Need Script : Enable Auto Reply on specific mailbox on weekend
PMAMCorp
Post by PMAMCorp » 2021-05-17 08:10
Can someone please help on the script that will enable Auto Reply (Out of office) on specific mailbox over the weekend & will turn off automatically on Monday 6 AM ?
Regards
Kedar Khanderkar
Re: Need Script : Enable Auto Reply on specific mailbox on weekend
Post by jimimaseye » 2021-05-17 08:42
viewtopic.php?f=20&t=28942
PMAMCorp
Post by PMAMCorp » 2021-05-20 10:05
We tried the above scripted but still it not working, can you suggest is there any wrong in scripts i did any thing wrong. let me know if you need more info.
Regards
PMAM
Documents.zip
(6 KiB) Downloaded 33 times
PMAMCorp
Post by PMAMCorp » 2021-05-25 13:38
Hello Support,
We are getting syntax error when we place the OutofOffice script below sub OnAcceptMessage(oClient, oMessage). Please refer to attached screenshot.
Awaiting for your response.
Regards
Akshay Purabia
gotspatel
Post by gotspatel » 2021-05-25 14:07
PMAMCorp wrote:
2021-05-25 13:38
Hello Support,
Regards
Akshay Purabia
Check that "Sub" is there in your code, it is not visible in image and also the line numbers
EDIT
You have not used the code properly. Check the complete code again.
	Sub OutOfOffice(oMessage,oClient)
   Dim HMPassword, IncludeSubject, SubjSuffix, TriggerSubject, TempTxt
   HMPassword = "test#123"		<-------- You need to change to your hmail password
   TriggerSubject = "set vacation"
   IncludeSubject = "YES"       ' Change to "YES" to append original subject text to reply subject
Post by jimimaseye » 2021-05-25 14:57
As identified by Gotspatel, you have not input the code correctly (you are missing "sub"). Revisit the link/guide and read through carefully.
Virinum
Post by Virinum » 2021-05-26 08:25
For turning off auto reply automatically, I've written this script.
Set up a task in Windows Task Scheduler triggered every Monday at 6 AM calling the script like this "autoreply.vbs your@mail 0"
(You can also enable auto reply with this script by calling it like this "autoreply.vbs your@mail 1")
Const HMSADMINUSER = "USERNAME"
Const HMSADMINPWD = "PASSWORD"
email = WScript.Arguments.Item(0)
command = WScript.Arguments.Item(1)
domain = Split(email, "@")(1)
Dim obApp
Call obApp.Authenticate(HMSADMINUSER, HMSADMINPWD)
Dim obDomain
Set obDomain = obApp.Domains.ItemByName(domain)
Dim obAccount
Set obAccount = obDomain.Accounts.ItemByAddress(email)
if (command = "1") then
    obAccount.VacationMessageIsOn = true
end if
if (command = "0") then
    obAccount.VacationMessageIsOn = false
end if
obAccount.Save
autoreply.vbs
