Is it possible to call like Rest API from axios or fetch on COM API ?
Prashanthady
Post by Prashanthady » 2020-06-04 11:52
Hello ,
Can you please clarify will it possible to call hmailserver linke rest api for creating domain and email address using axios or fetch ?
COM API will it be helpful for the above problem ?
Thanks in advance for your reply.
Re: Is it possible to call like Rest API from axios or fetch on COM API ?
Post by palinka » 2020-06-04 12:08
Hmailserver doesn't have built in rest api. You would have to build your own. But yes, it's possible php -> COM.
Prashanthady
Post by Prashanthady » 2020-06-04 12:21
You mean for PHP application we can able to call COM API. Is it correct ? Does hmailserver will provide an endpoint for accessing from php application ?
Did we have any blog and support document on how to establish the connection it will me helpful for me to integration.
Thanks for your help.
Post by mattg » 2020-06-04 12:47
The PHPWebAdmin that is installed with hMailserver is a working example
https://www.hmailserver.com/documentati ... hpwebadmin
