]+)\.)+[a-zA-Z0-9-]+)(:\d+)?((?:\/[\+~%\/\.\w\-_]*)?\??(?:[\-\+=&;%@\.\w_]*)#?(?:[\.\!\/\\\w]*))?)\b)"
ExtractDomainFromURLRegEx = "(?:https?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+)?"
RedirectURLFinderRegEx = "(?:\bhttps?:\/\/.+\?.+=https?(:\/\/|\%3A\%2F\%2F))([a-zA-Z0-9-.]+)(?:(\/|\%2F)[^\s\""]+\b)?"
				"Here's a bony fide short link https://t.co/Ej4jsWGIuY right in the middle of the message." & _
				"Here's another: https://clck.ru/39CGSZ - by the way these are real spam - exercise caution!!" & _
REM - Find URLs in message body
Set URLsFound = oLookup(URLFinderRegEx, MessageBody, True)
WScript.Echo URLsFound.Count & " URL matches found in message body"
If URLsFound.Count > 0 Then
	For Each URL in URLsFound
		MsgURL = URL.SubMatches.Item(0)
		WScript.Echo " "
		WScript.Echo "URL found in message body: " & MsgURL
		REM - If URLS found then get domain from each URL
		Set UMatches = oLookup(ExtractDomainFromURLRegEx, MsgURL, False)
				MsgURLDomain = UMatch.SubMatches.Item(0)
		REM - Might as well test it as long as we're here
		If IsInSurbl(MsgURLDomain) Then WScript.Echo MsgURLDomain & " LISTED IN SURBL!!!" Else WScript.Echo "not listed in SURBL"
		If IsInSpamHausDBL(MsgURLDomain) Then WScript.Echo MsgURLDomain & " LISTED IN SPAMHAUS DBL!!!" Else WScript.Echo "not listed in Spamhaus DBL"
		REM - Test URL domain against shortlink provider list
		If Lookup(ShortLinkProviderRegEx, MsgURLDomain) Then
			WScript.Echo "Shortlink found in message body: " & MsgURL
			REM - If URL is a shortlink then expand it
			LongURL = GetToRootURL(MsgURL)
			REM - Get domain from expanded shortlink and test it against SURBL and Spamhaus DBL
			Set SLMatches = oLookup(ExtractDomainFromURLRegEx, LongURL, False)
					REM -
					REM -
					REM -
					REM -
			REM - Now lets look for redirects in the expanded shortlink and test them as well
			Set SLMatches = oLookup(RedirectURLFinderRegEx, LongURL, False)
				WScript.Echo "Redirect found in expanded URL"
					Domain = SLMatch.SubMatches.Item(1)
					REM -
					REM -
					REM -
					REM -
Post by palinka » 2024-04-15 17:31
Here's eventhandlers.vbs script for this. I've been running it a few days. No errors. Found a few shortlinks but so far no hits on SURBL or Spamhaus DBL.
Use the powershell script above to create "short_link_provider_regex.vbs".
Option Explicit
	Dim f, s, oFSO
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	Dim strLookup
	Dim strLookup
	Dim Request : Set Request = CreateObject("MSXML2.ServerXMLHTTP.6.0")
	Request.Send
	If Err.Number <> 0 Then
		EventLog.Write("--------------------------------")
		EventLog.Write("Error       : ExpandURL Function could not expand shortlink")
		EventLog.Write("Domain      : " & ShortURL)
		ExpandURL = ShortURL
	On Error GoTo 0
	If Link = URL Then
		GetToRootURL = URL
			GetToRootURL = Link
	Dim strMsgSLBody, LongURL, Domain, URL, URLsFound, Match, Matches, UMatch, UMatches, RedirectMatch, RedirectMatches, URLFinderRegEx, ExtractDomainFromURLRegEx, RedirectURLFinderRegEx, MsgURL, MsgURLDomain
	REM - Convert message body to text string
	If oMessage.HTMLBody = Empty Then
		strMsgSLBody = oMessage.Body
		strMsgSLBody = oMessage.HTMLBody
	REM - Test Expanded Shortlinks
	Set URLsFound = oLookup(URLFinderRegEx, strMsgSLBody, True)
				EventLog.Write("SURBL hit on message URL: " & MsgURLDomain)
				' Do Stuff
				EventLog.Write("Spamhaus DBL hit on message URL: " & MsgURLDomain)
				' Do Stuff
			REM - And look for redirects and test them as well
			Set RedirectMatches = oLookup(RedirectURLFinderRegEx, LongURL, False)
			If RedirectMatches.Count > 0 Then
				For Each RedirectMatch In RedirectMatches
					Domain = RedirectMatch.SubMatches.Item(1)
						EventLog.Write("SURBL hit on URL redirect: " & Domain)
						' Do Stuff
						EventLog.Write("Spamhaus DBL hit on URL redirect: " & Domain)
						' Do Stuff
				EventLog.Write("Shortlink Found: " & MsgURL & " ---> " & LongURL)
				Set Matches = oLookup(ExtractDomainFromURLRegEx, LongURL, False)
							EventLog.Write("SURBL hit on expanded shortlink: " & Domain)
							' Do Stuff
							EventLog.Write("Spamhaus DBL hit on expanded shortlink: " & Domain)
							' Do Stuff
				REM - Look for redirects in the expanded shortlink and test them as well
				Set Matches = oLookup(RedirectURLFinderRegEx, LongURL, False)
						Domain = Match.SubMatches.Item(1)
							EventLog.Write("SURBL hit on expanded shortlink redirect: " & Domain)
							' Do Stuff
							EventLog.Write("Spamhaus DBL hit on expanded shortlink redirect: " & Domain)
							' Do Stuff
Post by palinka » 2024-05-06 12:54
I got my first bona fide hit - a SURBL hit on an expanded shortlink url.
Spamassassin (bayes) already scored it high enough to hit the delete threshold since I've received plenty of these messages ("ukraine girls/dating") before. I guess SURBL just added the expanded URL.
Still evaluating if this is useful or not. It seems as though SURBL and especially very conservative Spamhaus are very late in updating their records. I'm sure they're avoiding false positives, but still, bayes does a better/faster job of picking these messages out.
Post by palinka » 2024-05-17 18:41
Based on something RvdH mentioned in another thread about SURBL, I decided to make the list of URLs unique so they don't get tested twice. Also, If there's a hit, it will exit without further testing since one hit is enough. There's no need to test every single URL if one already tripped SURBL.
Also, using the array greatly shortens the code. There are 3 new functions to help with that.
The code searches the message body for URLs. If found it will do the following:
1) add the FQDN to the domain array
2) check if the FQDN is a shortlink domain, expand it, then extract the FQDN and add it to the domain array
3) check if the URL contains a redirect and if it does, it will extract the redirect URL FQDN and add it to the domain array
4) check if the FQDN is a shortlink domain, expand it, look for redirects in the expanded URL and if found, extracts the redirect URL FQDN and adds it to the domain array
If any of those items already exist in the array, it will be ignored so that the array contains unique FQDNs only.
Then it takes that array of FQDNs and tests them against SURBL.org and Spamhaus DBL. If there's a hit on either one, you handle the message however you want, then it will exit the for each loop. I use Soren's blacklist function and report the IP address to AbuseIPDB.
Option Explicit
	Dim f, s, oFSO
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function IsInSURBL(Domain)
	Dim objShell : Set objShell = CreateObject("Wscript.Shell")
	Dim objExec : Set objExec = objShell.Exec("Powershell -Command (Resolve-DnsName -Name " & Domain & ".multi.surbl.org -DnsOnly -NoHostsFile).IPAddress")
	IsInSURBL = Lookup("(127\.0\.0\.[0-9]+)", objExec.StdOut.ReadAll)
Function IsInSpamhausDBL(Domain)
	Dim objExec : Set objExec = objShell.Exec("Powershell -Command (Resolve-DnsName -Name " & Domain & "." & SpamhausDQSKey & ".dbl.dq.spamhaus.net -DnsOnly -NoHostsFile).IPAddress")
	IsInSpamhausDBL = Lookup("(127\.0\.1\.[2456])", objExec.StdOut.ReadAll)
	Request.Send
	On Error GoTo 0
	If Link = URL Then
		GetToRootURL = URL
			GetToRootURL = Link
Function GetFQDN(URL)
	Dim Match, Matches
	Set Matches = oLookup("(?:https?:\/\/)([a-zA-Z0-9-.]+)(?:\/[^\s]+)?", URL, False)
			GetFQDN = Match.SubMatches.Item(0)
Function GetURLRedirectDomain(URL)
	Dim Match, Matches
	Set Matches = oLookup("(?:\bhttps?:\/\/.+\?.+=https?(:\/\/|\%3A\%2F\%2F))([a-zA-Z0-9-.]+)(?:(\/|\%2F)[^\s\""]+\b)?", URL, False)
			GetURLRedirectDomain = Match.SubMatches.Item(1)
Function IsInArray(Arr(), Item) : IsInArray = False
	Dim A
	For Each A In Arr
		If A = Item Then
			IsInArray = True
			Exit Function
	Dim MessageBody, URL, URLsFound, Match, Matches, URLFinderRegEx, MsgURL, MsgURLDomain, ExpandedShortLinkDomain, MsgURLRedirectDomain, ExpandedShortlinkRedirectDomain, FQDNArr(), FQDN, DomainIterator, strMsgBody
	REM - Test URLs, Expanded Shortlinks and Redirects against SURBL
		MessageBody = oMessage.Body
		MessageBody = oMessage.HTMLBody
	DomainIterator = 0
			MsgURLDomain = GetFQDN(MsgURL)
			ExpandedShortLinkDomain = GetFQDN(GetToRootURL(MsgURL))
			MsgURLRedirectDomain = GetURLRedirectDomain(MsgURL)
			ExpandedShortlinkRedirectDomain = GetURLRedirectDomain(GetToRootURL(MsgURL))
			REM - Add URL FQDN's uniquely to array
			If MsgURLDomain <> "" Then
				If IsInArray(FQDNArr, MsgURLDomain) = False Then
					REDIM PRESERVE FQDNArr(DomainIterator)
					FQDNArr(DomainIterator) = MsgURLDomain
					DomainIterator = DomainIterator + 1
			If ExpandedShortLinkDomain <> "" Then
				If IsInArray(FQDNArr, ExpandedShortLinkDomain) = False Then
					FQDNArr(DomainIterator) = ExpandedShortLinkDomain
			If MsgURLRedirectDomain <> "" Then
				If IsInArray(FQDNArr, MsgURLRedirectDomain) = False Then
					FQDNArr(DomainIterator) = MsgURLRedirectDomain
			If ExpandedShortlinkRedirectDomain <> "" Then
				If IsInArray(FQDNArr, ExpandedShortlinkRedirectDomain) = False Then
					FQDNArr(DomainIterator) = ExpandedShortlinkRedirectDomain
		REM - Test Unique FQDN array against SURBL and Spamhaus DBL
		For Each FQDN In FQDNArr
			If IsInSurbl(FQDN) Then
				EventLog.Write("SURBL hit on message URL: " & FQDN)
				' Do stuff
				Exit For
			If IsInSpamHausDBL(FQDN) Then
				EventLog.Write("Spamhaus DBL hit on message URL: " & FQDN)
				' Do stuff
				Exit For
Post by palinka » 2024-05-19 10:13
I was getting errors on some messages due to the URLs being URLEncoded. So I made a URLDecode function.
Function URLDecode(URL)
	Dim objExec : Set objExec = objShell.Exec("Powershell -Command [uri]::UnescapeDataString(" & Chr(39) & URL & Chr(39) & ")")
	URLDecode = Trim(Replace(objExec.StdOut.ReadAll, vbCrLf, ""))
	REM - Find Unique URLs in message body
	DomainIterator = 0
			MsgURLDomain = GetFQDN(URLDecode(MsgURL))
			ExpandedShortLinkDomain = GetFQDN(GetToRootURL(URLDecode(MsgURL)))
			MsgURLRedirectDomain = GetURLRedirectDomain(URLDecode(MsgURL))
			ExpandedShortlinkRedirectDomain = GetURLRedirectDomain(GetToRootURL(URLDecode(MsgURL)))
But wow... this takes a long time because every URL gets passed through the shortlink expander twice (2nd one to look for redirects - that will be fixed). Do not use this script on a busy server.
Post by palinka » 2024-05-20 07:55
Only bona fide shortlinks should be expanded. This greatly cuts the processing time.
Option Explicit
	Dim f, s, oFSO
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function URLEncode(URL)
	Dim objExec : Set objExec = objShell.Exec("Powershell -Command [uri]::EscapeDataString(" & Chr(39) & URL & Chr(39) & ")")
	URLEncode = Trim(Replace(objExec.StdOut.ReadAll, vbCrLf, ""))
Function ExpandURL(URL)
	Request.Open "HEAD", URL, False
	Request.Send
		EventLog.Write ( "--------------------------------" )
		EventLog.Write ( "Error       : ExpandURL Function could not expand URL" )
		EventLog.Write ( "URL         : " & URL )
		EventLog.Write ( "Description : " & Err.Description  )
		ExpandURL = URL
	If Link = URL Then
		GetToRootURL = URL
			GetToRootURL = Link
	Dim Match, Matches
Function IsShortlink(FQDN) : IsShortlink = False
	If Lookup(ShortLinkProviderRegEx, FQDN) Then IsShortlink = True
	Dim Match, Matches
	Dim A
	For Each A In Arr
		If A = Item Then
			IsInArray = True
			Exit Function
	Dim MessageBody, URL, URLsFound, Match, Matches, URLFinderRegEx, ExtractDomainFromURLRegEx, RedirectURLFinderRegEx, MsgURL, MsgURLDomain, ExpandedShortLink, ExpandedShortLinkDomain, MsgURLRedirectDomain, ExpandedShortlinkRedirectDomain, FQDNArr(), FQDN, DomainIterator
	DomainIterator = 0
			If IsShortlink(MsgURLDomain) Then
				ExpandedShortLink = GetToRootURL(URLDecode(MsgURL))
				ExpandedShortLinkDomain = GetFQDN(ExpandedShortLink)
				ExpandedShortlinkRedirectDomain = GetURLRedirectDomain(ExpandedShortLink)
		REM - Test Unique FQDN against SURBL and Spamhaus DBL
				' Do Stuff
				Exit For
				' Do Stuff
				Exit For
Post by palinka » 2024-06-06 07:53
I noticed that my URL regex missed a quoted printable URL. Specifically:
https://e=2Enewyorktimes=2Ecom/pub...
So I found a quoted printable decode function for vbs here: ' https://www.motobit.com/tips/detpg_quot ... le-decode/
Here's the function without the notes (just to save space):
' https://www.motobit.com/tips/detpg_quoted-printable-decode/
Function QuotedPrintableDecode(SourceData, CharSet)
	Dim Message: Set Message = CreateObject("CDO.Message")
	Message.BodyPart.ContentTransferEncoding = "quoted-printable"
	Dim Stream 'As ADODB.Stream
	Set Stream = Message.BodyPart.GetEncodedContentStream
	If VarType(SourceData) = vbString Then
		Stream.charset = "windows-1250"
		Stream.WriteText SourceData
		Stream.Type = 1
		Stream.Write SourceData
	Stream.Flush
	Set Stream = Message.BodyPart.GetDecodedContentStream
	Stream.CharSet = CharSet
	QuotedPrintableDecode = Stream.ReadText
And here is where you run the function - before attempting to search for URLs:
		MessageBody = QuotedPrintableDecode(oMessage.Body, "UTF-8")
		MessageBody = QuotedPrintableDecode(oMessage.HTMLBody, "UTF-8")
Post by palinka » 2024-06-06 09:32
oof... not enough coffee this morning. This function ^^ is not needed.
But pretty cool function. I'll probably find a use for it somewhere else.
