Looking for same version Clamwin and Clamav
kiekar
Post by kiekar » 2016-10-28 01:29
I'm following a tutorial viewtopic.php?f=21&t=26829 to start using ClamAV and Clamwin. Where can I find a matching version of ClamAV and Clamwin?.
How does one upgrade clamav where clamd version .97.1 is running currently on my server as a service. Do I need to uninstall the old version or can I override the files in the folder.
Your help would be much appreciated.
Regards,
Karl
agatha
Re: Looking for same version Clamwin and Clamav
Post by agatha » 2016-10-28 08:50
In my opinion you should only use clamav running as a service. That is the fastest way to scan your mails. And take a look at the signatures from sanesecurity.
To update clamav stop the service, override the files and start the service again. That should work in most cases. If it does not, remove and reinstall the service.
Post by jimimaseye » 2016-10-28 10:53
kiekar wrote:Hello,
Regards,
Karl
Clamwin at clamwin.com is 0.99.1.
The matching clamd 0.99.1 is here: viewtopic.php?f=7&t=29830&p=186601&hilit=clamd#p186601. (You now have everything to do the install as per the original thread instructions.) I recommend you uninstall everything you currently have first before commencing with this installation tutorial (and dont forget to use Sanesecurity definitions to make it worth while).
Post by jimimaseye » 2016-10-28 10:57
agatha wrote:In my opinion you should only use clamav running as a service. That is the fastest way to scan your mails. And take a look at the signatures from sanesecurity.
He is using it as a service. My installation tutorial does use it (and sane defs) as a service with the added benefit of the clamwin interface.
kiekar
Post by kiekar » 2016-10-30 02:31
Thank you for your link to the Clamd .99.1. I got everything running per tutorial except for sanesecurity definitions. Maybe I missed something in the tutorial but where do I get the sanesecurity definitions.
Thanks,
Post by mattg » 2016-10-30 02:45
kiekar
Post by kiekar » 2016-10-30 15:45
I appreciate the help but sorry for my ignorance. Per jimimaseye statement
and the links provided by mattg, I still don't know where or how to use sanesecurity definitions after following the tutorial. Is there a tutorial on how to use the definitions? Is this a third party addon to work along side clamwin and clamav? seems from what I read it works great but I don't see where it explains how to implement it.
Post by mattg » 2016-10-30 15:59
Try this one from the sane security site >> http://sanesecurity.com/usage/windows-scripts/
kiekar
Post by kiekar » 2016-10-31 22:47
Finally installed sanesecurity from
using the readme.txt instructions for ClamAV/ClamWin configuration. I also added a task to update every hour using the supplied sigupdate.bat file.
Unfortunately I received two emails with an attached zip file containing a Trojan which was found by my PC antivirus software. looking at the hmailserver log file it showed that it scanned the email but passed it through.
I'm just wondering if the sanesecurity definitions are not working due to the way I configured it. Any help would be great
Post by jimimaseye » 2016-10-31 22:55
kiekar wrote: I'm just wondering if the sanesecurity definitions are not working due to the way I configured it. Any help would be great
Probably. (I'm confident in sane but I am not currently in a position to help in detail due to moving house).
