SecurityRange properties
nis
Post by nis » 2011-03-26 15:49
I dont see expiration and expiration date within properties list in the documentation
also, when I created a new range via vbscript, when I use the hmailserver interface, I cannot "edit" it when I clic on it. but I can delete it
here is a part of the code
dim SecurityRges
dim SecurityRge
dim obApp
Call obApp.Authenticate("Administrator", "password")
set SecurityRges = obApp.settings.SecurityRanges
set SecurityRge = SecurityRges.add
SecurityRge.AllowIMAPConnections = false
SecurityRge.AllowPOP3Connections = false
SecurityRge.AllowSMTPConnections = false
SecurityRge.AllowDeliveryFromLocalToLocal = false
SecurityRge.AllowDeliveryFromLocalToRemote = false
SecurityRge.AllowDeliveryFromRemoteToLocal = false
SecurityRge.AllowDeliveryFromRemoteToRemote = false
SecurityRge.EnableSpamProtection = false
SecurityRge.LowerIP = SendfromIP
SecurityRge.UpperIP = SendfromIP
SecurityRge.name = "blacklist IP :" & SendfromIP
SecurityRge.priority = 10
SecurityRge.save
many thanks
philg
Re: SecurityRange properties
Post by philg » 2012-12-30 19:38
Did you ever figure out if you can set the expiry through the COM API/Scripting?
I'm looking at adding something similar to one of my scripts.
Thanks,
Phil
Post by mattg » 2012-12-31 02:30
I think...
SecurityRange.Expires (Boolean) where True = expiry enabled
SecurityRange.ExpiresTime (date & Time) = Daye and time of expiry.
( I got this from the PHPWebAdmin.php)
philg
Post by philg » 2012-12-31 02:32
Thanks Matt,
Yes, you are right.... I figured it out looking at the COM interface with OLEView.
I got it working nicely :)
Phil
FixItDik
Post by FixItDik » 2020-09-25 12:06
I know this was a long time ago but I found it useful but also had the secondary issue that the original post mentioned: rules I create in my script could not be edited when clicked on in the admin interface.
The solution was very simple: close the admin tool down and open it again (you probably leave it open all the time like I do).
Basically it is a minor bug (or two) in the admin tool code that any rule created by scripts whilst it is running will appear in the list box (but not in the "tree" list in the navigation on the left) and can be clicked on but can only be deleted, not even viewed let alone edited.
It's not a bigee but thought someone might hit the same problem if they are looking at this post.
Post by SorenR » 2020-09-25 15:22
FixItDik wrote:
2020-09-25 12:06
Did you try hitting F5 on your keyboard?
Post by mattg » 2020-09-27 02:41
I just change 'branches' in the tree in the left pane, then change back
