I use it for my LogWriter so I can crossmatch with the normal logging.
Example...
This custom log track the logic of the EventHandler script in my server. 465/25 is SMTP port, DISCONNECT will force terminate TCPIP connection not returning a SMTP status code, IDS = Intrution Detection System, "IDS BAN" is handled by an external script running every 60 seconds. The sequence "IDS Add" followed by "IDS Delete" describe receipt of valid email.
ThreadID is the left most column.
1844 "2019-04-10 03:02:31.625" "*************** 103.116.12.239 465"
1844 "2019-04-10 03:02:31.781" "IDS Add 103.116.12.239"
1844 "2019-04-10 03:02:31.842" "SnowShoe 103.116.12.239"
1844 "2019-04-10 03:02:32.170" "DISCONNECT 103.116.12.239"
3260 "2019-04-10 03:02:32.249" "*************** 103.116.12.239 25"
3260 "2019-04-10 03:02:32.249" "IDS Add 103.116.12.239"
3260 "2019-04-10 03:02:32.249" "SnowShoe 103.116.12.239"
1844 "2019-04-10 03:02:32.578" "*************** 103.116.12.239 465"
1844 "2019-04-10 03:02:32.592" "IDS Add 103.116.12.239"
1844 "2019-04-10 03:02:32.592" "SnowShoe 103.116.12.239"
3260 "2019-04-10 03:02:33.203" "DISCONNECT 103.116.12.239"
3260 "2019-04-10 03:02:33.281" "*************** 103.116.12.239 25"
3260 "2019-04-10 03:02:33.281" "IDS Add 103.116.12.239"
3260 "2019-04-10 03:02:33.281" "SnowShoe 103.116.12.239"
1844 "2019-04-10 03:02:34.203" "DISCONNECT 103.116.12.239"
3260 "2019-04-10 03:02:34.203" "DISCONNECT 103.116.12.239"
1844 "2019-04-10 03:02:48.967" "*************** 103.116.12.239 465"
1844 "2019-04-10 03:02:48.983" "IDS Add 103.116.12.239"
1844 "2019-04-10 03:02:48.983" "SnowShoe 103.116.12.239"
1844 "2019-04-10 03:02:49.202" "DISCONNECT 103.116.12.239"
1844 "2019-04-10 03:02:49.545" "*************** 103.116.12.239 465"
1844 "2019-04-10 03:02:49.545" "IDS Add 103.116.12.239"
1844 "2019-04-10 03:02:49.545" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:50.092" "*************** 103.116.12.239 465"
2572 "2019-04-10 03:02:50.108" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:50.108" "SnowShoe 103.116.12.239"
3260 "2019-04-10 03:02:50.655" "*************** 103.116.12.239 465"
3260 "2019-04-10 03:02:50.655" "IDS Add 103.116.12.239"
3260 "2019-04-10 03:02:50.670" "SnowShoe 103.116.12.239"
3260 "2019-04-10 03:02:51.185" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:51.185" "DISCONNECT 103.116.12.239"
3260 "2019-04-10 03:02:51.217" "*************** 103.116.12.239 25"
3260 "2019-04-10 03:02:51.217" "IDS Add 103.116.12.239"
3260 "2019-04-10 03:02:51.233" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:51.763" "*************** 103.116.12.239 25"
2572 "2019-04-10 03:02:51.763" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:51.763" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:52.170" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:52.310" "*************** 103.116.12.239 25"
2572 "2019-04-10 03:02:52.310" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:52.327" "SnowShoe 103.116.12.239"
1176 "2019-04-10 03:02:52.874" "*************** 103.116.12.239 25"
1176 "2019-04-10 03:02:52.874" "IDS Add 103.116.12.239"
1176 "2019-04-10 03:02:52.874" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:53.185" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:53.405" "*************** 103.116.12.239 25"
2572 "2019-04-10 03:02:53.405" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:53.405" "SnowShoe 103.116.12.239"
3064 "2019-04-10 03:02:53.920" "*************** 103.116.12.239 25"
3064 "2019-04-10 03:02:53.920" "IDS Add 103.116.12.239"
3064 "2019-04-10 03:02:53.935" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:54.138" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:54.499" "*************** 103.116.12.239 25"
2572 "2019-04-10 03:02:54.499" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:54.499" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:55.108" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:55.124" "*************** 103.116.12.239 25"
2572 "2019-04-10 03:02:55.124" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:55.124" "SnowShoe 103.116.12.239"
3064 "2019-04-10 03:02:56.155" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:56.155" "DISCONNECT 103.116.12.239"
3064 "2019-04-10 03:02:56.169" "*************** 103.116.12.239 465"
3064 "2019-04-10 03:02:56.169" "IDS Add 103.116.12.239"
3064 "2019-04-10 03:02:56.169" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:56.716" "*************** 103.116.12.239 465"
2572 "2019-04-10 03:02:56.716" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:56.733" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:57.138" "DISCONNECT 103.116.12.239"
1176 "2019-04-10 03:02:57.185" "DISCONNECT 103.116.12.239"
3064 "2019-04-10 03:02:57.202" "DISCONNECT 103.116.12.239"
2572 "2019-04-10 03:02:57.280" "*************** 103.116.12.239 465"
2572 "2019-04-10 03:02:57.280" "IDS Add 103.116.12.239"
2572 "2019-04-10 03:02:57.280" "SnowShoe 103.116.12.239"
2572 "2019-04-10 03:02:58.202" "DISCONNECT 103.116.12.239"
3260 "2019-04-10 03:02:58.202" "DISCONNECT 103.116.12.239"
1844 "2019-04-10 03:02:59.123" "DISCONNECT 103.116.12.239"
2560 "2019-04-10 03:03:00.310" "IDS BAN 103.116.12.239"
2572 "2019-04-10 03:05:44.539" "*************** 204.232.178.184 25 web1.valentus.com"
2572 "2019-04-10 03:05:44.539" "IDS Add 204.232.178.184"
200 "2019-04-10 03:06:49.693" "IDS Delete 204.232.178.184"
I decided to log the events where script is waiting for locked file to clear lock (If (i > 0) Or (Err.Num... etc.).
On Error Resume Next
For i = 0 To 30
Err.Clear
Set OpenFile = .OpenTextFile(strPath, Append, True, Unicode)
If (i > 0) Or (Err.Number <> 0) Then EventLog.Write( "Function OpenFile, i: " & i & ", Err.Number: " & Err.Number )
If (Not Err.Number = 70) Then Exit For
Wait(1)
1844 "2019-04-10 03:02:33.203" "Function OpenFile, i: 0, Err.Number: 70"
1844 "2019-04-10 03:02:34.203" "Function OpenFile, i: 1, Err.Number: 0"
1844 "2019-04-10 03:02:51.186" "Function OpenFile, i: 0, Err.Number: 70"
3260 "2019-04-10 03:02:52.171" "Function OpenFile, i: 0, Err.Number: 70"
1176 "2019-04-10 03:02:53.186" "Function OpenFile, i: 0, Err.Number: 70"
3064 "2019-04-10 03:02:54.139" "Function OpenFile, i: 0, Err.Number: 70"
1176 "2019-04-10 03:02:56.155" "Function OpenFile, i: 1, Err.Number: 70"
3064 "2019-04-10 03:02:56.155" "Function OpenFile, i: 1, Err.Number: 0"
3260 "2019-04-10 03:02:56.155" "Function OpenFile, i: 1, Err.Number: 70"
1844 "2019-04-10 03:02:56.155" "Function OpenFile, i: 1, Err.Number: 70"
1844 "2019-04-10 03:02:57.186" "Function OpenFile, i: 2, Err.Number: 70"
1176 "2019-04-10 03:02:57.186" "Function OpenFile, i: 2, Err.Number: 0"
3260 "2019-04-10 03:02:57.186" "Function OpenFile, i: 2, Err.Number: 70"
3260 "2019-04-10 03:02:58.202" "Function OpenFile, i: 3, Err.Number: 0"
1844 "2019-04-10 03:02:58.202" "Function OpenFile, i: 3, Err.Number: 70"
1844 "2019-04-10 03:02:59.123" "Function OpenFile, i: 4, Err.Number: 0"
It also allows us to match the lines from the custom log and the EventLog by ThreadID and timestamp.
"SMTPD" 2572 491 "2019-04-10 03:06:04.117" "204.232.178.184" "SENT: 220 mx.acme.inc ESMTP"
"SMTPD" 2572 491 "2019-04-10 03:06:04.445" "204.232.178.184" "RECEIVED: EHLO web1.valentus.com"
"SMTPD" 2572 491 "2019-04-10 03:06:24.100" "204.232.178.184" "SENT: 250-mx.acme.inc[nl]250 SIZE"
"SMTPD" 2572 491 "2019-04-10 03:06:24.225" "204.232.178.184" "RECEIVED: MAIL FROM:<support@valentus.com>"
"SMTPD" 2572 491 "2019-04-10 03:06:24.225" "204.232.178.184" "SENT: 250 OK"
"SMTPD" 2572 491 "2019-04-10 03:06:24.335" "204.232.178.184" "RECEIVED: RCPT TO:<road.runner@acme.inc>"
"SMTPD" 2572 0 "2019-04-10 03:06:24.397" "TCP" "DNS lookup: 184.178.232.204.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"SMTPD" 2572 0 "2019-04-10 03:06:24.757" "TCP" "DNS lookup: 184.178.232.204.b.barracudacentral.org, 0 addresses found: (none), Match: False"
"SMTPD" 2572 0 "2019-04-10 03:06:24.913" "TCP" "DNS lookup: 184.178.232.204.bl.spamcop.net, 0 addresses found: (none), Match: False"
"SMTPD" 2572 491 "2019-04-10 03:06:24.913" "204.232.178.184" "SENT: 250 OK"
"SMTPD" 2572 491 "2019-04-10 03:06:25.022" "204.232.178.184" "RECEIVED: DATA"
"SMTPD" 2572 491 "2019-04-10 03:06:45.162" "204.232.178.184" "SENT: 354 OK, send."
"SMTPD" 200 491 "2019-04-10 03:06:49.756" "204.232.178.184" "SENT: 250 Queued (4.515 seconds)"
"SMTPD" 1176 491 "2019-04-10 03:06:49.881" "204.232.178.184" "RECEIVED: QUIT"
"SMTPD" 1176 491 "2019-04-10 03:06:49.881" "204.232.178.184" "SENT: 221 goodbye"
Modification to hMailServer 5.4.2-B1964:
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.cpp hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.cpp
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.cpp 2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.cpp 2019-03-04 14:45:12.484375000 +0100
@@ -125,4 +125,20 @@
+STDMETHODIMP
+InterfaceStatus::get_ThreadID(long *pVal)
+ try
+ if (!m_pStatus)
+ return GetAccessDenied();
+ *pVal = m_pStatus->GetThreadID();
+ return S_OK;
+ catch (...)
+ return COMError::GenerateGenericMessage();
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.h hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.h
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.h 2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.h 2019-03-04 14:45:12.375000000 +0100
@@ -51,6 +51,7 @@
STDMETHOD(get_RemovedViruses)(/*[out, retval]*/ long *pVal);
STDMETHOD(get_RemovedSpamMessages)(/*[out, retval]*/ long *pVal);
STDMETHOD(get_SessionCount)(eSessionType iType, long *pVal);
+ STDMETHOD(get_ThreadID)(/*[out, retval]*/ long *pVal);
private:
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.cpp hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.cpp
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.cpp 2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.cpp 2019-03-04 14:45:12.625000000 +0100
@@ -158,4 +158,11 @@
return SessionManager::Instance()->GetNumberOfConnections((SessionType) iSessionType);
+ int
+ ServerStatus::GetThreadID() const
+ DWORD dwThreadID = GetCurrentThreadId();
+ return dwThreadID;
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.h hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.h
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.h 2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.h 2019-03-04 14:45:12.562500000 +0100
@@ -36,6 +36,8 @@
int GetNumberOfSessions(int iSessionType);
+ int GetThreadID() const;
private:
int m_iProcessedMessages;
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/hMailServer/hMailServer.idl hmailserver-5.4.2/hmailserver/source/Server/hMailServer/hMailServer.idl
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/hMailServer/hMailServer.idl 2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/hMailServer/hMailServer.idl 2019-03-04 14:45:12.250000000 +0100
@@ -497,6 +497,7 @@
[propget, id(4), helpstring("Gets the number of removed virues")] HRESULT RemovedViruses([out, retval] long *pVal);
[propget, id(5), helpstring("Gets the number of detected spam messages")] HRESULT RemovedSpamMessages([out, retval] long *pVal);
[propget, id(6), helpstring("Gets the current number of sessions")] HRESULT SessionCount([in] eSessionType iType, [out, retval] long *pVal);
+ [propget, id(7), helpstring("Gets the current thread number")] HRESULT ThreadID([out, retval] long *pVal);
